E36 (1991 - 1999)
Old 09-28-2013, 09:11 AM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Originally Posted by drivinfaster View Post
edit: if your fluid level is low enough to turn the light on, then you either have a leak or are very low on friction material.
Isn't the low brake fluid warning light different than the brake pad warning light? Edit: it is in the E36, so I'm assuming it is also the case in the E46.
1998 BMW 328is
1966 Pontiac GTO
Old 09-28-2013, 09:24 AM
BMRfanatic's Avatar
BMRfanatic BMRfanatic is offline
Mein Auto: Bad Luck 46
yeah the e46 pad warning is a orange circle with the 6 bars around it. and the brake light is for the ebrake and red while driving either means the parking brake is engaged (beeps also) yellow means a problem with the DSC/ABS.
at least to my understanding from the manual pdf i found
-Dino
Old 09-28-2013, 09:39 AM
ZeGerman's Avatar
Warm Leatherette
Yeah, so we know it isn't a pad thickness (i.e. friction material) issue, which of course was confirmed by the low fluid level you found in the reservoir.
1998 BMW 328is
1966 Pontiac GTO
Old 09-28-2013, 10:15 AM
southpark11235's Avatar
southpark11235 southpark11235 is offline
bimmerfest Supporting Member
Mein Auto: 1999 BMW 323is
Originally Posted by Dino1394 View Post
hmm the tank looks dry i opened the cup but the little filter inside wont come out guess I need to buy some fluid.
If the tank is out of fluid, it could let air in to the system. After you put more brake fluid in you should bleed the system.
and interestingly enough i found the warranty handbook from 04 and it says that the AutoTragics should have their fluid changed every 100k. BUT the coolant shouldnt never have to be changed because its life time
What is next, lifetime gas? I can imagination it now. "Buy one of our BMWs and we will fill up the tank with special BMW lifetime* gas. Then you will never have to buy gas for the life of the car*.
* Life of the car is 500 miles. BMW can not be held responsible for any failures after 500 miles. Use of any non-BMW parts including, but not limited to, a non-BMW drive and non-BMW socks will void all warranties.
Alex//1999 323is - power e46 M3 seats, style 43 rims, 328 exhaust, Z3 rack, Bilstein PSS coilovers
“We got about ten minutes before this entire county is up in flames. If you want to live, you’d better step on the gas! Oh wait is this a Tesla? Sh!t! Well, step on the prissy pedal, we're going to die!” – Cartman
Old 09-28-2013, 01:35 PM
BMRfanatic's Avatar
Today on my Bimmer I...
Ok so I guess I was wrong about the brake fluid. I poured a little and didn't see a change so I managed to get that cap off and saw it had plenty of fluid. It was quite clear too (all the brake fluid I've seen was a sort of green color)
So i have no idea why that light is coming on.
-Dino
Old 09-28-2013, 05:29 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
stuck float in the reservior?? (not under pressure, so no alex, no need to bleed the system when removing the cap), possible short to ground in the e-brake warning circuit??
thoe are the 2 most plausible that come to my mind....pic of said indicator light??
df
Old 09-28-2013, 05:39 PM
BMRfanatic's Avatar
df
the light in the white circle is the one im getting
car doesnt beep while moving so i dont think the car thinks i left the e-brake up
the one circled in blue is the pad warning
-Dino
Old 09-28-2013, 06:00 PM
yeah, i believe that is a fluid level indicator....especially if it isn't beeping. then i would rule out the parking brake signal short to ground possibility, or else you would be hearing the beeping.
jiggle the reservior next time the light is on and see if that turns it our also, see if the float is in the bottom of the reservior you should be able to see it, or at least where it goes into the side of the reservior. it'll have a plug on it....
df
Old 09-28-2013, 08:37 PM
I know that, I was just saying that if the reservoir was run completely dry it could suck air into the system. I guess I phrased it poorly, oh well.
Old 09-28-2013, 08:44 PM
97328i 97328i is offline
Mein Auto: 1992 325i, Porsche 944 s2
Rather than just setting the subframe bushings on fire.. If you use a puller and a bearing press (or a large socket), then heat up the metal around the outside of the bushing, it is not difficult to press them out. Crank the puller down to build up the tension pushing on the bushing, then heat up the outside metal. Because of the tension, you can watch the bushing start sliding out as it heats up. When it starts slipping out, you've hit the right temperature and can easily press it the rest of the way out.
