Old 06-26-2013, 03:42 PM
A B Able Truck's Avatar
A B Able Truck A B Able Truck is offline
Mein Auto: 2006 550I (N62TU) V8
Originally Posted by bmwoem1 View Post
That bulletin is no longer used because the method used to clean the carbon was found to be ineffective. We now use walnut shells to actually blast the carbon off manually. This method is well documented in other areas of this forum. Again.... I have never heard of either of these methods used on an N62tu/N62 intake valves or piston tops to reduce smoking tailpipes. Even the walnut blasting is used sparingly in extreme cases because the noticeable effects are minimal (that statement comes from BMW engineers/PUMA). The only before and after improvement I have seen is a smoother idle.
*** Well you got me with that walnut blasting - I've never heard of it ***
But I don't know if I'd want nut shells floating around my rings.
Old 08-04-2013, 06:58 AM
2006750LI 2006750LI is offline
2006750LI
Mein Auto: 2006 750LI
2006 BMW 750LI is smoking
Hello everyone, can you recommend someone who could fix my car for much less than the dealership? I'm in Buffalo NY. I just joined this website. My 06 750 just started having that smoke problem that you all have been talking about here. The dealership says it's most likely the valve issue discussed here, so for them to fix, it would cost a fortune. If I let it idle for a while, then punch the gas pedal, smoke comes out of the tail pipe. Thanks!
Old 08-04-2013, 07:10 AM
2006750LI
By the way, my 06 750LI I am talking about has 148k miles, but looks and drives amazing.
Old 08-04-2013, 08:10 AM
First - welcome my fellow Buffalonian (my birthplace) - can't say I miss it but it was fun growing up there. From my previous post my car is still running strong with no smoke. Fiirst try the inexpensive recommendations before handing over your hard earned money.
Old 08-04-2013, 08:14 AM
745iguy's Avatar
745iguy 745iguy is offline
Besessen Deutsch Autos
Mein Auto: 2006 X5 3.0
Valve Stem Seal, SUGGESTIONS?
Pm bmwoem1 he is in ny and does this for 2500
06 X5 3.0 Toledo Blue Metallic/Light Beige 2:
Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades,
+Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs,
+White Angel Eye LEDs, +5000k LED H11 Foglights, +Blacked Out Chrome Grill Surround, +Puddle Light Logo Projector
.. more updates to come
PREVIOUS 2002 745i
Old 08-04-2013, 09:46 AM
ayman ayman is offline
Mein Auto: Alpina B7 e66
Wooooooow
In our country they replace the valve steam with the parts for 1500$ including the parts.
The whole engine will cost 4000$ low mileage imported from Japan.
Most of the valve steam issue is from not replac the oil for long period. And this common issue in all Germany cars such as Mercedes , Audi as they use the the same brand
I think the prices is over. If its like that I wish that I own garage in US.
Old 08-04-2013, 09:50 AM
bmwoem1 bmwoem1 is offline
Past Sponsor
Mein Auto: X3
PM sent
Old 09-28-2013, 06:45 PM
2006750LI
I highly recommend BMWOEM1 for valve seal repair
I made the 6 hour drive to have BMWOEM1 fix my valve seal issue. I have a 750LI with almost 150k miles. He did a great job, I'm so glad I went to him instead of the BMW Dealership. Saved a fortune and I think he did a better job and in less time than my dealership would have. It was an easy trip to his house in Long Island NY, all highway driving, his place was just off the highway. This guy really knows BMW's inside and out. He made the job look easy. My car used to go through oil like crazy, there were so many leaks. Since he fixed everything a few weeks ago I haven't lost a drop of oil, engine is sealed tight with all new gaskets and the new valve seals eliminated all the smoke from the exhaust. It feels weird now, not having to add oil all the time . Very happy. Anyone considering seeing this guy for any major BMW repair should not hesitate. He really really knows his stuff and is very fair with his prices.
Old 09-28-2013, 07:00 PM
Past Sponsor
Mein Auto: X3
Thanks for the great feedback, always appreciated!
Old 10-01-2013, 09:37 PM
miguel 745li miguel 745li is offline
Mein Auto: 04 BMW745li
I am new to Bimmerfeast and I am having the same issues with my 745. I just purchase a 2004 BMW 745li and at the time of purchase it was not smoking till two days after. First my logic7 amp went out then it started smoking white smoke from the tail pipe on takeoff. I am debating on keep it or selling it. I pretty sure it’s the valve seals from what I have read on the forums. Is there anyone in the bay area (San Francisco) that is dependable that would be able to replace valve seals for a good price? BMWOEM1 be nice if you lived out in the bay area…………Is it common for exhaust to only come out of one tail pipe? Thanks
Old 10-02-2013, 03:58 AM
Past Sponsor
Mein Auto: X3
Only one pipe is open during idle, the other closed by the exhaust flap. If I had the time, I would make a cross country trip and do a bunch of stem seal jobs.... But for now, I guess only northeast BMW owners can take advantage of my services
Old 10-02-2013, 05:47 AM
FYI -
Yesterday, 11:54 PM
craigatkinson
Member
I've been trying many of the suggestions in this forum and it appears that I may have fixed the problem. My car is not smoking at all anymore.
I went and took off the vacuum tubes and dumped out any oil in them, there wasn't much. I changed the oil and placed a heavier oil, 10-40 synthetic mobile one, with some stop leak along with it. I also looked at my K&N air filter and it was plugged tighter than a tick, so I figured I better clean that. I also filled it up with oil just a little over max. That was accidental, but I don't know, if there is a vacuum issue, maybe that could make a difference as well. I did so many things, I do not know which things may have helped, but I've been driving it for several days without seeing any smoking, even in stop and go traffic where I used to see it bad. So if I see any more smoke I'll try to let you all know.
Old 10-02-2013, 10:38 PM
07jace750li 07jace750li is offline
Mein Auto: 750li
Question guys I have a 07 750li with 78000 miles on it and I recently changed my ccv and now I lose a quart of oil every 1000 miles before I changed my ccv I use to add a quart of oil every 5k-6k and I change my oil every 6k-7k and I use mobile 1.. could it be that I put a defect ccv or is this valve seal?? I don't see smoke coming out my car or maybe I just don't see it when I'm driving any advise or info would be much appreciate thank you
Old 10-03-2013, 03:33 AM
Past Sponsor
Mein Auto: X3
You need to double check the install of the CCV's first. The easiest way to check for valve stem seals is to drive the car until fully hot and let it idle for about 10 minutes. Next, rev the engine (while in park) to about 5k rpm quickly and release the throttle. If you see a cloud of smoke from the tail pipe, it's most likely leaking valve stem seals.
Old 10-03-2013, 05:59 AM
Double check your CCV install and while you're at it pull your CCV hose(s) and check for oil.
Read this thread for good info/debate (start at page 1);
http://www.bimmerfest.com/forums/sho...718963&page=11
Old 10-03-2013, 07:23 PM
Mein Auto: 750li
Thanx A B Able I appreciate the info!!
Old 10-03-2013, 07:26 PM
Mein Auto: 750li
K I will check tomorrow and let u guys know what happen thanx for the help bmwoem1 I appreciate it!!
Old 10-08-2013, 08:29 PM
Mein Auto: 750li
I check both ccv looks fine but one of the ccv cap was loose I tighten it back up just got a oil change I will check and see if I get a better oil consumption but I don't think it will get better but will see
Old 10-09-2013, 10:16 AM
Past Sponsor
Mein Auto: X3
I see your in NY, PM me if you find that the valve stem seals need to be replaced.
Old 10-24-2013, 11:10 AM
Mein Auto: 750li
Just a update I tighten one of the ccv cap got a oil change put 10w 30 mobile one I put 1000 miles on it and I haven't lose a drop of oil do u guys think that one of the ccv are lose could cause this oil consumption I use to lose a quart every 1000 miles
Old 10-24-2013, 12:56 PM
Past Sponsor
Mein Auto: X3
Only time will tell.... You need to put some more miles on it
Old 10-24-2013, 03:24 PM
brettsg brettsg is offline
Mein Auto: 5 series
it is a known problem and you car is very low mileage for this but your quote to fix this is also too high. My shop does this repair for 3500. look around for a better deal
Old 10-24-2013, 07:36 PM
RON7165994 RON7165994 is offline
Mein Auto: 2004 745LI
I need to get this done is any one in Houston can do this?
Old 10-24-2013, 08:39 PM
Mein Auto: 750li
I did this test I drove the car for 1 1/2 and I let it idle for 30 min cause I forgot it was on but when I hit the gas I didn't c a cloud of smoke
Old 10-28-2013, 01:02 PM
whytry's Avatar
whytry whytry is offline
Mein Auto: '07 750Li, 68 Camaro
I think I'm starting to develop this issue now. Idling like in driveway then rev it has a little bluish colored smoke... Ugh. It doesn't really do it unless it sits n I rev it. Letting it sit n then driving seems fine from what I can tell
But I am loosing about 1 qt of oil every 2k miles I'm noticing last couple months... 110k on it.
06 750i - Blk/Blk, Sport pkg, premium pkg, comfort access, ent pkg, convience pkg, 21's, sold
07 750LI - Blk/Blk, Sport, Premium, comfort access, rear DVD, convenience, 21's
68 Camaro - Procharged and injected LS2 in progress
