E36 (1991 - 1999)
Old 09-30-2013, 08:20 AM
koaffiliate koaffiliate is offline
Mein Auto: 1998 BMW 328is
Just got my first BMW dash warning light help!!
Just picked up my first BMW yesterday and I love it. A 1998 328is. Anyways the brake pad light and the ASC light are always on, ABS light is not on. I tried holding down the button, just pushing the button etc and it doesn't change anything.. If I put the key to the on position, the ASC light goes out and the button will activate/deactivate it, but as soon as I start it, it comes back on.. any suggestions? Also is the 18 button OBC backlit? Its dark and the guy told me it needed a new bulb.
also is maybe the pad light and traction control light a connected problem or two separate things?
Old 09-30-2013, 08:29 AM
bmw-mania bmw-mania is offline
Mein Auto: BMW
Welcome!
Please be sure to SEARCH the forum FIRST..
TWO different lights.. two different problems.
You should read the owners manual regarding your E36.. Lots of INFO in there.
- Brake pad light means your brake pads need to be checked.. or you have a failing sensor.
- ASC light means you have a fault, and need to check the ASC.. or do as others have done.. and Delete ASC.
Its a bottleneck in the Intake system anyway..
- OBC's often have lighting issues... its a common problem.. they can be repaired easily.
Cheers!
Originally Posted by cj.surr View Post
I don't have to read the username on these posts to know who wrote it.
Bmw-Mania, Ladies and Gentlemen.
Old 09-30-2013, 08:33 AM
Thanks, yes I was doing a search just now and came across someone with an ASC problem because of a ripped intake boot.. I checked mine and it has a split in it as well.. Ill try replacing that and see if it works. Brakes are all new, so I will try checking or changing the sensors..
Old 09-30-2013, 08:54 AM
Mein Auto: BMW
Those boots can be pricey.. You can fix yours for now.. Save some moolah $$
Rubber cement, patch, or that stickyasalllhell black tar tape will work as a temporary fix.
That means your car has been sucking unfiltered air into the motor.
You should consider a engine cleaning after your fixes..
If you delete the ASC, you can get the NON-ASC boot..
If you KNOW the brakes are new.. inspect them.
Sensor may be disconnected, not connected properly, broken, etc..
Old 09-30-2013, 09:21 AM
I just went ahead and ordered the boot.. 38 bucks. I got the car at a reasonable price, so I have some extra cash to put into it.. boot will be here tomorrow, I guess Ill see if it works.
Old 09-30-2013, 10:00 AM
Mein Auto: BMW
awesome!
Old 10-01-2013, 07:55 AM
Got the boot, installed this morning, fixed my problem! Thanks for the help.
Old 10-01-2013, 08:38 AM
Mein Auto: BMW
^ booya.
Old 10-01-2013, 11:50 AM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
I'll always remember my first...
1998 BMW 328is
1966 Pontiac GTO
traction control asc dsc