Name:	e36 subframe bushing press puller.jpg
Old 09-29-2013, 09:30 AM
BMRfanatic's Avatar
Ok I got the BMW CEL code from my car and for some reason the light when out when I never did the clear command
anyways i got this
235 (Oxygen-sensor control upstream bank 1) and 236 (Oxygen-sensor control upstream bank 2) also a i hidden p0430 that was pending and ended up going away and never setting the light.
maybe its time to do change both pre cat o2s?
Im looking into seeing if I have the right DME update since apparently BMW released a TSB software update since there was a o2 reading error that could cause the CEL and a lag at take off around 2k rpms. I remember updating it but who knows.
And i still dont know why my side mirrors dont work
-Dino
Old 09-29-2013, 12:22 PM
BMRfanatic's Avatar
I found my passenger front tire flat today
hope i didnt run over anything
-Dino
Old 09-29-2013, 12:25 PM
E36 Phantom's Avatar
I Am The Machine
Re: Today on my Bimmer I...
Ouch, that sucks.
Changed the E38 oil yesterday. Also pulled the carbs from the Connie.
C:\>Sent from my 386 using MS-DOS__
// Chad //
// 1999 Chevy Tahoe //
You're a derbanana
Old 09-29-2013, 08:31 PM
My project is moving very slowly. Removed bushings yesterday. Cleaned up, painted the subframe, then installed new bushings today. I'd have gone stock replacement but I'm also welding in reinforcement plates, so why not?
Name:	e36 subframe purple powerflex bushings.jpg
Old 09-30-2013, 05:59 AM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
I would definitely do powerflex bushings over stock. And good call on the reinforcement plates.
-CJ
Old 09-30-2013, 06:46 PM
FenderBender's Avatar
FenderBender FenderBender is offline
Needs Boost
Mein Auto: Red Sled
Make sure you get the correct Mcmaster washers and E90 studs if you're using powerflex bushings.
Turbo Build Here
Old 09-30-2013, 06:50 PM
cj.surr's Avatar
some kid
Ugh... Nobody ever told me about that. I've been using the Powerflex bushings with stock studs and washers.
-CJ
Old 09-30-2013, 06:55 PM
Needs Boost
Mein Auto: Red Sled
Google it, should fine a thread documenting the powerflex washers crushing after a while. The fix is some really thick Mcmaster washers, but then you need longer studs.
Turbo Build Here
Old 09-30-2013, 07:00 PM
cj.surr's Avatar
some kid
I'm not even using Powerflex washers... I'm using stock ones.
It makes sense that the stock washers aren't too good, since they are curved and have limited contact area. I'll probably just find some washers that cover the bushing and still fit the stud. Don't feel like dropping the subframe again just for that.
-CJ
Old 09-30-2013, 07:03 PM
Needs Boost
Mein Auto: Red Sled
Don't blame you, that should work well anyway.
Turbo Build Here
Old 09-30-2013, 07:11 PM
cj.surr's Avatar
some kid
Yeah, it's been working fine as far as I know.
Not sure if it's related or not, but I have been getting a knock when the drivetrain loads/unloads. There isn't a clunk or jolt, though. Only things changed in the drivetrain were trans, diff, and driveshaft. The trans had significantly less backlash than the old one. And the diff seemed about equal, I think. There used to be a jolt (no knock) in my old car, but now it's just the knock. Any ideas? I couldn't find anything to be loose upon hand inspection.
-CJ
Old 09-30-2013, 07:57 PM
hornhospital's Avatar
D'oh, You Kids!
Subframe bushings maybe?
Quotes to live by:
Old 09-30-2013, 08:25 PM
cj.surr's Avatar
some kid
They're good powerflex ones...
-CJ
Old 09-30-2013, 08:34 PM
D'oh, You Kids!
Oh. Trying to think what else can clunk. ???????
Quotes to live by:
Old 09-30-2013, 08:36 PM
cj.surr's Avatar
some kid
Since I used most of the same parts, it doesn't leave much. Is it possible that this diff is just noisier than the other one? It's a pretty decent volume knock.
-CJ
:3
