E28 (1982 - 1988)
Old 09-27-2013, 02:54 PM
karenfraser karenfraser is offline
Mein Auto: 1986 BMW 525
1986 BMW 525 - E28 Will not start in Cold Weather
Hello
I am new to this site and have a 1986 bmw 525. A year ago it started having problems starting in very cold weather (0-5 degree C. Now it is having these same problems in weather that is only 12-15 degrees C. Once it starts it runs fine.
Any ideas?
Karen
Old 09-27-2013, 05:56 PM
catso's Avatar
catso catso is offline
catso
Cold start valve, idle air control, plugs, wires, coil, fuel delivery system; lots of possibilities.
Don't be gormless; get some gorm!
![/I][/FONT]
Old 09-28-2013, 01:46 PM
cjmertz cjmertz is offline
Mein Auto: 325i
A quick check would be to remove the cold start valve..2bolts...set it aside, point it by twisting/spinning at the hose clamp in a safe direction, like straight up
when it's cold enough, climb inside and turn the ignition on to START,.. be quick to turn it right back off! ....you should observe a large fuel mist spray coming from the nozzle end..., if not you may have other issues, could be a bad valve itself...easy enough to replace, but I'd go one more step...
disconnect the electrical connector from the valve, and connect a voltmeter or 12v test lamp between the two connectors and do the same cold day test as above...
you should get 8+ volts there or your test lamp should lite if not...suspect the thermo-time switch.
it's been a long time since I've seen these, I thought 1982=84 were the last of the cold start valves...either or both of the above checks were pretty standard with this complaint.
Your engine is a 6 cylinder, with one fuel injector for each cylinder... the cold start valve is essentially a seventh injector , spraying a little extra fuel on cold mornings to enriching the fuel mixture across the plenum just a little more, kind of like a choke, but in reverse ( the choke will allow a little less air) ..
Old 09-29-2013, 06:14 AM
south26 south26 is offline
Mein Auto: 535i 1989
They had the cold start valve until 88 with the 528e seta. I am assuming the 525i had the m20 so it would be like the 528e here in the states, so I would also guess the cold start valve.
Old 10-05-2013, 08:37 AM
BMWFatherFigure's Avatar
Old School
Cold start control switch or (and) temp sensor for the ECM.
Current:
E38 Parts Car
Previous:
HTML code is Off
