Old 01-18-2013, 08:08 PM
loso81 loso81 is offline
Mein Auto: 335i
Extended warranty package
i can't exactly remember on this forum where i read it but someone posted a thread about they went to a different bmw dealer and got a cheaper extended warranty package? Is that really possible to do? and IF so, does anyone know the names of any?
Old 01-18-2013, 08:19 PM
jaytank jaytank is offline
Mein Auto: 328i Convertible
I just PM'd you the details..
Old 01-19-2013, 03:19 PM
shakatak shakatak is offline
Mein Auto: 2009 E93 335i HTC
warranty info
Hello
Please PM me with the warranty info.
Thank you
Old 01-19-2013, 04:09 PM
Hey shakatak,
Just PM'd you the info. - good luck
Old 01-19-2013, 07:43 PM
Got PM
Jaytank
Thanks for the info.
Shak
Old 01-19-2013, 07:51 PM
billeul billeul is offline
Mein Auto: 2009 335i MT
Extended Warranty
Since I don't know what you were pm'd, thought I'd let you and everyone else who is interested know that Pacific BMW sells OEM BMW extended warranties at a couple hundred over cost for online customers. I paid $650 under MSRP for my extended warranty. Hope I am allowed to provide that info without pm'ing it. I have no affiliation with Pacific BMW.
Old 01-19-2013, 09:36 PM
Originally Posted by shakatak View Post
Jaytank
Shak
Sure no worries man..
Old 01-19-2013, 09:38 PM
Oh well just passed on the info. - who to contact and from whom I got the warranty for how much. I tried Pacific BMW but Carchex offered lower rates but then again it depends on who you talk to
Old 01-20-2013, 07:16 AM
I found my old post from another forum that provides a little more info. See below.
"Contact Daniel Dutton at Pacific BMW. He sells OEM BMW extended warranties at a discounted price. Since I am retired and don't put the miles on my car, I bought the 7YR/70K platinum for my 2009 335i coupe with 28,000 miles. I am covered until April of 2016. I went with the platinum version to cover my premium package electronics. I Paid $2850. The BMW list price is $3500. Other YR/M combinations were discounted similarly. As a side note, I picked up on an 18 month 0% interest credit card to pay for the warranty. Makes it easy, I am paying $160 a month for the extended warranty."
Old 01-20-2013, 07:29 AM
Yep, that's the guy I spoke with but he said he won't be able to match the quote I had from Carchex. I think these just depend on person you talk to and their margins for that month..
Old 01-20-2013, 07:58 AM
Interesting. Is Carchex quoting BMW OEM extended warranty? If not, that might explain it. I wanted to go BMW OEM. May not be necessary, but that is what I wanted.
Old 01-20-2013, 08:07 AM
That's what I think I have but you're right it could differ a bit. Here is what is covered in my extended warranty.
Components Tech Choice Ultimate
Seals and Gaskets yes
Wear and Tear yes
GPS/Navigation optional - yes
Engine Tech Choice Ultimate
Engine Block yes
All Engine Internals yes
Engine Cylinder Heads yes
Engine Dip Stick and Filler tube yes
Engine Mounts and Torque Strut yes
Flywheel yes
All Pulleys yes
Intake Manifold yes
Exhaust Manifold yes
Timing Belt yes
Piston Pins yes
Valve Guides and Seats yes
Harmonic Balancer yes
Engine Sensors yes
Timing Chain Tensioner yes
Valve Springs yes
Vacuum Pump yes
Air Cleaner Housing yes
Push Rods yes
Hydraulic and Solid Lifters yes
Timing Gears yes
Oil Pump yes
Piston Rings yes
Thermostatically Controlled Air Intake yes
Distributor Shaft and Housing yes
Transmission Tech Choice Ultimate
External Transmission Controllers yes
External Solenoids yes
External Transmission Linkages yes
Dip Stick and Filler Tube yes
Transmission Mounts yes
Transmission All Internals yes
Vacuum Modulator yes
Drive Axle Tech Choice Ultimate
All Internals yes
Spider Gears yes
Drive Axle Yokes yes
Center Support Bearings yes
4 Wheel Drive Locking Hubs yes
Universal Joints yes
Drive Axle Shafts yes
CV Joints yes
Locking Rings and Retainers yes
Electrical Tech Choice Ultimate
Distributor yes
Gauges yes
All Electric Motors yes
Relays, Pumps, Solenoids yes
Speed Sensors yes
Wiring Harnesses yes
Coil Pack, Ignition Coil, Electronic Ignition Coil yes
Wheel Sensors yes
Ignition Lock Cylinder and Ignition Switch yes
Instrument Panel Printed Circuit yes
Voltage Regulator yes
Electronic Level Control Compressors yes
Pneumatic Suspension Pumps yes
Moisture Control Sensors yes
Keyless Entry System yes
Factory Installed Anti Theft System yes
Power Seat Motors yes
Power Sun Roof Motors yes
Convertible Top Motors yes
Computerized Timing Controllers yes
Electric Driver Information Displays yes
Turn Signal Switch yes
Ignition Module yes
Factory Installed Thermometer yes
Factory Installed Compasses yes
Fuel Sending Unit yes
Anti Detonation Sensors yes
Cruise Control Components yes
All Manually Operated Switches yes
Power Door Locks yes
Electric Window Defrosters yes
Electronic Spark Controllers yes
Brake Switch yes
Hazard Switch yes
Horns and Horn Buttons yes
