Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > 6 Series DIY
6 Series DIY
6 Series Do It Yourself (DIY) forum.
Old 10-22-2013, 10:53 AM
sddsys sddsys is offline
Mein Auto: 1984 633Csi
1984 633Csi No Spark
I am a new member, an old guy. I do not profess to be a great mechanic but have always been successful fixing my cars with time patience and some sound advice. My son bought a real nice 633Csi 65k miles that will not start. He is young and impetuous so I have been asked to get it to run while he is away at school. We have the famous power to coil but no spark to distributor. I do have injector pulse. I have checked all the on line advice. I have ruled out the ignition switch, fuses, main relay & coil and all check out OK. I replaced the speed & ref sensors because the plugs were bad and have verified that they are in the right locations. We purchased replacement OBC (old style) and ECM and neither helped. I tried to do the 15 minute countdown with the OBC to check if a security code was entered. When I reconnect the battery and turn the key to pos 1 I get the four dashes and no 15 minute countdown so I assume there is no security code. I hope you guys can help me out I am dead in the water.
Old 10-22-2013, 04:42 PM
Yorgi's Avatar
Yorgi Yorgi is offline
This is the DIY section - for posting instructions on how to fix your car and it does not get much traffic.
I would re-post over here in the E24 section where more owners will see your question.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 10-22-2013, 06:31 PM
Thanks Yorgi I went ahead and reposted it. I see that there are a lot of smart guys on this forum and I cut my teeth on carbs and points so I am still trying to fully understand how the spark is generated. I believe that the ECM (the motronic unit) makes and breaks the ground to create the spark but am having trouble with the wiring diagrams I have available to test the wiring.
