540i Engine Knock sound only when warmed up? - Bimmerfest - BMW Forums
Old 10-19-2013, 05:48 PM
ashtray ashtray is offline
As seen on the Internet
Mein Auto: 540iT Dinan
I'm new to this car, but when you first start up the engine cold, it idles smooth. Drives very smoothly. No issues. When you reach normal operating temperature, you hear a faint knocking - which you hear more when idling than while driving but only bc engine and road noise drown out the sound.
I stopped and took a video. The supercharger sound drowns out the knock from the passenger side, but sticking the mic down the driver's side you can hear the noise clearly (about halfway in video).
The noise can be heard from inside the car but you need to turn up your computer speakers.
Thoughts on what could be the source? Again - idles quiet when cold, noise only comes when engine is warm. No performance issues. Drives fine. It's just a noise at this point.
2000 540iT Sport Dinan: Supercharged, modified, 3.45 LSD, Stage2 Suspension, M5 18's, M5 brakes, and a bunch more.
Old 10-19-2013, 07:10 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Possible VANOS noise. Go here and browse the forum. www.beisansystems.com
BTW, whenever you wish us to help you, please mention the miles on the car, and the build date.
We are not clairvoyant.
Old 10-19-2013, 07:31 PM
Thanks. Build date in my signature - 2000. Mileage at 122k, as shown in video.
VANOS seals done at some point in the past few years - will have to check records.
Old 10-19-2013, 07:37 PM
No, build date is a month/year expression, as noted on the door jamb sticker. Sometimes, things change during a model year run, and it may help us to know.
VANOS seals have not been available for the V8 until the last couple of years. You need to examine the records to verify. If it was a dealer VANOS ASSEMBLY replacement, the same crappy seals were used in these units, not the improved Beisan seals.
Read up on this: http://www.beisansystems.com/procedu..._procedure.htm
Old 10-19-2013, 10:29 PM
Ah - ok, didnt realize mid year changes. Will check door jamb and records and post more details.
From the video, does it sound like a VANOS noise? Would it be not present until the engine is warm though?
Old 10-20-2013, 05:17 AM
JimLev JimLev is offline
When the engine is warmed up the oil pressure drops to ~10 PSI at idle, from 50+ when it's at cold idle.
When these cars were under warranty BMW said that this was not a problem and won't effect its operation. If the owner complained enough they would change the rod bearings.
You could try a thicker oil, maybe give so 20w/50 a try. What are you using now?
