Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > E24 (1976 - 1989)
E24 (1976 - 1989)
The BMW 6 Series (E24) was the first variant of the 6 series produced by BMW from 1976 through 1989.
Old 10-22-2013, 12:27 PM
drseth drseth is offline
Mein Auto: 1998 Z3 2.8, 1987 L6 635C
Noisy Power Steering Pump When Cold
Hi,
I have had this L6 for almost ten years. Two years ago I finally got tired of hearing the power steering pump moan and groan and bought a new PS pump. Installed it, filled it with new fluid, and it groaned about as bad as the one I took off. I did notice the reservoir has a filter, so I changed that, and it quieted down.
Two days ago I got in the car to go to church on a cool fall day, and the moaning and groaning returned. Does anyone have any suggestions on what to do? I did change the fluid in the reservoir, using Mobil One ATF. It did seem to be quieter after the fluid change.
Seth Anderson
1987 BMW 635CSi L6
Old 10-22-2013, 06:57 PM
hornhospital's Avatar
D'oh, You Kids!
Change the filter again?
Quotes to live by:
Old 10-23-2013, 10:01 AM
No, I didn't have a new one on hand, and the filter I had looked a heck of a lot better than what I removed a couple of years ago. I noticed that the filter did not fit inside of the rim of the piece that holds the filter against the bottom of the reservoir, so I flipped it over and put the spring and clips back on.
Guess I probably ought to get a new filter anyway.
