Old 10-12-2013, 10:16 AM
07 E63650i's Avatar
07 E63650i 07 E63650i is offline
Freude am Fahren
Mein Auto: BMW E63 650i
Power Steering Fluid Flush?
I saw a nice thread written up by roseng last year and I plan to do this sometime in December when the school quarter is over. My question is how many quarts or liters of power steering fluid does the dynamic drive/power steering hold?
Once a 6'er, always a 6'er.
Old 10-12-2013, 02:21 PM
roseng's Avatar
roseng roseng is offline
Hi 07 E63650i,
I forgot I wrote that one up.
http://www.bimmerfest.com/forums/sho...light=pentosin
3 changes over 2 weeks and it looked like new oil after a week of driving. Total cost about $70.00.
I bought the Pentosin at NAPA. They had it in stock locally too.
Old 10-12-2013, 03:14 PM
Mein Auto: 4 BMWs, 1 Jeep, 1 Vespa
Wish I had remembered that post. Indy charged me $220 for the flush. Only question is where did you take the old fluid for recycling? Most places only take engine oil which is one of the reasons I stopped doing most fluid changes myself and just have it done.
Old 10-12-2013, 03:21 PM
roseng's Avatar
I put in the new cans and my town has recycling days and they will take paint and oil products.
Old 10-12-2013, 06:16 PM
07 E63650i's Avatar
Freude am Fahren
Originally Posted by roseng View Post
Hi 07 E63650i,
Thanks Gary. I figured that buying about three liters for flushing is way cheaper than an Indy.
Old 10-12-2013, 08:11 PM
HerbP HerbP is offline
It would be a good time to inspect the bottom of the reservoir for leaks. The hoses tend to get brittle on the bottom connection of the reservoir, & start to weep oil. You can cut the hose for a tighter fit, & replace the factory hose clamp as a preventative measure. The 3 cans of fluid should be plenty to do the flush. A turkey baster works great for removing the fluid.
Good Luck!
Old 10-12-2013, 11:11 PM
07 E63650i's Avatar
Freude am Fahren
Good Luck!
Good looking out Herb. Will do this when that time comes around. Thanks again!
Old 10-13-2013, 03:06 AM
mfelsoci mfelsoci is offline
Mein Auto: 2004 645ci
Chf 11s
I just flushed mine and purchased the Pentosin CHF 11S at my Local NAPA. It was $21.00 a quart. Napa was the only place in north east ohio I could purchase it besides the dealership.
CURRENT:
BMW 323i
BMW 645ci
Lexus SC 300
Ford F150
Dodge Ram
Old 10-13-2013, 05:28 AM
Mulchman's Avatar
Mulchman Mulchman is offline
Mein Auto: '07 650i
Not to be repetitive....but I just posted this thought I'd copy it here. Pep Boys near me also started carrying 11S fluid as well.
BTW - The reservoir is also the filter for the system. I did a flush or two and the fluid looked better but not clean. Next time anyone does this I suggest also replacing the filter/reservoir. Once I did this the fluid looked clear and green even now months later.
http://www.realoem.com/bmw/showparts...33&hg=32&fg=20
This says $84 but I don't think I paid that much. The other nice thing is you really get a good drain on the system. It's a little more work but worth it. I did the coolant reservoir at the same time since it is right there.
M6 bumpers, skirts & wheels
HUD, Comfort Access
Old 10-13-2013, 07:49 PM
I agree with Mulchman. I replaced my reservoir while searching for my Dynamic Drive problem. This was the only way I could eliminate the filter being clogged causing my problem. I think I purchased it for around 56.00. The cost for the reservoir is cheap, to help eliminate problems down the road!
Good Luck!
Old 10-13-2013, 11:35 PM
07 E63650i's Avatar
Freude am Fahren
Thanks for chiming in guys. I'll be sure to write up a nice DIY when the time comes around.
Old 10-14-2013, 02:16 AM
ttuite ttuite is offline
Mein Auto: 650I cabrio
Is there a service interval for the replacement of the Hydraulic fluid?
Old 10-14-2013, 03:39 AM
Mulchman's Avatar
Mein Auto: '07 650i
Tom, the Bavauto schedule says 2yr/50k.
HUD, Comfort Access
Old 10-14-2013, 03:46 AM
Thanks MM I guess I better change it as my 06 has 45K.
Tom
