Fan Delete Mod - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 09-30-2013, 06:55 AM
alsy alsy is offline
Mein Auto: E36
Fan Delete Mod
It seems everyone is sick of hearing about this mod, buuuut i have a question that i think is probably going to be a stupid one but i cant find the answer to it.
Why do you need a lower temp fan switch when you are removing the fan?
Old 09-30-2013, 07:35 AM
hnaz's Avatar
hnaz hnaz is offline
BMW CCA Member
Mein Auto: 128i M, M3, 530i M
It's s safety, just in case.
Harry // 1995 Avus Blue M3 - 2003 Titansilber 530i M Sport - 2010 Black Sapphire Metallic 128i M - Sport // BMW CCA #453346 - North Capitol Chapter // 2000 Silver Audi B5 S4
My Previous Work:
My 325is M-Tech Restoration Thread
My 98 M3 and 03 530i Restoration Thread
Old 09-30-2013, 07:41 AM
Mein Auto: E36
Just incase what though? it wont be turning anything on? surely just blocking the hole on the side of the radiator is literally no different...?
Old 09-30-2013, 08:31 AM
bmw-mania bmw-mania is offline
Mein Auto: BMW
You read the threads regarding the FDM.. and you didnt find your answer??
I doubt it..
BECAUSE WITHOUT THE FAN, THE CAR RUNS HOTTER.
If you have UNDERDRIVE PULLEYS YOU NEED THE LOWER THERMOSTAT.
Originally Posted by cj.surr View Post
I don't have to read the username on these posts to know who wrote it.
Bmw-Mania, Ladies and Gentlemen.
Old 09-30-2013, 08:46 AM
Mein Auto: BMW
Are you fcuknig kidding me?
THERMOSTAT - is a THERMAL SWITCH activated at a specific TEMPERATURE.
Old 09-30-2013, 09:05 AM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
I Am The Machine
Mein Auto: Dreier, Fünfer & Siebener
Re: Fan Delete Mod
I doubt it..
Dude. What the f*ck are you talking about? The question has nothing to do with the thermostat.
OP, the Fan Delete Mod removes the viscous fan between the radiator and the engine. That fan is completely mechanical, no electrical at all. What the temperature switch that you're referring to does is turn on the electric pusher fan in FRONT of the radiator.
Normally, the electric fan only comes on when the air conditioning is running, or when the car is getting very hot. The mechanical fan provides almost all of the actual cooling of the engine. Since the electric fan is designed to come on only when very hot, this means that your engine will not get be getting any additional air at all at high temperatures until you reach the very high threshold for the electric fan and could leave you very vulnerable to overheating. The lower switch makes the electric fan come on earlier, to take part of the job the the mechanical fan was doing before you removed it and provide more protection against overheating.
That said, there's absolutely nothing wrong at all with the viscous fan setup,
removing it is a bad idea.
C:\>Sent from my 386 using MS-DOS__
// Chad //
// 2006 BMW 330i Sport 6MT // 2006 Toyota Highlander Hybrid //
// 1997 Range Rover 4.0 // 1994 Range Rover Classic //
// 1997 Land Rover Discovery // 1998 Land Rover Discovery //
// 2009 Kawasaki Concours 14 // 2006 Kawasaki Ninja 250 //
// 1999 Chevy Tahoe //
Ok...this is getting ridiculous. Someone come buy a few of these things.
Originally Posted by SlimKlim View Post
You're a derbanana
Old 09-30-2013, 09:23 AM
Mein Auto: BMW
You're right.. I re-read it.. I swear I read thermostat.
Mustve been the superblue brake fluid in my eye..
Old 09-30-2013, 09:24 AM
Mein Auto: E36
How funny is the internet with people shouting their heads off when they are still completely wrong, i asked the question and knew your answers were bull****.... as for phantom, thank you... that makes sense. And as i've removed the air con, i will not be needing the lower temp switch, correct?
Old 09-30-2013, 09:42 AM
I Am The Machine
Re: Fan Delete Mod
That's incorrect. You NEED air moving over the radiator or you'll over heat. When you do the FDM you still need the air flow, but now you're relying on the electric fan to provide it. Like I said, the electric fan only comes on A) When A/C is on OR B) when you exceed very high temperature limit of the fan switch on the radiator. A&B are separate situations, the elec fan will still come on without A/C when the temp for the switch is met.
The idea is that temp is set very high because it's only supposed to help the mechanical fan in very hot situations with mechanical fan can't keep up. When you remove the mechanical fan, then you're not getting any air until extremely high temperatures. So, you change the temp switch so it comes on earlier before you're at dangerous temps.
