Idle sputter/running rough and jumpy. Hit the accelerator, car stalls - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 07-04-2013, 06:59 PM
stonewall_johns stonewall_johns is offline
Mein Auto: 87 325i
The title pretty much sums this up. It's a 1987 325i. I'm very car illiterate so please forgive me! Any ideas of what this could be? What's weird is that this doesn't happen all the time. It's completely random and seems to be getting worse. On days that this happens, ill keep trying to start it and eventually it will start and run as if nothing was wrong.
Old 07-04-2013, 07:37 PM
woodenbmw's Avatar
woodenbmw woodenbmw is offline
Mein Auto: 1987 BMW 325
Re: Idle sputter/running rough and jumpy. Hit the accelerator, car stalls
Check for vacuum leaks...
1987 325e automatic sedan
Old 07-05-2013, 01:09 AM
toybuilder's Avatar
toybuilder toybuilder is offline
Mein Auto: 89 325i 2dr&DucatiMonster
Check the CPS (crank position sensor) and the idle control valve then start worrying about hunting down vacuum leaks.Since it's not happening all the time the CPS may be your culprit and when it goes the car will no longer start at all.If it does it try wiggling the wire for the CPS to see if you can get it to start.plus make sure there's no dirt or grease between it and the contact wheel.The other possible problem could be a sensor for your ECU is the car getting to operating temp before it starts and runs right? I mean it runs crapy enough times to get it to normal temp before it starts working?
Old 07-05-2013, 08:11 AM
First time's Avatar
First time First time is offline
INSANELY UNPREDICTABLE!
Mein Auto: 2001 540i sport/1994 525i
^this CPS failures are quite commonplace on the M20's
Old 07-05-2013, 10:25 AM
toybuilder's Avatar
Almost as common as air .They all go bad eventually it's just a matter of when. Then wire gets brittle from getting hot and they eventually fail.But it could be something else have you checked for codes?
Old 07-05-2013, 11:50 AM
cjmertz cjmertz is offline
Mein Auto: 325i
Also might try cleaning the throttlebody, pull the throttlebody Bootie off ..inspect it carefully for splits/cracks, if any are found or develop while removing ,Don't even try to repair.. ,just replace it.
Spray a lot of Gum cutter on a rag wrap wet area of rag around your RT hand pointer and middle fingers..open throttle lever on top of throttlebody with left hand,...clean all that black sticky carbon stuff you see in there from between the butterfly valve and the body housing walls.An old toothbrush soaked in the same cleaner helps too.Repeat,..get it squeaky clean Some air actually needs to pass thru that area even when closed at idle and if gummed up or otherwise blocked,.. idle-off idle transition characteristics may suffer .
WARNING/ CAREFUL! ..!Most if not "ALL" 0f the chemical combinations in carburetor cleaner containers (spray cans)..have affixed a label listing chemicals that are known to the State of California to cause cancer ,birth defects and other nasty maladies..and containchemicals which "cannot be made non-poisonous"...but by all means,Don't let any of that crap slow you down, lol!... ,..READ THE LABEL before use!! wear heavy rubber gloves to protect your skin, a respirator if desired, goggles.. and lord knows don't smoke while using any of these products..they are HIGHLY FLAMMABLE!! ...they may also damage or remove vehicle paint.This procedure WILL leave a very nasty toxic stain on your clean concrete driveway that may never go away..sheesh,..no wonder you can't find a good mechanic around anymore.. lol!Let us know if it helps
Old 07-05-2013, 04:17 PM
toybuilder's Avatar
Hey I resmeble that remark I've been a good mechanic for 28 yrs and after that long you develop an immunity to chemicals ,you almost start to like the smell, though the burn on your hands or open cuts you never get used to .P.S. DON'T USE CARB/FUEL INJECTION CLEANER ON YOUR AIR METER ,the plastic parts inside will be damaged.There is a chemical for cleaning MAF's that will work without any damage to the part if you follow the directions.
Old 09-24-2013, 04:11 PM
starspiker starspiker is offline
Mein Auto: 87 BMW 325
My 87 325 does the same thing but only when it is very damp or humid outside. Thought it might be the coil.
bill in Maine
Old 10-04-2013, 02:26 PM
tj88 tj88 is offline
Mein Auto: 94 bmw 318i e30
I believe this is the right spot. Hey Igot a 94 318I.e30. Just boght it and it started to idea real rough like miss fiering or wanting to stalll. And performance is kinda ****ty. looked around under hood and I beliefe its the maf boot was wrapped in tape and huge ass wholes I'm going to dealer to get a new one but was wondering is that it and itl be good afteror could it be something else and yesterday tried to start it and nothing
Old 10-05-2013, 06:41 AM
BMWFatherFigure's Avatar
Old School
Leaking boot = all bad. Check for other bad pipes and hoses too.
Current:
E38 Parts Car
Previous:
