Known E34 Upgrades and Common E34 Myths - Page 4 - Bimmerfest - BMW Forums
E34 (1989 - 1995)
Old 09-09-2013, 09:23 AM
Doktor Bert's Avatar
Doktor Bert Doktor Bert is offline
Der Sturm Uberdoktor
Mein Auto: BMW 525i
From my own recent experiences:
I was told that BMW Bore Wash was a myth.
It's a real condition!!!!!
"Herr Doktor will see you now..."
Old 09-14-2013, 04:06 AM
sixpot_simon's Avatar
sixpot_simon sixpot_simon is offline
Mein Auto: E30, E39
while Cold Air Intake Internet Debate #43591 rages , I don't mean to be rude, but there are several points in the stickied OP that I would challenge:
- The point of 540i MAF is not to somehow trick the ECU into thinking there's a V8 under the bonnet to magically increase power. It is simply a bigger (ie less restrictive) MAF. So, for a modified engine which breathes harder, it is a way to remove the bottleneck of the smaller M50 MAF. Check out the r3vlimited threads for more info.
- For the headers, I assume "S50" refers to the US version. According to the part numbers, these are exactly the same headers. Also, for headers which are actually different, performance can actually decrease if the tune isn't tweaked to suit the new breathing. So I think retune/chips should be mentioned in this section.
- Ram Air Intake: aka high beam delete. Performance benefit (unless we're talking a monster S5x engine) is widely regarded as dubious, is there any proof to back up the claim "the most efficient and easy to produce modification"? Also, hydro-locking is serious stuff, I wouldn't be relying on a hacked up stocking to protect my engine...
- Springs/shocks/struts: Some more understanding of suspension basics would be worthwhile, in order to do an overhaul of these sections. Also, Bilstein aren't the only manufacturer of decent E34 sports shocks in the universe. At least Koni should also be mentioned.
- Braided brake lines: There are differing opinions regarding whether stainless lines improve braking performance for a street car. Personally, I suspect the claimed improvements may be simply due to putting in fresh fluids and bleeding the system.
Originally Posted by robertobaggio20 View Post
A contribution : using a fuel pressure regulator meant for the the immediately lower capacity in your engine class (i.e. using a 520s fpr in a 525) will improve fuel economy by 10% or higher without any noticeable fall in low and high end performance.
That is a very ghetto sounding way to make the engine run leaner IMHO. If the closed-loop system is working, it just means the ECU has to compensate for the lower fuel delivery (probably asking for more than the injectors are capable of delivering at that fuel pressure). If closed-loop isn't working, you're just running leaner than BMW intended, therefore risking damage under load.
Originally Posted by jhayregz View Post
man..m20's dont have many options for HP upgrades
Actually, some good news, there's all kinds of upgrades out there for M20s. The M20 might be bottom of the E34 pecking order, but it's only below the M3 in the E30 range. So plenty of people have been tweaking them to squeeze out some extra horses.
Originally Posted by Monsignor View Post
I was being facetious. It would be a ludicrously difficult job seeing as it is a 24V head instead of a 12V. It also has the VANOS system. Timing is different. Exhaust will bolt right up. The VANOS swap would be the most difficult part.
The first M50s were non-vanos. So that takes care of the "most difficult" part.
Sorry if I sound rude, just some suggestions to consider.
Cheers,
Simon
Old 09-15-2013, 09:21 AM
Monsignor's Avatar
BMW CCA Memeber #445389
Mein Auto: Sig
what a fantastic second post.
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 09-15-2013, 06:53 PM
MySatinDoll MySatinDoll is offline
I'm from NJ. So What!?!
Mein Auto: What they Drive
Thank God... please don't it's been beaten to death already.
Fixed that for ya. The MAF and AFM though similar in application aren't the same nor measure air flow the same. Though I understand what you're saying. Others may not.
Koni's weren't mentioned?!? Well at least you did now.
Think that's bad check out some of his remedies for various issues
Truth be told your 100% correct. (I just had this conversation)
People have counted out the e34 m20 cars.
Kind of like what's the progressing notion on e34 m30 cars.
Yes it's old tech. The m20 isn't the best performer and some if not most swap them out.
Your interjection is exactly what needs to be said. People love them.
It's the love of these old grunts that has always been the foundation of the overall e34 enthusiast group.
