E30 (1982 - 1993)
Old 09-25-2013, 09:36 PM
itrunsE3 itrunsE3 is offline
Mein Auto: BMW 325E coupe automatic
idle problems help please
I was cruzing around today because it was a nice weather and I park for a little bit and I some how touch my accelerator pedal and I notice that the rpms went down and then up I tought I was seeing things so I did it again and I notice that rpms went down and then up when I touch the gas pedal
This is the first time that I has happen does anyone know what may be the problem
When I bought it it had vaccum leaks and I replace the mass airflow sensor and the air intake boot and I seal other vaccum leaks but never change the idle control valve I have no idea if that's the problem
Old 09-26-2013, 02:50 AM
Billwill Billwill is offline
Mein Auto: BMW E30 318i 1991
Clean the idle control valve and make sure your Throttle Position Switch (TPS) under the throttle body is working correctly.
Old 09-26-2013, 09:55 PM
downhiller's Avatar
livin large
last time you did a tune up?
idle, problems
