Old 10-18-2013, 04:31 PM
alex800st alex800st is offline
Mein Auto: x5
Rain sensors
Seems like something wrong with the rain sensors - if I put wipers to "A" position, it does not care raining hard or not, giving me a wipe every several seconds regardless.
I have a suspicion that the same sensor senses brightness outside - because my HUD is on the same brightness regardless day or night, and practically invisible daytime.
Am I right? Any way to check that sensor?
Old 10-19-2013, 01:13 AM
jgchoi jgchoi is offline
Mein Auto: 2013 550xi M Sport
Although my rain sensor works just fine but I'm pretty sure that they are different sensors located differently. HUD brightness can be adjusted in the iDrive menu and it, I believe, stays the same no matter what.
Old 10-19-2013, 06:36 AM
Mein Auto: x5
It says "The brightness setting is automatically corrected in order to compensate for different
light conditions. Compensation is based on signals from the rain and light sensor. The
automatic brightness setting is configured in such a way that no HUD brightness jumps
occur."
here - https://drive.google.com/folderview?...VQ1c1dLQ3hYVFE , in the section "Head-up display".
Can you see the HUD on a bright, sunny day? I can't.
Old 10-19-2013, 07:09 AM
blue dragon blue dragon is online now
Mein Auto: X5 35D
Hud gets brighter in bright sunlight, and dimmer at night.
| '09 X5 35D - Work horse | '17 X1 MSport - Wife's daily | '17 - 340i MSport - My daily |
Old 10-19-2013, 11:28 AM
occur."
I should've said, "HUD brightness stays the same to my eyes" and yes, I can always see the HUD but not as clearly on a bright, sunny day (you're already aware of the HUD not working with polarized sunglasses, right?). According to the provided HUD page, you must be right about the sensor being a single unit. My bad.
Old 10-25-2013, 03:35 PM
Mein Auto: x5
update - took the car to the dealership today. it took them 3 hours to fix the issue. I asked - just replace the damn sensor, 2 minutes job. They say - no, we have to follow The Protocol - connect my car to a computer, it will run the diagnostic, we will check wiring, etc etc. In 3 hours they come back and say - yes, the sensor did not work, but we will not replace it - we will "re-initialize" it. Indeed, soon I get the car back and rain sensing started to work.
Good thing - they did not charge me.
Question - what is "re-initialazing" of the sensor means? Anybody?
I was ready to get one off ebay - does it mean it may not work without initializing?
Another question - your HID low beam in "A" setting - is it "On" on a sunny day?
Old 10-25-2013, 03:54 PM
ard ard is offline
Resident Curmudgeon
Well, if they 'fixed' it by 'reinitializing' it, the sensor wasnt 'broken' or 'bad'... possibly the software in the module that receives the sensor input was corrupted?
They talk in shorthand as it takes too much effort to eductae people on what is involved. 99% of people dont care.
Old 10-25-2013, 05:40 PM
boostedX5SAV boostedX5SAV is offline
Mein Auto: 2012 X5 35i
Auto setting for headlights is very sensitive. I have seen on sunny days and the headlight is on.
Old 10-25-2013, 06:06 PM
Penguin Penguin is offline
Mein Auto: Z4 and X5 Diesel
The dealers are between a rock and a hard place on this topic. If they do not follow the protocol that BMW set-up, BMW NA can, and will, deny them warranty reimbursement. BMW NA aggressively audits warranty claims and stick it to the dealer whenever they find a slip-up.
A BMW dealer I know said that BMW found a single slip-up on one battery claim they processed, so BMW then retroactively and automatically denied all of the battery claims the dealer had submitted in the past 12 months.
Old 10-26-2013, 03:45 AM
TinyRK's Avatar
TinyRK TinyRK is offline
Ja mei!
Mein Auto: X5
Indeed.
There are several sensitivity levels and here in the US they're at the highest level of sensitivity.
Can be coded.
BMWCCA Member# 481324
Old 10-27-2013, 06:42 AM
Mein Auto: x5
Interesting fact I did not know - that rain/light sensor is also a solar sensor. It tracks sun in the sky and adjust air distribution to cool down the sunny side.
Another thing I discovered recently - while driving on cruise control and entering the ramp with the speed that is higher that car thinks is safe - cruise control drops the speed and recovers after the cornering is done. That car keeps surprising me.