Head Lamp Switch yes
Oxygen Sensor yes
Suspension Tech Choice Ultimate
Steering Knuckles yes
King Pins and Bushings yes
Spindles and Spindle Supports yes
Leaf Springs yes
Wheel Bearings yes
Ball Joints yes
Control Arm Shafts and Bushings yes
Strut Bar and Bushings yes
MacPherson Struts and Mounts yes
Torsion Bars yes
Coil Springs yes
Radius Bar and Bushings yes
Stabilizer Bar and Bushing yes
Spring Shackles and Shackle bushings yes
Control Arms yes
Steering Tech Choice Ultimate
Tie Rods yes
Tie Rod Ends yes
Power Steering Cooler Lines yes
Main and Intermediate Shafts yes
Steering Couplings yes
Power Steering Cooler yes
Pitman Arm yes
Idler Arm yes
Link and Control Valves yes
Pivot Joints yes
Drag Link yes
Power Cylinder Assembly yes
Power Steering Control Valve yes
Air Conditioning Tech Choice Ultimate
AC Condenser yes
AC Compressor Clutch Coils and Pulleys yes
Evaporator Core yes
The Accumulator yes
Serpentine Belt Tensioner yes
Idler Pulley and Bearing yes
AC Ducts and Outlet Hoses yes
AC Compressor Internals yes
Expansion Valve yes
Hi/Low Cut off Switch yes
POA Valve yes
Temperature Control Programmer yes
AC Power Module yes
Blower Motor yes
Orifice Tube yes
HI/LOW pressure lines yes
Receiver/Dryer yes
Brakes Tech Choice Ultimate
Drum Brake Wheel Cylinders yes
Disc Brake Calipers yes
Combination Valve (Proportioning Valve) yes
Brake Hardware (springs, retainers, clips, self activators yes
Self Adjusters yes
Parking Brake Linkages yes
Vacuum Assist Booster yes
Brake Lines and Hardware yes
Power Assist Booster yes
Backing Plate yes
ABS Components yes
ABS Master Cylinders yes
Cooling System Tech Choice Ultimate
Heater Core yes
Thermostat yes
Radiator yes
Coolant Sensors yes
Heater Control Valve yes
Coolant Fan yes
Fuel Delivery Tech Choice Ultimate
Fuel Tank yes
Fuel Pressure Regulator yes
Fuel Injection Metering Pump yes
Fuel Rail yes
Sensors yes
Fuel Injection Pulsators yes
Fuel Distributors yes
IAC Motor yes
Fuel Lines yes
Emissions Tech Choice Ultimate
Air Control Valve yes
Air Idle Vaccum Valve yes
Air Supply Valve, hose and tube yes
Air Check valve assembly yes
Barometric Pressure Sensor yes
ECC relay assembly yes
EGR control valve yes
EGR pressure sensor yes
EGR regulator yes
EGR valve adapter yes
Idler Air Control Valve yes
Vacuum Restrictor yes
Old 02-21-2013, 02:50 PM
Mein Auto: 335i
with the carcheck warranty can you take the car to a bmw dealership to have work done to it or it has to be a specific mechanic?
Old 02-21-2013, 03:45 PM
BMW or any certified BMW dealer
Old 06-04-2013, 09:29 PM
cane714 cane714 is offline
Mein Auto: 2010 328i Coupe
I can confirm once again like many others on the forum that I got the best deal after shopping around and making many phone calls that Daniel Dutton at Pacific BMW in glendale, CA offers the best no nonsense service and pricing for the BMW OEM extended warranties. I got a price which was at least $1000 less than the next best quote after trying at least 15 dealerships and I was in and out of the dealership in minutes. I rarely take the time to write a review of a purchasing experience, but wanted to share to help anyone on the forum shopping around for an extended warranty. It was cheaper than a similar safeguard aftermarket warranty as well.
Old 06-05-2013, 10:40 AM
3two8iguy's Avatar
3two8iguy 3two8iguy is offline
Mein Auto: 2011 E90 328i sedan
Ok,The secrets out,Pacific BMW...Anyone know of a deal I can get on the eastcoast as far as extended warranty,In NY I get my car serviced at BMW in Huntington long Island,never Bayshore again, and in NC I get it serviced at Leith BMW,my warranty is still active but I would like to know anything that could help me save some greenbacks,thanks.
Life is a Journey,Enjoy your ride.
Old 06-05-2013, 01:24 PM
unrealii unrealii is offline
Mein Auto: 2009 335 6MT 'vert
Pacific can probably sell to you too. I think they just need a key read.
2009 335i 6MT M-Sport AW/CR Convertible
2002 Toyota 4Runner 4wd
Old 06-05-2013, 02:01 PM
You can either send Daniel your 2nd FOB or have your dealer read the key and send send Daniel the printout. Give Daniel a call. He will tell what he needs. He has special online prices for OEM warranties. Doesn't matter where you live.
Old 06-06-2013, 06:26 AM
3two8iguy's Avatar
Thankyou
Old 06-06-2013, 07:25 AM
fb88 fb88 is offline
Mein Auto: 2014 X1 xDrive28i
If you bought this prior to 4 yr/50k miles what happens to the extended warranty if the car is totaled? Do you lose it?
Old 06-06-2013, 09:32 AM
Re: Extended warranty package
Check your contract terms. Some policies allow for cancellation with a prorated refund.
Sent from my HTC VLE_U using BimmerApp mobile app
Old 10-07-2013, 06:30 AM
Mein Auto: 335i
have you needed to take you car to the dealer for any reason in reference to using your carchex extended warranty? If so, what is the initial process, and will they pay to provide you with a loaner car from bmw??????