// Chad //
You're a derbanana
Old 09-30-2013, 09:52 AM
Mein Auto: BMW
^ feeling high and mighty now??
What shouting? You mean EMPHASIS? We're on the interweb.
Its called a AUX fan.. short for auxiliary fan, dipswitch.
Your post simply stated "lower temp fan switch".. which, stupid fcknig me, I took for "lower temp thermostat"
Because.. there is no "lower temp switch" on the fixed fan.
I assumed since you didnt SPECIFY what you were talking about, you must've meant the THERMOSTAT.
Since the THERMOSTAT is changed to a "lower temp" when you do the FDM and is available in multiple different "lower temp"s. 88, 92, 74, etc..
Your question was answered in the FDM thread... on this forum, bimmerfourms, m3net, r3vlimited, etc..
NO.
YOU NEED TO DRAW AIR OVER THE RADIATOR TO COOL THE COOLANT.
Are you aware of how the systems on a vehicle work?
Please re-read the FDM threads..
Sorry about your luck.
Cheers!
Mein Auto: E36
sorry i don't think i explained what i meant clearly, i've removed the air con along with the fan that sits on the front of the rad, which is normally the air con fan right? if so i am right in saying i don't need that switch?
sorry if im not making much sense.
Old 09-30-2013, 09:54 AM
Mein Auto: BMW
Quick draw!
Damn.. you're fast phantom..
Old 09-30-2013, 09:57 AM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
The electric fan serves two purposes: To add cooling air flow when the AC is on, AND to add cooling air when the coolant temperature gets higher than normal. In fact, it has two speeds, and will 'kick it up a notch' if the temperature gets really high.
Cliffs: You need that electric fan. Put it back.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Mein Auto: BMW
You're saying you removed the aux fan, the only fan you have left...?
Reinstall and hardwire to a switch.
Old 09-30-2013, 10:00 AM
Mein Auto: E36
No i have a fan hardwired to a switch, just not the aux fan. that's why i'm wondering about the switch, because in my head its now doing nothing except stopping water falling out the hole right?
Old 09-30-2013, 10:06 AM
Mein Auto: BMW
you should have put ^ this info in your original post.
If you have a fan wired to a switch for the radiator..
then you can re-install the A/C AUX fan sending unit without connecting it to "plug" the hole.
Old 09-30-2013, 10:08 AM
Mein Auto: E36
awesome, you actually ended up being helpful.. thank you. no hard feelings, haha.
I Am The Machine
Re: Fan Delete Mod
Let's go back to square one so we're all on the same page.
There are two fans. Electric on the front, viscous on the back.
FDM usually refers to removing the viscous and keeping the electric.
You're saying you removed both fans though and replaced one with an electric on a switch, is this correct?
I'm assuming the new fan you're talking about is a puller fan between the radiator and engine?
Where is the switch for this getting its temp data from?
// Chad //
You're a derbanana
Old 09-30-2013, 10:20 AM
Mein Auto: E36
Yep, all correct.. and shoot me down but it isn't, i just turn it on when i feel i need it, will most likely be on all the time bar the first 10 - 15 minutes of having the car run... but i live in england, its rarely hot i don't really have to worry about stupid high temps.
Old 09-30-2013, 10:23 AM
Mein Auto: BMW
None.
You actually ended up learning..
His finger.
Yep, all correct..
what? no shooting. We're indoors.
You dont need to turn the fan on during initial startup.. just during operation when at temperature.
turn it on if you're in traffic for longer than 2 minutes, or sitting and idling..
Cheers!
Old 09-30-2013, 10:37 AM
D'oh, You Kids!
mania, I got notice you'd PMed me, but I can't reply until you clear out your inbox. You are over the limit for message storage.
Quotes to live by:
BMW-CCA #441426
Old 09-30-2013, 10:45 AM
I Am The Machine
Re: Fan Delete Mod
Ultimately you have to make the decision based on the risk you're comfortable with, but I can't imagine doing it that way.
Why not replace the aux fan switch with a lower temp unit and splice the wires to your new fan? Then you wouldn't have to deal with the manual switch.
To bring it full circle, if you're dead set on keeping it the way you have it (which I think most all of us would highly advise against), you're right that the switch in the radiator is now just plugging the hole and wouldn't need to be changed out.
// Chad //
You're a derbanana
Old 09-30-2013, 10:58 AM
Mein Auto: E36
mainly because my ability to wire stuff is awful, this way its simple and i'm in control.
