1999 528i EML light, Cranks but not starting - Bimmerfest - BMW Forums
Old 10-20-2013, 07:59 AM
manzoorz5001 manzoorz5001 is offline
Mein Auto: 1999 BMW 528i
I had a broken vacuum hose (from the dip stick to the CCV). had a mechanic put the hose in. After replacing the hose, the car isn't starting but cranks. I have checked the following things so far:
1- Spark--OK
2- Fuel Pump/Lines -OK
3-Battery-OK
I scanned the car and get the following code(s):
170-AA Control-Unit Self-Test, Internal Fault, Throttle Body.
Old 10-20-2013, 09:51 AM
johnstern's Avatar
johnstern johnstern is offline
Mein Auto: 2000 BMW 528iT/5, S/C
An EML light usually is for a throttle body problem and that's exactly what the code says. You can try cleaning it but you'll probably have to replace it. I'd also inspect the Bowden cable and clean the connector.
Old 10-20-2013, 12:50 PM
The cable is intact. I try replacing the throttle body.
thanks
Old 10-21-2013, 12:58 PM
whats the best way to clean the throttle body and the electrical connector.
Old 10-21-2013, 09:06 PM
johnstern's Avatar
Electrical spray and carb cleaner.
eml light, mdk, no start, throttle body
