Hellrot Turbo Build - Page 74 - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 09-30-2013, 11:31 AM
FenderBender's Avatar
FenderBender FenderBender is offline
Needs Boost
Mein Auto: Red Sled
Re: Hellrot Turbo Build
Thank ya sir! Have a long way to go but progress is progress.
Turbo Build Here
Old 09-30-2013, 01:17 PM
TheFinanceGuy's Avatar
TheFinanceGuy TheFinanceGuy is offline
still learnin'
Mein Auto: 1998 328i / 99 540iA
Wait, is there enough room between the frame and the turbo, or does that require minimum room?
Patrick ///04 330i ZHP///BMWCCA#465139
99 540i TiAg
98 328i hellrot (sold)
96 318iC black (sold)
Old 09-30-2013, 01:18 PM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
The turbo clearance is fine, but I just noticed the compressor outlet. It's pretty close to the frame tube. Is there enough room for an elbow in there, Matt?
-CJ
Old 09-30-2013, 01:23 PM
still learnin'
sorry bad description, that is where I was looking.
99 540i TiAg
Old 09-30-2013, 01:24 PM
Needs Boost
Mein Auto: Red Sled
Motor won't be moving so clearance is good. I need to clock the turbo, it can be rotated to any degree so the frame rail won't be an issue.
Turbo Build Here
Old 09-30-2013, 01:26 PM
still learnin'
Huh, the more you know.
99 540i TiAg
Old 09-30-2013, 04:45 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
yeah, i saw that earlier but wasn't certain if the turbo was clockable or not, but figured matt has a pretty good idea what is going on.
and if not, would probably just cut a hole to fit....
df
Old 09-30-2013, 06:39 PM
Needs Boost
Mein Auto: Red Sled
Here happy???
Untitled by fender13bender, on Flickr
Didn't get as much done as I had hoped tonight. I tightened up the subframe and motor mounts, attached the rear coolant/heater hoses, installed correct dipstick tube O ring, and connected the steering shaft.
AKG mounts and such
Turbo Build Here
Old 10-02-2013, 06:11 PM
Needs Boost
Mein Auto: Red Sled
Had a few hours to spare today so more work got done. I'm really trying to get all the annoying pita jobs done now. I was able to reinstall the control arms, and sway bar end links. I put on a new M50 slave cylinder with a UUC SS clutch line (got illegal super blue fluid EVERYWHERE!!) and also installed my UUC EVO short shifter and DSSR. The water pump pulley had a hairline crack so I bolted up one I had laying around and installed the belt.
The old ground wire was nasty and chewed up so I bolted up a new one as well. Then installed the power steering lines and I figured I would start putting the front end together.
Food for thought, I'm thinking of running the coolant drain alone the top like the oil feed and coolant feed, then around the back of the engine to the block drain. I'm hoping this will keep the exhaust manifold heat off of it, or should I just leave it as is?
New guy
Installed
Undercarriage pron
Shifter, I need to clean up the greasy tranny once I get it on a lift
Old
Newish
Sneaky (hood JUST closes)
Front end parts
Clearance
Turbo Build Here
Old 10-02-2013, 06:17 PM
wow that's close matt...
will that cover insulate the hood enough??
df
Old 10-02-2013, 06:18 PM
Needs Boost
Mein Auto: Red Sled
Yes, and to be sure I'm going to buy some reflective heat tape for the hood and fender.
Turbo Build Here
Old 10-04-2013, 07:13 PM
Needs Boost
Mein Auto: Red Sled
I finished all the turbo feeds and drains tonight, ended up changing the coolant drain. I made another line that goes under the intake manifold, behind the engine, and to the block drain. I'm happy with how it looks and it's away from manifold heat. I may end up shortening or getting a different angle fitting for the oil drain, but for now it should work well. Some coolant hoses needed hooked up so I did that, then installed the radiator and some front end parts. It's coming along nicely. Even my Depo HID headlights fit with this turbo, however it looks like I'll just be running some type of turbo screen, no filter.
I need to do some trimming of the bumper support to get the intercooler to fit, so that will have to wait until I can borrow a plasma cutter. Then I'll mount it and start meausring and cutting intercooler piping and a downpipe.
Anyone have links to some intercooler piping, probably J bends? I'll need downpipe material as well.
Turbo Build Here
Old 10-05-2013, 05:58 PM
bimmer claus's Avatar
bimmer claus bimmer claus is offline
Santa
Mein Auto: 95 M3
Coming from a person with car OCD this looks super clean. Great job on the install thus far Matt I'm loving it. The feed/drain lines look stupendous. How/s the whole turbo/headlight/airfilter thing going to work out? OR are you just running a screen?
Lots of junk.
Old 10-05-2013, 06:49 PM
Needs Boost
Mein Auto: Red Sled
Thank ya sir. Yea I'm just going to buy some kind of turbo screen.
Turbo Build Here
Old 10-06-2013, 07:27 PM
jkmeisl's Avatar
jkmeisl jkmeisl is offline
Josh
Mein Auto: Built inze Fatherland 325
wow I have followed this thread in forever... theres alot going on here. everything looks amazing holy crap
M3GT sedan - my slow progress thread ->http://www.bimmerfest.com/forums/sho...040&highlight=
Old 10-06-2013, 07:30 PM
Santa
Mein Auto: 95 M3
Whats the official cost on the build Matt?
Lots of junk.
Old 10-06-2013, 07:39 PM
still learnin'
Hellrot Turbo Build
That's like asking a girl her age....
99 540i TiAg
Old 10-06-2013, 07:47 PM
Needs Boost
Mein Auto: Red Sled
Haha, cost is in the 5 figure range for sure.
Turbo Build Here
Old 10-06-2013, 07:48 PM
Santa
Mein Auto: 95 M3
In all honesty that's not nearly as bad as i thought
Lots of junk.
Old 10-07-2013, 06:06 AM
jkmeisl's Avatar
Josh
you thought is was in the 6 figure range?
Old 10-07-2013, 07:40 PM
Needs Boost
Mein Auto: Red Sled
Got the intercooler rmounted up tonight. Took a few hours but it came out just perfect. I used two pieces of angel aluminum and one piece of aluminum flat stock. I'm going to add two more bolts to the nose panel for added strength.
Unfortunately I didn't cut enough of this off
Mock up
Bracket
Painted and installed
Turbo Build Here
Old 10-08-2013, 05:56 AM
still learnin'
I like this.
99 540i TiAg
Old 10-08-2013, 06:04 AM
jkmeisl's Avatar
Josh
very well done! I like the fact thats the intercooler isnt slapping you in the face when you look at it. almost have to look twice, I like it!
Old 10-08-2013, 06:29 AM
BMRfanatic's Avatar
BMRfanatic BMRfanatic is offline
Mein Auto: Bad Luck 46
Matt doin WERK!
Modded front bumper support FTW!
Nice work dude
Will your lights have enough room with the turbo being there?
-Dino
Old 10-08-2013, 09:19 AM
Needs Boost
Mein Auto: Red Sled
Thanks guys. My depo lights look like they'll fit just like before.
Turbo Build Here
:3
