Flashing SMG gear # in the display - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E46 M3 (2001-2006)
E46 M3 (2001-2006)
Old 07-28-2005, 05:47 AM
bart jefferson bart jefferson is offline
Mein Auto: 2014 X5
Aloha, friends -
The gear # indicator is flashing, now when in A or S. It used to be on solid. Did I break something? The hood is closed but I noticed it flashing after the hood was opened for an oil check.
Old 07-28-2005, 01:03 PM
Ajax's Avatar
Ajax Ajax is offline
Hydrocarbon Man
Mein Auto: 991 GT3
Originally Posted by bart jefferson
Aloha, friends -
Sometimes that sensor sticks. Try opening and closing the hood again. It's happened to me....
Old 07-28-2005, 04:29 PM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
Hood is not fully shut.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 07-28-2005, 08:57 PM
Mein Auto: 2014 X5
Thanks, Ajax -
The switch was loose! You nailed it. Right On.
Old 07-24-2006, 05:09 AM
BMW540ISPORT BMW540ISPORT is offline
Mein Auto: 540i Sport
Flashing GEar light
This has just happend to my car, where is the hood switch guys, and did this work for you when you opened and closed the hood again.
Old 07-24-2006, 11:46 AM
Ajax's Avatar
Hydrocarbon Man
Mein Auto: 991 GT3
I don't know where the actual switch itself is...just opening it and shutting it once worked for me. Rinse and repeat as necessary.
Old 07-24-2006, 12:04 PM
bren's Avatar
bren bren is offline
///Mpty pockets
Mein Auto: wankermatic
It's a black plunger switch next to the '+' battery jump start terminal on the passenger side rear of the engine bay.
Old 02-27-2008, 02:17 AM
M3ZAK M3ZAK is offline
Send a message via MSN to M3ZAK
Mein Auto: BMW M3 e46 2002model
Mine just started doing it too! After taking it to BMW for a service of course (typical). I really thoght it had something to do with some sort of sensor or gear failing in the transmission, lucky! I love the SMG!
Old 01-11-2009, 08:01 AM
pete1199 pete1199 is offline
Mein Auto: 2004 M3
I just had to replace the hood on my '04 M3 after hitting a deer and now my gear # indicator will not stop flashing and it will even kick me out of gear and into neutral sometimes. I have tried opening and closing the hood numerous times and pressing the plunger switch but to no avail. Any other ideas?
Old 01-14-2009, 09:50 AM
///MMM ///MMM is offline
you are a long time dead
Mein Auto: 2004 M3 SMG vert
this sounds like the switch and the hood are not aligned....take it back to the shop that installed the hood and get the switch and hood to be in the correct relationship..good luck..
Old 01-17-2009, 04:58 AM
Jim in Oregon Jim in Oregon is offline
Mein Auto: 2009 E92 M3 Coupe
The hood sensors for the SMG flashing are in the holes where the hood pins go into. There are two of them.If you look inside the holes you'll see the switches. Those two pins have to make contact with the sensors or you'll get the flashing numbers or not allowed into gear.
Old 01-29-2009, 06:28 PM
AussieM3 AussieM3 is offline
Mein Auto: 2002 M3
Talking Thanks All!!!
Thanks to all for the replies. I just picked my '02 M3 last Friday. It had a registration check this morning at a local mechanic and when I was driving home the gear indicator was permanently flashing. Only having had the car a week my blood pressure went up immediately thinking of expensive SMG repairs. Soon as I got home I googled "M3 smg flashing gear' and hit this thread straight up. To clarify, the fix (in my situaton anyway) was the hood sensors inside the holes where the hood pins seat on closure. I sprayed some WD40 (lubricant) on the sensors and adjusted one of them that looked a bit askew. All fine now. Thanks again. Saved me the hassle of a trip to the BMW Dealership and the anxiety in between!!
Old 08-11-2013, 03:03 PM
smokefast smokefast is offline
Mein Auto: e46 m3 midnight blue
Talking enough of this hood thing
I got a sweet midnight blue m3 with the smg gearbox a camaro pulls up on me we have a go and when im done the gear indicator starts flashing it had happened once so no big deal get home slam the hood like hulk and still ther blinking after some research I figured it was the pins on the hood moved them around and nothing but here is the solution.......take a flathead screwdriver and were the pins go in put it in and lift the tabs inside the hole them take a sand paper and clean off the tips of the pins and presto no more need to slam the beautiful hood anymore problem solved for good good luck with your little flashing light
Old 10-06-2013, 01:32 AM
Mersh Mersh is offline
Mein Auto: Bmw m3
Smile
First post, but had this problem on my 04 m3, i read these posts and went out and tried a spray of wd40 on the pins and cleaned the sensors and hey presto no more flashing lights. This forum is pretty cool.....
Old 12-08-2013, 02:59 AM
ziyaad ziyaad is offline
Send a message via ICQ to ziyaad
Mein Auto: M3 E46
smg flashing gearbox
Hi guys I just joined this forum. Amazing its great to see guys helping eachother. I can't seem to find the pins to clean out this flashing gearbox and is it ok to drive the car with the gearbox flashing??
Old 01-03-2014, 06:55 PM
noorcaliii noorcaliii is offline
Mein Auto: 2003 E46 M3
This happened to my 03 M3! My door wasn't closed! Lol something so small!
Similar Threads
z4 3.0 smg review Josh (PA) E85 / E86 Z4 (2003-2008) 14 04-25-2006 07:07 PM
H/K Traffic Pro Review - The Real Review Jim E. E36/7 Z3 (1996-2002) 331 08-17-2004 07:14 AM
SMG vs. Standard Manual for auto-x Andy Motorsports, Racing & Track 49 06-27-2004 03:10 AM
