Old 11-10-2012, 03:17 PM
Neversaynever Neversaynever is offline
Mein Auto: 2002 525i
2001 525i No Defrost Air
A friend's 2001 E39 with a "dial" for controlling vent, defrost, foot ari flow has lost any air coming through the defrost vents. Dash and heat vents work fine. When the dial is rotated to defrost, the dash and heat vents close but the defrost vents do not open, or at least do not blow air. Can anyone offer an idea on where to start looking? Obviously a fuse would be a thing of beauty. That and other ideas are welcome.
Many thanks.
CL
2002 525i 164k
1988 911 Cabrio
1986 911 Coupe (track car)
Greater Boston, MA
Old 11-10-2012, 03:21 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Sounds like a cable has broken or slipped off. I assume the car has a manual HVAC.
Old 11-11-2012, 07:50 AM
Thanks Ed. Probably right. If manual HVAC means the control in a three position dial and heat control is manual (versus LED), yes, manual. I do believe the defrost redirect is electronic as the dial switch does not have the "feel" of manually operating cables. So, now I need to figure out how to open the dash and center console to debug this.
Any ideas anyone on this?
Thanks. Chris
CL
2002 525i 164k
1988 911 Cabrio
Greater Boston, MA
Old 11-11-2012, 08:33 AM
Fudman's Avatar
Fudman Fudman is offline
Chris:
Your bud has the IHKR panel. We had the IHKA, which used motors to control air distribution. For the IHKR, per the Bentley, it says "Bowden cables attach it to the air distribution flaps in the IHKR housing". Hence, he may have a cable failure or it has disconnected somehow. The instructions for removing the IHKR panel are:
"1. Remove switch panel below IHKR panel
2. Push out IHKR control panel by reaching through switch panel opening
3. Disconnect electrical harness connectors
4. Disconnect Bowden cables from back of panel
CAUTION - Note color coding of Bowden cables. When reinstalling, reattach cables to correct control levers."
However, info on the IHKR housing is not available. Hence, if the problem is not behind the panel, then I can't provide any info on the housing. If you want to talk about this, give me a shout. I'm home most of today. If your bud wants to swing by, we can take a look together.
Old 11-11-2012, 09:01 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Ditto what has been mentioned above. If you have the manual IHKR control unit...then bowden cables are used to actuate the HVAC flaps instead of the electronic stepper motors used on e39s with the IHKA control panel.
If the defrost dial doesn't seem to "feel" manual...then the implication that the bowden cable has become disconnected is even greater:
manually adjusting IHKR control panel
item #10 is the bowden cable...1 each for the defroster, dash, and floor vent flaps
Q {BMW CCA Member #191509}
(SOLD)
Old 11-11-2012, 02:50 PM
Fud and Quick,
You guys are simply tremendous. As Fud knows, my 525 went away and was replaced by a Tacoma truck. There is not a day when I do not miss that E39. Not one. The truck is fine and serves the purpose, but no comparison.
It looks like finding and checking the bowden cable is not beyond my capabilities. I will check out the car and get back to you.
Many thanks.
Chris
CL
2002 525i 164k
1988 911 Cabrio
Greater Boston, MA
Old 08-11-2013, 03:57 PM
wiredawg100 wiredawg100 is offline
Mein Auto: 2001 525i (E-39)
How to properly remove?
Originally Posted by Fudman View Post
Chris:
I need to look behind my switch panel (the 3 knobs temp/vents/blower) to check the bowden cable to the vent control. I would appreciate some instructions or video to do this. I feel like every time I do something like this I break it...
Old 10-20-2013, 07:55 PM
Defrost Not Blowing Air
Since I had no responses regarding the removal to the vent control panel, I venture out and figured it out. To re-iterate the problem, I was basically having the problem as described at the beginning of this thread. I have the manual vent/climate control knobs. My heating and AC is working fine it simply would not come out of the defrost when switched to the defrost position. Pics below...
