E30 (1982 - 1993)
Old 09-20-2013, 04:59 PM
BimmMeUpScottie BimmMeUpScottie is offline
Send a message via AIM to BimmMeUpScottie
Mein Auto: 1988 BMW 325e 2dr
Question SI Board help....
Ok, I need some help on finding a new SI Board for my 88 325e coupe. BavAuto and Pelican Parts are charging $238 and $257 respectively and they don't even have lithium batteries:dunno. Does anyone know where I could find a remanufactured Board for around $125-$150?? Can anyone point me in the right direction?
1988 BMW 325e 2 Dr
6-cyl 2.7 Ltr (M20)
Automatic Transmission
Old 09-20-2013, 06:01 PM
cmac2012's Avatar
cmac2012 cmac2012 is offline
Renaissance Dude
Mein Auto: Two 1987 325i, 430K, 211K
Replacing the batteries is tough. I've done it twice and nearly blew it the second time. I can solder copper plumbing together like nobody's business but that low temp soldering is something else. I suspect I'll someday need a new board - if the car live that long - so I was curious and did a search also. I'm finding something better than that on Pelican Parts, not sure why:
http://www.pelicanparts.com/cgi-bin/...9-070-793-M250
Somewhat down the page, they have it with batteries for $198.
Science advances one funeral at a time. - Max Planck
Old 09-23-2013, 08:31 AM
Ken@BavAuto Ken@BavAuto is offline
Bavarian Autosport
Mein Auto: 1989 325is
Ours has a $60 core charge on it too. So if you send back your old one afterwards we'll refund you $60. Making the new board $178.95. If the original one lasted 25 years I'm sure the new one will last plenty long also lithium batteries or not.
CONTACT US
WEB: http://www.bavauto.com/ | E-MAIL: kenb@bavauto.com | PHONE: 800-535-2002
HOURS (EST): Monday - Thursday 8AM - 9PM | Friday 8AM - 7PM | Saturday 9AM - 4PM
CONNECT WITH US
Facebook | YouTube | DIY Tech Blog | Twitter
Old 09-23-2013, 12:06 PM
cmac2012's Avatar
Renaissance Dude
But it needs the batteries, doesn't it? You'll need to solder your own in place?
Old 09-23-2013, 12:12 PM
Bavarian Autosport
Sorry I didn't explain that very well. The boards come with batteries. Originals weren't lithium but they tend to last about 20 years. Yours is probably original now. Mine is and I have an 89. On the 86-older E30's the new boards actually use flash memory instead of batteries. But apparently that doesn't work on the later version so they retain the original design with batteries.
CONTACT US
CONNECT WITH US
Old 09-23-2013, 12:56 PM
cmac2012's Avatar
Renaissance Dude
Thanks, I was wondering about that - the older boards being more simple that is. I almost trashed my board with clumsy soldering the second time. It was only some heavy finessing with a magnifying glass and a bit of luck that I salvaged it and got it working. Next time out, I'll just get a new board (if the car lives that long).
Old 09-24-2013, 07:39 PM
I found one for a good price...Thanks for all the help Gents!
1988 BMW 325e 2 Dr
6-cyl 2.7 Ltr (M20)
Old 09-25-2013, 03:17 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
Post Soldering PC boards
a tip from somebody who solders electronics, including surface mount, every day.
Good light is vital
I have a lamp with a 6" magnifying glass attached on my work bench, as well
and I got myself a watchmakers loupe that you pop into 1 eye-socket
In the end I got myself a set of surgeon eyeglasses that have a magnifying glass built into it. It was expensive, but worth it
get a universal electronics clamp to hold things for you
a good soldering Iron is a must. I used Antex before I went onto a Weller soldering station with various bits.
Solder suckers are cheap & beat blowing molten solder all over the place
When you get older your hands shake, so make sure you can rest your wrists on something.
Make sure your workbench is ergonomic and that you have a bench at the right height to your chair.
With a bit of planning you can set up your workplace, as a place to enjoy
Don't take life too seriously; no one gets out alive !
1984 323 currently being resurrected from the ashes
325 e30, coupe., instrument cluster., si board
