E36 (1991 - 1999)
Old 09-30-2013, 10:48 AM
bec1506 bec1506 is offline
Mein Auto: E36 1994 Convertible
Question E36 1994 Driver's Window Problem
Hi
My dad has a 1994 E36 convertible with a problem to his driver's window. The regulator wouldn't work and he couldn't get his window down. We have checked the switch and wiring and all ok. My husband tried a second hand regulator in it but this only worked quarter of the way up. When you shut the door it goes up a bit more to close onto the roof we guess. He has had the regulator apart to see if anything catching and can only think it must be the motor. Does any one have any ideas before we buy a new regulator??
Old 09-30-2013, 11:46 AM
tim330i's Avatar
tim330i tim330i is offline
Bimmerfest.com Founder
Mein Auto: Ti Silver 03 M3
Welcome to Bimmerfest! I moved your thread over to the E36 forum. You'll be able to get more help in here from other E36 owners.
Tim
Old 09-30-2013, 12:11 PM
e36 miguel e36 miguel is offline
Mein Auto: 1995 325i
Welcome to the fest! Check the plastic sliding pieces that go on the rails on the windo and make sure theyre not broken and are attached to the regulator arms. Make sure the arms arent bent either i had that problem. If you have to buy a new one try- autohausaz.com or ecstuning.com
Old 10-01-2013, 08:22 AM
Smile
Ok thanks will try this first. A guy in the trade thinks it maybe the computer not talking to the body computer as well. Will look at other options before buying a new regulator
Old 10-01-2013, 09:29 AM
bmw-mania bmw-mania is offline
Mein Auto: BMW
STOP STOP STOP..
It has nothing to do with a "computer not talking to the body computer"
I would suggest not going back to that mechanic either..
Dont go buying a new stuff just yet!
Your windows need to be SYNC'd.
There are microswitches in the door latch that make the window go up a little bit when you close the door.
Your windows are out of sync from the battery dying, a jump start, or disconnecting window motor/regulator plugs while the car is on.
The car should be off.
The door should be closed.
Then turn on the ignition 3 clicks..
hold DOWN buttton.. window should go down.. HOLD for 20 seconds
hold UP button.. window should go up.. HOLD for 20 seconds
IF, the door is closed, and the window does NOT go up.. you have a failing microswitch in the latch.
Lean against door while it is closed to try and activate it.
Try to push UP button again...
A cheap fix is to "pad" the latch striker in the door jamb, or the latch in the door with some electrical tape.. you only need a few millimeters of "padding".
The contacts in the microswitches just wear out after use..
the "pad" allows a different part of the switch to make contact.
Originally Posted by cj.surr View Post
I don't have to read the username on these posts to know who wrote it.
Bmw-Mania, Ladies and Gentlemen.
Old 10-06-2014, 07:11 AM
pmr49 pmr49 is offline
Mein Auto: Acura TL, M Roadster
Smile to the Rescue
Thanks bmw-mania
Here we are a year and a few days later and your cure was just what was needed after I repaired the door panels, replaced the cracked tweeter housing and lubed the windows. Love this forum!
Old 10-06-2014, 08:58 AM
Mein Auto: BMW
^ you're welcome!
now roll down those windows and take a drive!
If you need anything else lmk..
Cheers!