Name:	Boden cable re-attachment 1.jpg
ID:	403166   Click image for larger version
Name:	Boden cable re-attachment 2.JPG
ID:	403167   Click image for larger version
Name:	Boden cable re-attachment 3.jpg
ID:	403168   Click image for larger version
Name:	Boden cable re-attachment 4.jpg
Old 10-21-2013, 12:55 AM
QSilver7's Avatar
great follow up & resolution. I'm sure some one in the future looking for this info will appreciate it.
(SOLD)
Old 05-26-2014, 06:08 PM
zybanuser zybanuser is offline
Mein Auto: 2000 BMW Z3 2.5
Thanks guys for this thread. Have the same problems for over 4 years now and finally found the culprit and solution to it.
wire, that's some serious demolition lol. Any other way to get to that cable with less hassle?
Many thanks!!!!
Old 05-26-2014, 09:31 PM
Many thanks!!!!
Sorry, I don't think so. I started with just the middle console area. But soon realized, the way all the molding is overlaying, I needed to work back to the glove box just to get the middle console off. One simply needs the space to visually see and physically work the cable.
Old 10-08-2014, 01:29 PM
Pete315 Pete315 is offline
Quick question,on my 2001 525i with the manual heater control, does the knob that controls vent/floor/defrost rotate completely around in circles? I can rotate mine either clockwise or counterclockwise but it gets stuck when it's almost straight up at defrost.in other words, if dial is St the 9:00 position, I can't turn it clockwise to the 3:00 position. The switch does not allow it to lock in the defrost setting. Feels like something is getting hung up.
Old 10-08-2014, 03:44 PM
Hey Pete315, it should rotate freely 360 degrees. as you are rotating it you should feel a little resistance as the vents move into it proper position. If you decide to tackle this annoying problem. There are some rotation type gears on the left side (passenger side) of the console under the dash area. It think you view/access this area by removing the glove box and the side console panel. If nothing is apparent there you will have to remove a bit more see my pics above to properly access the area behind the center console. Keep in mind it some pieces fit together by overlapping vs a puzzle where pieces fit together.
Old 10-08-2014, 06:51 PM
Thanks for the quick reply. All the doors work properly. It's just that something is causing the knob to hang up when it gets near defrost. Great pics you posted.
Old 10-09-2014, 09:43 AM
All fixed. Took 1 minute. I pulled out the heater control assembly and saw that the blue line defrost cable slipped off the piņon the controller. Put back on and now works fine. Thanks for your help.
Old 10-09-2014, 02:24 PM
Glad to hear you fixed it. Just curious, you said "1 minute"..."pulled out the heater control assembly"...can you clarify, what exactly you did using my pics above. Just wondering, if I did not need to remove all that dash-stuff...just-in-case I need to do this again.
Old 10-09-2014, 03:45 PM
The heater control assembly slides right out. I used a plastic picked a pulled it out about 6 inches which was more than enough to see that cable fell off the controller.
Old 10-09-2014, 04:14 PM
Whaaaat...really??? I tried to remove it that way, I but could not find any tabs or access points or it would not move and I was afraid of breaking it. And to clarify the "heater control assembly" would be the label "1" in the above diagram pic...anywho, great info to know...
Old 10-10-2014, 07:26 AM
Yes. It comes right out.
Old 10-12-2014, 11:59 AM
Wire, Pete was right. The IHKA slides right out.
I took the radio panel out first, then pushed the IHKA out from behind. Took 2 minutes thou, and not one
Now i have defrost!! Woohoo!
Thanks!!!
ID:	469544   Click image for larger version
ID:	469545   Click image for larger version
Old 10-14-2014, 08:21 AM
Thanks!!!
I swear I tried this method and mine did not seem to want to budge...LOL Anywho, great to know and thk for the pics..
Old 09-22-2016, 12:18 PM
kgdad2012 kgdad2012 is offline
Mein Auto: 2001 X5
It Worked!
I checked the forum and followed the tips. It totally worked! Wanted to let everyone know the shared knowledge is very much appreciated. Thanks!
Michael
2001 BMW X5
