Old 10-06-2013, 09:04 AM
halltristan's Avatar
Bimmer Enthusiast
Mein Auto: 325i and X3
How can I clean the Fan clutch
Pretty dirty. How do I clean it? What can I safely use?
Member No. 470379
Old 10-06-2013, 09:12 AM
RivMcLean RivMcLean is offline
Retired USAF MSgt
Send a message via MSN to RivMcLean
Mein Auto: 2004 330Ci, 87 Toyota PU
Be careful with the fan itself as it is pretty delicate, examine it for nicks and cracks, they will fly apart taking other components with it. I used 409 to clean the fan and I used a dry parts brush to loosen the dirt on the clutch itself. Mine was leaking so I just ended up replacing it.
RivMcLean
2004 330Ci
1987 Toyota Pickup
Moreno Valley, CA
Old 10-06-2013, 09:15 AM
Bimmer Enthusiast
Can it get wet?
Member No. 470379
Old 10-06-2013, 09:19 AM
Bimmer Enthusiast
Also the nut on the clutch is pretty tight. It has resistance when I turn it. Is that normal?
Member No. 470379
Old 10-06-2013, 09:39 AM
Retired USAF MSgt
You could hose it off I guess, but I wouldn't soak it. I have a compressor to blow it off dry when done. Resistance is normal, as the engine warms up the fluid in the clutch warms up as well and spins more freely using airflow for cooling.
RivMcLean
2004 330Ci
1987 Toyota Pickup
Moreno Valley, CA
Old 10-07-2013, 08:10 AM
Scott ZHP's Avatar
We want the Lion!
If it's covered in grunge, I cant help but wonder if its leaking.
Old 10-07-2013, 10:10 AM
charlesberry's Avatar
charlesberry charlesberry is offline
Mein Auto: E46 944 Turbo
I've used Simple Green - which didn't do much, and went on to brake cleaner - which worked pretty well.
Old 10-08-2013, 06:07 AM
G. P. Burdell's Avatar
G. P. Burdell G. P. Burdell is offline
Rambling Wreck
Mein Auto: E46
This. My car's original fan clutch was just as grungy, and barely engaging at all, after about five or six years of service. I replaced it along with the plastic fan blade.
Old 10-08-2013, 06:51 AM
Bimmer Enthusiast
I'm not sold on it leaking just yet. It runs fine. But what could all the crud be? Road dust?
Member No. 470379
Old 10-08-2013, 08:08 AM
Rambling Wreck
Mein Auto: E46
I think it's road crud stuck to a thin film of viscous fluid from inside the fan clutch.
