E46 (1999 - 2006)
Old 10-02-2013, 12:05 PM
halltristan's Avatar
halltristan halltristan is offline
Bimmer Enthusiast
Mein Auto: 325i and X3
How much time needed for this project?
Next week I plan to do the following:
VCG replacement
Rebuild Vanos
OFHG
Vanos Oil Pipe from OFHG to Vanos
New belts
New pulleys (if needed)
I'm thinking about doing the CCV as well so I'm curious to know the time difference with or without it.
Member No. 470379
Old 10-02-2013, 12:20 PM
mlukas161's Avatar
mlukas161 mlukas161 is offline
Mein Auto: 03 330i, 04 X3
I'd say 8-10 hours not including the Vanos seals. Many of the belts and pulleys have to come off anyway. Also, as mentioned, now's the time to do the CVV if you're concerned about it.
Clean your ICV while your in there too.
Old 10-02-2013, 12:23 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
VCG replacement
Rebuild Vanos
OFHG
New belts
I'm thinking about doing the CCV as well so I'm curious to know how the time difference with or without it.
Don`t be so concerned about the relatively small extra amount of time, now would be ideal, while you have everything apart. You won`t have to mess with it again for a long time, and you`ll be a BIG step further down the road....
The road goes ever onward....
(R.I.P. Jever)
Old 10-02-2013, 12:27 PM
ahull's Avatar
ahull ahull is offline
Agree with all above - well, I think you can do the vanos seals and CCV plus all the other in 10 hours. CCV is probably 3 of that (half of which is removing intake, DISA, ICV and TB, part of which you have to do for the OFHG anyway and that gives you more room for the CCV job). Vanos seals only take maybe an hour once you've removed the vanos, which only takes about 15 mins after the VC is off. You're saving some time by doing the CCV too. Just make sure you keep track of and plug all the connectors back in or we'll razz you when you come back with a "where does this connector go" thread. Good luck!
Watch the bavauto video on the CCV. You'll be glad you did - especially on putting the new one in with the s-hose.
2003 330i TiAg Sport Pkg ~95k miles
DIY MODS: AA Stage I supercharger, Meyle HD FCAs w Powerflex CABs, Bilstein shocks, Meyle HD Rtabs, Angel Eyes, Clear Corners/Markers w/ LEDs, LED tails, ZHP rims, Akebono pads, AUX input
DIY E46 Merit Badges: Sunroof resurrection, CCV, OFHG, VCG w/ VANOS seals, DISA, Cooling Refresh I, steering giubo, window regs, Magnetic Infandibulator (see wiki)
DIY On deck: Rear Diff bushing. UUC SSK, clutch job eventually, Wavetrac LSD
Old 10-02-2013, 12:47 PM
Bimmer Enthusiast
Its funny how a $6 job has turned into $600. At first I was only planning to do the OFHG but that led to the discovery of a small leak from the VCG. Of course that leads to the vanos rebuild... and since I have to do that, well why not the pulleys/belts too. And while everything else is out of the engine compartment, I might as well go ahead and do the CCV.
Absolutely crazy. Watch the DISA need replacing. I already expect it.
Might as well take a shovel, dig everything out and just put new stuff back in.
Member No. 470379
Old 10-02-2013, 12:53 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Re: How much time needed for this project?
3.5 hours
Sent from my HTC One X using BimmerApp mobile app
Old 10-02-2013, 01:16 PM
Bimmer Enthusiast
Why does the OFHG being removed make the CCV easier to do? From all the videos I've seen, it looks like the alternator removed would give most of the extra room needed.
Member No. 470379
Old 10-02-2013, 01:29 PM
mlukas161's Avatar
IIRC You have to remove the alternator to get to the Oil Filter Housing.
Old 10-02-2013, 01:33 PM
Bimmer Enthusiast
That's my point. I don't really see how the OFH is really in the way.
Member No. 470379
Old 10-02-2013, 01:34 PM
OfTheLost's Avatar
OfTheLost OfTheLost is offline
Mein Auto: 2000 328i
Truth.
Old 10-02-2013, 01:47 PM
jvr826's Avatar
jvr826 jvr826 is offline
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
Originally Posted by smolck View Post
3.5 hours
Timelapse video or it didn't happen.
Jeff R.
Old 10-02-2013, 02:07 PM
mlukas161's Avatar
You don't need to remove the OFH to change the CVV... but it makes it much easier from what I'm told.
The alternator needs to be removed to get the OFH out.
Old 10-02-2013, 03:03 PM
smolck's Avatar
ROLL TIDE!
Wish I could. What I can tell you is a week or so ago I redid my VANOS seals and I started at 5:15pm and was done before 6:30pm. I've gotten pretty good at the valve cover stuff.
Old 10-02-2013, 05:48 PM
Fast Bob's Avatar
Keeping it surreal
I have a suspicion that just from sheer repetition, Smolck`s normal pace for this job looks like time-lapse photography to the rest of us mere mortals....
(R.I.P. Jever)
Old 10-06-2013, 01:57 PM
terry740 terry740 is offline
Mein Auto: 1994 740il
might as well
throw in an alternator while you're at it (depending on your mileage) lol
