Old 10-07-2013, 06:22 AM
nsrad nsrad is offline
Mein Auto: 328i
Aluminum dash kit for 328i
Hi,
I have the wood trim dash on my 2009 328i but want to switch to the aluminum trim. Does anybody know what is the best way to do this with a budget under $500?
Old 10-07-2013, 06:35 AM
Zooks527's Avatar
Zooks527 Zooks527 is online now
Winding up the M235xi
Mein Auto: 2015 M235xi / 2005 Tacoma
For that budget, find someone who wants to trade. Not the easiest task, but potentially doable.
Or, I suppose, offer to swap out the trim with a salvage yard that may have an appropriate car in house. Use some of your $500 budget to make the trade come off with the yard.
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/ BimmerTech amp, Enh. BT
Ordered 3/12/15, Off the line 4/7/15, Delivered 5/14/15
Prior 40 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette / 1981 Subaru GL wagon 4WD / 1983 s10 Blazer 4x4 / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion / 2009 BMW 335i xDrive E92
Old 10-07-2013, 11:36 AM
bladerunner123 bladerunner123 is offline
Mein Auto: 328i
If your ever in the chicago area i would be willing to swap my aluminum for wood trim. assuming it would work on my 2011 with idrive. just not willing to risk swapping in the mail only to be disappointed
Old 10-07-2013, 02:33 PM
fdriller9 fdriller9 is offline
Mein Auto: '06 AW 330xi
You can find someone to wrap your trim. I did mine in brushed graphite. 3M makes a brushed aluminum too. Not identical to the OEM trim but similar. You can expect to pay around $250 for a professional interior wrap.
You can also try wrapping it yourself. Just google 3M 1080 scotchprint vinyl.
I normally use Fellers but you need to open a wholesale account.
Autovinylsolutions.com is ok too
| LCI Msport Conversion | Exotic Tuning Front Lip | H&R Coilovers | M3 Subframe Bushings | Custom Polyurethane Shore A90 Tension Strut Bushings | E93 M3 23.6mm Rear Sway Bar | UUC Front Sway Bar | Custom Heim Joint Rear Control Arms | Apex ARC-8 | Dunlop Direzza ZII Star Spec | Modified Dinan Cold Air Intake | aFe Oiled Drop-in Filter | Custom Hand-Made LED Angel Eyes | Alpine MRP-M500 | Custom LED Reverse Lights | OEM Blacklines | BMW Performance Trunk Spoiler |
Old 10-07-2013, 06:22 PM
Mein Auto: 328i
I don't have idrive so they wouldn't match anyways. Also I have heard that when you take the kit out the plastic which holds it in breaks most of the time so it becomes unusable. I am not sure if that is actually the case, but its what a friend told me. If it does break it would rule out the possibility of doing any kind of a trade.
Old 10-07-2013, 06:27 PM
Mein Auto: 328i
Wow your interior looks great. From the picture I would argue the brushed graphite looks better than the brushed aluminum. Did you get it professionally installed? was the price $250 including labor and material? Also did you change the trim on the doors as well?
Old 10-07-2013, 06:29 PM
Mein Auto: 328i
I actually found someone to trade with but now I am afraid once the kits are taken out they might be unusable due to damage.
Old 10-08-2013, 11:46 AM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
Try wreckers yards
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
Old 10-08-2013, 11:57 AM
Zooks527's Avatar
Well, that's your call. I've popped all of my dash trim off for one reason or another over the past few years with no problems. I will confess to not pulling the center console, nor do I have any desire to do so.
Old 10-09-2013, 06:49 AM
Thanks. All the interior trim peices are wrapped...center console, door trim, even the rear center console.
I wrap in the side and provide this service so I wrapped it myself. Material cost is about $80. But it takes me about 5 hours to wrap all the peices for e9x interiors.
The trim is held in by plastic/metal friction clips and metal prongs. The trim is stubborn to remove in some areas, but you have a slim chance of damaging anything. Even if one of the clips break, they can be purchased at the dealer for under $1.
Old 10-09-2013, 01:07 PM
Mein Auto: 328i
Thanks for the reply. Just wondering, if you decide to remove the wrap later will the wood trim be damaged?
Old 10-09-2013, 01:21 PM
Nope. Besides some left over adhesive, the vinyl comes off cleanly, without damage to the original finish. It can actually double as a protective film.
Some rubbing alcohol or goo gone, etc will remove the left over adhesive right away.
Old 10-09-2013, 01:39 PM
Ilovemycar Ilovemycar is offline
wooohooo
Mein Auto: '08 335i coupe 6MT sport
I've taken out trim pieces from both door and dash, it seems quite easy. Center console, I've never touched. My trim removal tool kit was about $5 for a nice variety of shapes, they come in handy more than I expected. Also, the wood trim has a very thick coating on it, it is very durable, you can even machine polish it like you would car paint if you needed to. Brushed aluminum is delicate. I use some Klasse AIO every once in a long while to clean it up pretty good, and sometimes I'll even use polish too.
There was a nice pictorial here some time ago... here ya go...
http://www.bimmerfest.com/forums/sho...470&highlight=