Cheers,
Simon
Not rude... you're good your observation and suggestions.
______________________________________
Former Content Writer - FCPEURO
86 BMW 325es...Sold,
92 BMW 535i...Totalled
89 BMW 535i aka "Zaraki"... Totalled,
90 BMW 325i m60 swap... Sold for a friend,
95 e34 525 5 spd S52 Swap aka "Grau"...Sold,
01 Cosmoschwartz on Dove e38 740i msport... Sold,
01 Titan Silver on Schwartz e38 740i Msport Aka "Lucky Lilly... Daily
00 Chevy 4wd s10 BLazer LT aka "El Squeeky"... Haulin & Yard Duty.
Old 09-16-2013, 05:42 AM
Mein Auto: E30, E39
Thanks, MSD.
Woops, yes, that dyslexic moment makes quite a difference! Thanks for picking that up.
Yeah, I've got a soft spot for the old warhorse M30 too. And the lighter E30 body means the smaller torque output of an M20 doesn't matter too much when you just want to get to the shops without ringing out every gear. I'm not trying to push the barrow of any particular engine, just wanted to highlight that M20 folks have room for improvement instead of going straight for an engine swap. There's everything from a chip to awesomely bonkers builds like this: http://www.performanceforums.com/for...th-TK-goodness (not to mention boosted options )
Cheers,
Simon
Old 09-17-2013, 07:24 PM
sybronis sybronis is offline
Mein Auto: 95 540i
Is there a chip for a 95 540i automatic? Didn't see from the directions here.
Old 09-18-2013, 05:58 AM
Monsignor's Avatar
Mein Auto: Sig
LMGTFY
Search took 0.32 Seconds. #1 and #3.
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 09-18-2013, 05:59 PM
Mein Auto: 95 540i
Thanks your a peach
Old 09-19-2013, 06:32 AM
Monsignor's Avatar
Mein Auto: Sig
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 10-04-2013, 08:32 AM
Macjackson Macjackson is offline
Mein Auto: 1991 BMW 535i
I have a hole in the exhaust of my 91 535i stock exhaust and I want to replace it with a performance exhaust that has a nice deep rumble. Any suggestions people? Something that won't cost me an arm and a leg.
Old 10-04-2013, 09:56 AM
E34ZombieHunter's Avatar
E34ZombieHunter E34ZombieHunter is offline
Nothin like an E34
Mein Auto: 95 540i B/B
YOUTUBE!!!!!!!!
Found a vid there and that made my decision on exhaust, but mine is 540i, so not sure how it would sound on your car. It is a nice deep rumble that i like too, not that ridiculously loud tuner sound.
Gotta love an E34!!
If you want to get junkyard parts remember one thing, if it was wrecked you know it was running/driving. You may not know how well, but it was.
READ THE STICKIES AT THE TOP OF THE PAGE!!
STOMP TEST
READ ME IM THE BIBLE
FAN CLUTCH
LOCKS
ANGEL EYES
Audio
E28 v. E30 v. E34
Old 10-04-2013, 10:15 AM
Yah I'm really not into the tuner sound for this vehicle, which at this point it does sound like due to the hole in the exhaust. I looked on YouTube but could find and make, just descriptions of the exhaust
Old 10-05-2013, 10:23 PM
B&B, Remus, Eisenmann, super sprint, simon (not in the US...I think) Schmiedmann.
Outside of a magnaflow muffler or just creating your own exhaust.
That's just about it.
Old 10-06-2013, 10:19 AM
Thanks a lot! I'll check them out!
Old 10-28-2013, 08:51 AM
Hey guys. My windshield wiper motor burnt out on my 91 BMW 535i. Any ideas where I could get a new one for cheap?
Old 10-28-2013, 09:04 AM
Nothin like an E34
Junkyard
Gotta love an E34!!
STOMP TEST
FAN CLUTCH
LOCKS
ANGEL EYES
Audio
E28 v. E30 v. E34
Old 10-28-2013, 12:44 PM
^ This.
Or South26 aka Andy and another member who's handle I forgot.
They're both parting e34s as we speak.
Don't know the other guy but Andy is a solid seller.
Andy's thread: here
I got his name it's 92 535i manual. Heres his thread as well:
Parting a e34 535i
Old 11-17-2013, 04:31 PM
Nothin like an E34
http://www.scribd.com/doc/80785425/15/Moonroof This may be something to add very interesting.
