Old 10-02-2013, 10:25 PM
shinnes shinnes is offline
Mein Auto: 2002 BMW 525i
2002 5251: oil leak or oil burning?
Greetings fellas,
I have a 2002 525i that has about 180K on it. I have been adding oil at least 1 qt every month. There is some oil spots in the parking lot but I park on a public parking lot and its hard to tell if that oil come from my car or not. But there is a big possibility it did since I usually see oil spots when I pull out in the morning.
Any ideas will help? and what can I do if its an oil leak ?
Old 10-03-2013, 01:47 AM
dannydoo dannydoo is offline
Mein Auto: 540i 6
IF your on a stupid poor budget,get some gasket sealer,drain the oil,take the 14 bolts out,dry it clean both sides with a razor,out gasket sealer on install bolts wait 12 hours,put oil back in and drive
3$ and and about 2hours work
OR buy the real gasket. if the pan is leaking,could be a loose drain bolt.
Old 10-15-2013, 05:41 PM
Old 10-15-2013, 06:54 PM
eparayno's Avatar
eparayno eparayno is offline
Mein Auto: 2001 530i
Put a piece of cardboard under the engine to determine the general location of the drips. You can either fix the leaks or not, those are the only options so I don't know why you're asking what to do if you plan on keeping the car
Old 10-15-2013, 07:55 PM
MAICODOUG MAICODOUG is offline
Mein Auto: 530i
My 530 was leaking and burning, mine a valve cover leak, which was hard to see, except when smoke was coming up out of the cowling when it was turned off. It is normal to burn a minor amount of oil with the inline 6 motors, mine w/ 200kmi at about a quart every 3000 mi (one month for me~)
Old 10-16-2013, 10:42 AM
manticore33's Avatar
manticore33 manticore33 is offline
Send a message via AIM to manticore33
Mein Auto: '86 Porsche 951, '01 530i
M54 engines love oil. Failing CCV or other vacuum issues only make the problem worse. How many miles are on that 1qt loss? 1,000/qt is acceptable.
I like coffee.
My e39 is fixed and moving towards atrophy.
Old 10-20-2013, 04:39 PM
Thanks guys , will do the piece of cardboard test
