E36 (1991 - 1999)
Old 09-30-2013, 06:28 AM
bigmikebuck bigmikebuck is offline
Mein Auto: 1997 328i
Exclamation Catastrophic Cooling Failure
HELP!! I was driving my 97 328i yesterday and I experienced a catastrophic failure with my cooling system, mainly the radiator fan and it's housing. I have not owned this vehicle for long and it has been running like a dream for the month I've owned it.
I was driving when there was a loud metallic clank the the gut wrenching sound of breaking plastic. Then the car shut itself off. when I looked under the hood almost all of the coolant was either draining out or was already on the road. The housing that the coolant reservoir was attached to was broken from it's mount and the top of it was bout midway down the fan. Two of the blades on the fan were also broken and on the ground under the engine.
Not sure what exactly broke or how to fix it. Wondering if anyone has had this problem before or might have any hints or tips. I am a sufficient mechanic and have worked on cars for years (never a BMW though). Since im a broke college student i want to do the job right but was hoping to minimize cost and avoiding expensive repair shops if at all possible. ANy insight would be appreciated. Thanks.
Old 09-30-2013, 08:40 AM
bmw-mania bmw-mania is offline
Mein Auto: BMW
Yup!
Time for a cooling system overhaul!
Common weak chank in the armour..
Although I am having a hard time visualizing... Do you have a pic?
A Metal clank? then the car shut off?
Chances are.. time for a new water pump(get a metal impeller) Low thermostat, housing, gaskets, belts and fan..
You can do the fan delete mod, at this time if you like.
If you do, its nice to keep the fan in the trunk. i.e. hot days, traffic.. I can install mine at a stoplight.
I have a spare radiator shroud, if you need it.
Cheers!
Originally Posted by cj.surr View Post
I don't have to read the username on these posts to know who wrote it.
Bmw-Mania, Ladies and Gentlemen.
Old 09-30-2013, 03:54 PM
Nicky3 Nicky3 is offline
Mein Auto: 96 328is
As long as you didn't overheat for long you should be fine. You should rebuild your entire cooling system as a maintenance item at about every 75k miles IIRC. It is THE weak point on this car.
Old 09-30-2013, 04:00 PM
Mein Auto: BMW
^ Nick.. yes.. you are correct.. every 75k/miles..
Here is a good peek-a-boo
http://edgemotorworks.com/wordpress/...ing-m-edition/
328i, broken, cooling, radiator cooling fan
