E36 (1991 - 1999)
Old 09-28-2013, 10:02 PM
wisbimmer20 wisbimmer20 is offline
Send a message via AIM to wisbimmer20
Mein Auto: 1998 BMW 328I
Ticking from Rear
Lately my 98 328 has been making a loud 'ticking' noise from the rear. The car now has 176k miles.
It seems to click louder under acceleration and in a turn. It sounds pretty bad. I don't notice anything different in terms of how the car drives, however. The noise seems proportional to speed but isn't really noticeable unless under harder acceleration and over 30-35mph. The sound is not affected by application of brakes but I could also hear the noise as I was pulling into my garage moving slowly in the driveway...
Recently I have replaced the Rear trailing arm bushings and rear shocks. I had one of the rear wheel bearings replaced a few years ago.
Previous BMWs:
1995 BMW 530i
1995 BMW 525i
Old 09-28-2013, 10:22 PM
hornhospital's Avatar
D'oh, You Kids!
It's either going to be the (other) wheel bearing or one of the CV axles. Take a peek at the CV axle boots. If one is torn, that'll be a likely suspect.
Quotes to live by:
Old 09-29-2013, 06:41 AM
drivinfaster's Avatar
Mein Auto: rescued bmw's
this.^
or, you could just turn the radio up...
df
Old 09-29-2013, 01:01 PM
I'm under the car right now and the CV boots look ok. When I pull back and forth on them there is some play but not sure if that is normal. Also, the exhaust shield is really lose since the places where its bolted too have corroded enough to loosen the shield so I'm imrpovising with some zip ties
Previous BMWs:
1995 BMW 530i
1995 BMW 525i
Old 09-29-2013, 01:19 PM
Must have been the heat shield because now I can't hear it anymore
Previous BMWs:
1995 BMW 530i
1995 BMW 525i
Old 09-29-2013, 01:51 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
That's good, because I was going to suggest it was a soon-to-be grenaded CV axle, too.
1998 BMW 328is
1966 Pontiac GTO
