Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > F07 Gran Turismo (2010 - 2017)
The 5 Series Gran Turismo - 535i, 550i and 550i xDrive model.
Old 10-02-2013, 11:18 AM
gt=hi&bye gt=hi&bye is offline
GT = hi&bye
Mein Auto: 550i gt
Pic of bulb...
Yes, they are 6000K White. Similar to eBay item no. 370872340002. Or see pic. Except in the footwell, I used T10/194 bright white strips. Sold by jwmotoring.
It has been a year now and I haven't replaced a single bulb, or strip.
I am interested to see what the T10/194 OEM BMW LED bulb looks like. Anyone have a pic?
Old 10-02-2013, 11:41 AM
rogueshot rogueshot is offline
Mein Auto: '10 550GT
thanks GT....
I am thinking that dropping down to a 3 or 4 led "bulb" may be the way to go along with a warmer (3000-4000) white.
ID:	400095   Click image for larger version
Old 10-02-2013, 11:43 AM
I will check clearances of housings for the OE bulbs and then order a few different LED styles in a warmer tone than 6k and report back with some pics with a goal of finding an LED replacement that is whiter then OE halogens and perhaps just a bit brighter than OE (without being obnoxious). This will likely take a few weeks as most bulbs come directly from China....
Old 11-03-2013, 11:29 AM
Roadmax Roadmax is offline
Mein Auto: M3
LEDs
Great post, thanks OP.
I will also repeat the same here that these LEDs are ON only when we need to see better into interior of the car and OFF when we need to see the amber lights.
The factors that are important for me to switch to LEDs are:
1.Lower battery power consumption (I will have to find out exact difference in current draw between regular bulb and LED)
2.Less heat while staying ON
3.Better visibility, more light output
My car has lots of interior bulbs that are not the same model type and I will have to check each one and make a list for what type of LEDs I will need to order and where to order from.
It appears that BMW LED packages are way to expensive compared to other web sources that can be obtained for less $, but I am not sure about quality so some more homework for me here.
Old 11-10-2013, 06:05 AM
Akacia Akacia is offline
Mein Auto: f07
I have one question about this. Removing the front center portion for the swap where the sunroof switch is how did you get this out of the headliner?! I am having a hell of a time and of course don't want to break anything in the process.
Old 11-10-2013, 06:27 AM
GT = hi&bye
Mein Auto: 550i gt
Removing that console is tricky. Some have done it, others have had the dealer replace those bulbs.
For me, I tried to remove it, broke the clips (and still didn't get it off), and was forced to take the car to the dealership. They had to reglue and replace bulbs for me...ended up costing me $30 for the labor.
If you take the car to the dealership, odds are they won't charge you. They use a spatula-like tool to remove the console and it only takes them a few minutes.
I would rather be safe than sorry. Consider letting them replace those bulbs. All the other ones are a piece of cake.
Good luck!!
Old 11-10-2013, 10:47 AM
Mein Auto: f07
Good luck!!
Thanks appreciate it!
Old 02-21-2014, 01:49 PM
madmachunting madmachunting is offline
Mein Auto: bmwgt550msport
helo did yu change the door led lights ??
Old 02-21-2014, 02:02 PM
GT = hi&bye
Mein Auto: 550i gt
Door lights? Do you mean the lights that are on the bottom of the door panel and reflect on the ground? I think they are also called puddle lights. Yes, those are T10 bulbs and can easily be replaced with LED.
Old 02-21-2014, 06:17 PM
No I mean the led on your door handles and do you now how to remove the headlight unit ?? Are the angel lights upgradeable thks malcolm
Old 02-22-2014, 12:26 AM
GT = hi&bye
Mein Auto: 550i gt
Those are already LED. From the factory, the lights in the door handles and the license plate bulbs are already LED. No sure why you would want to replace it with another LED.
I have no idea on the headlight unit. Perhaps another forum member will be of more assistance regarding the headlights.
Old 08-09-2015, 10:45 AM
mydizzal mydizzal is offline
Mein Auto: 535i GT
Talking Very nice lighting :)
I love the lighting!!! Did you also replace the bulbs in the vanity mirrors too? If you did, what size and where did you get bulbs from? I really want to do that
Old 08-09-2015, 12:31 PM
GT = hi&bye
Mein Auto: 550i gt
I don't remember replacing bulbs in the vanity mirrors
I don't remember replacing the bulbs in the vanity mirrors. It's been so long since I did this swap....heck, the car is even gone!
Anyway, good luck!
Glad to see others are enjoying this mod.
Old 02-18-2016, 02:38 AM
Muz1k Muz1k is offline
Mein Auto: 535i GT
Did your kit come with bulbs for hatch, glove box and visor? if so where di you purchase it. The kit I received from IJDMtoy had 14 bulbs (4 dome, 2 map, 4 doors and 4 foot well) I can't find anything for hatch and visor has several options but the LED's don't look alike. I will call to ask about the visors from a few companies but wanted to ask you since you are the only one I've heard that actually installed it in a GT.
Old 02-18-2016, 04:14 AM
GT = hi&bye
Mein Auto: 550i gt
I didn't buy a kit....I just bought individual bulbs off eBay.
If I remember correctly, all the replacement bulbs were T10/194 bulbs. That's a pretty standard bulb. In fact, Autozone sells them, although they are a lot more expensive than just buying a 10 piece lot off eBay.
I don't remember replacing the visor bulb. The hatch bulbs should be T10 LEDs.
I've long since sold the car so I can't check it for reference.
Good luck!
Old 02-18-2016, 04:57 PM
2009f01 2009f01 is offline
2010 F07 550i
Mein Auto: 2010 GT 550i
Excellent mod. I did the same on mine, would not have it any other way.
Old 02-21-2016, 09:14 PM
Mein Auto: 535i GT
Has anyone replaced the bulbs in the visor, glovebox and hatch in the 5 GT (F07) with LED's. The visor is a very small bulb. What type of bulbs were used?
Old 07-01-2016, 09:22 PM
graphitegt graphitegt is offline
Mein Auto: 2013 F07 550i Xdrive
Do you have instructions on how to change dome lights?
I do not see the metal tabs in the front near the windshield .
Also when i stuck the screw driver into the L openings I could not figure out which way the tabs needed to go to drop the whole panel.
Any help would be appreciated.
Old 12-23-2016, 11:24 AM
TestShoot TestShoot is offline
Guibo killer
Send a message via ICQ to TestShoot Send a message via AIM to TestShoot Send a message via Yahoo to TestShoot
Mein Auto: E71 M, E60 535i
word of warning. LED domes will blind you at night when someone gets out of the car and you have to park. I park on the street, a very, very dark street and I curb my wheels because my night vision is shot but the luxor casino level of brightness, but it is killer for looking for things you may have dropped in the car.