Gotta love an E34!!
STOMP TEST
FAN CLUTCH
LOCKS
ANGEL EYES
Audio
E28 v. E30 v. E34
Old 11-23-2013, 05:48 PM
fendizainal fendizainal is offline
Mein Auto: e34
Re: Known E34 Upgrades and Common E34 Myths
Hi All,
Im new here. Wondering if anybody can tell me if I were to do an engine swap onto my e34, what latter model of engine would fit on to the e34 chasis. Here in malaysia parts n engines for e34 starting to become obsolete so I may need to consider changing to a newer model engine as my engine has been giving me a lot problems lately.
Appreciate it any reply and suggestions.
Old 11-24-2013, 03:34 PM
Originally Posted by fendizainal View Post
Hi All,
Each will need a little modifications due to the difference in size and mount positions But...
s38 (possibly the easiest for the m30 and the s38 are kin to each other)
m50
m6040
m62
m70
s50
s52
Basically anything that your time and bank account can afford.
Old 11-24-2013, 03:53 PM
imae34driver imae34driver is offline
Resident e34 Racer
Mein Auto: 1995 540i SPORT /6 spd
I think he is more looking for more easily maintainable direct fit solution..
Basically, you just wanna move up one generation..
If you have an m20/m30 replace it with an m50/m52 what ever is available to you.
If you have an m60, and its hard to come by then hopefully the pre vanos m62 is available.
Both swaps offer equal performance and a newer motor that should be easier to find extra spares for..
Both witch i recommend an obd1 swap on.
Goodluck
Bone stock 95' 540i/6 Blk/blk w/ ram style C.A.I / JBR LWFW/ DUDMD tune/ straight pipe /545 SSK /3.15 LSD / Rev-shift motor mounts/stage 4, 6 puck clutch/ K Sport coil overs/Eibach sway bars/ VAC under drive pulleys/weight reduction /sparco 368, Recaro seats, sparco harnesses, NX wet kit, M/T E/T streets.
"Skill can only get you so far, then comes money!"
R . I . P Paul Walker - 1973 - 2013
Old 11-24-2013, 05:49 PM
Mein Auto: e34
Hi mysatindoll,
Thank you very much for the list of engine models as what I am looking for. At least it narrows down my search and I can learn abt each engine from here on and of course time n money is the essence. Haha.
Cheers!
Sent from my GT-N7100 using BimmerApp mobile app
Old 11-24-2013, 05:56 PM
Mein Auto: e34
Hi imae34driver,
I was adviced the same as what you said by a friend of mine.
Thank you very much for both the replies! Helps.
Cheers!
Old 01-18-2014, 10:57 AM
mrkanda mrkanda is offline
Mein Auto: 1992 E34 535i 5spd
MySatinDoll,
Thanks for the nice info on the upgrades for the E34 535i. I've had mine for a week now. Sorry to hear about your recent accident. I hope it can be repaired to its former glory.
Besides what you mentioned I had a couple questions: My 1992 came stock with a 5 spd and LSD. What gear ratio does it have? It travels in 5th gear at 45mph at 2k rpms, 60 mph at 3k rpms, and 70mph at 3250rpms. I'm also wondering how to get better fuel economy. It gets about 15-16mpg around town and 19-20 on the hwy at 70-75 mph.
I was thinking of doing a tune up, although the PO did one in the past 10k miles, and I wanted to get an upgraded ECU chip which is why I had purchased the Alpina B10 3.5 ECU. I think now it won't work on my car, so maybe a TMS chip. Lastly I was wondering if a 6 spd trans could be fitted to the M30 motor to have a better final drive ratio. I would like to be able to get 18+mpg around town and 25+ on the hwy.
I am thinking to go turbo in the future but for now just need some reliable economy with decent stock power.
Thanks, Mark
Old 03-16-2014, 07:57 PM
Nothin like an E34
http://www.bimmerfest.com/forums/sho...d.php?t=363658
Gotta love an E34!!
STOMP TEST
FAN CLUTCH
LOCKS
ANGEL EYES
Audio
E28 v. E30 v. E34
bmw tuning, e34, e34 tuning, m50 upgrades, upgrades
