Wheels torque specs for 2012 550i xDriver GT - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > F07 Gran Turismo (2010 - 2017)
The 5 Series Gran Turismo - 535i, 550i and 550i xDrive model.
Old 09-13-2013, 09:15 AM
The BoatMan's Avatar
The BoatMan The BoatMan is offline
Bayerische Motoren Werke
Mein Auto: '14 X5 50/ '10 Golf TDI
Not sure why BMW cannot include this in the manual. Our Golf TDI has wheel torque values in it's manual.
Searched and found another thread that stated "Factory spec on the GT is 140Nm, or 103ftlb" but that was for a 535i GT with sport rims.
Not sure if the 103 translates over to the 550ix GT with base 18inch rims. You think the 103 is universal across all 5 series GT models?
Thanks for the help.
Current:
2014 X5 50i M Sport w/DHP
2010 Volkswagen Golf TDI
Gone but not forgotten:
2012 550I xDrive GT
2009 X5 35d
2007 335i European Delivery with Performance Center Re-Delivery * ED May 4, 2007 Link to ED Trip Report / PCD July 5th, 2007 Link to Performance Center Re-Delivery Trip Report
2007 X3 European Delivery with Performance Center Re-Delivery
2002 330ci, 1997 328i, 1990 325i
Old 09-13-2013, 02:29 PM
I think that 140Nm is correct, but the safest thing is to call the dealer's service department. Since any of the GT's can have any wheels, it's more the hub/rotor spec than the wheel attached.
Old 09-27-2013, 09:22 AM
rogueshot rogueshot is offline
Mein Auto: '10 550GT
That seems high to me. I would definitely check it. A range of 86-92ftlbs is more "common."
Old 09-27-2013, 05:30 PM
It depends on the platform and the brake rotors. The GT uses a composite aluminum and steel rotor and aluminum expands and contracts more than steel, so some more tension is required to keep the bolts tight. I think you'll find the numbers I gave will check out with the dealer's service department. And, I agree, it should list that in the owner's manual!
