Old 10-27-2013, 11:23 AM
KillaGorilla KillaGorilla is offline
Mein Auto: 745Li
Key fob issues, car doesnt accept it anymore
2002 745li non comfort access key
My unlock button quit working and rather than be raped by the dealership i cut it open as seen in some videos to find the button for the unlock had come un soldered.
As i did not have time to do the button repair right then i closed the key back up and ran a line of tape around it to hold until i had time this evening to fix it. Nothing inside the key was altered simply viewed. however now the car will not accept my key to start or do anything else.
The key is still alive the lock / trunk buttons work, but when you insert it, it only goes into the first "catch" which holds the key from falling out. if you push it further in it does not hold and the spring simply pushes it back out. it also does not power anything even if you hold it in place. after reading and watching videos etc i am stuck. any advice that isn't "lol go bend over at the dealership"
Old 10-27-2013, 01:40 PM
SuperSnoop's Avatar
SuperSnoop SuperSnoop is offline
Mein Auto: 2007 760Li
Glue it back together and make sure it's line up exactly right. If you just taped it, there's no way the car will accept it.
Old 10-27-2013, 03:59 PM
Mr745i's Avatar
Mr745i Mr745i is offline
Mein Auto: 745i
Re: Key fob issues, car doesnt accept it anymore
Your (cas) has taken a dump! Been there done that with my 2002 745i.....in my case it wouldn't hold key fob into the (cas) to start car. Key just would slid right back out.
Sent from my SAMSUNG-SGH-I717 using BimmerApp mobile app
Old 10-27-2013, 04:18 PM
bighorns's Avatar
bighorns bighorns is offline
Evil cider brewer
Mein Auto: E92 335i M Sport
Broke those locking prongs in the ignition?
http://www.bimmerfest.com/forums/image.php?type=sigpic&userid=325723&dateline=1371746393
*NEW* delete pls 1K
3K
11K
Old 10-27-2013, 07:57 PM
Mein Auto: 745Li
so.
i repaired the broken switch inside the fob and now the unlock and all other buttons function properly. i also glued the fob back together taking care to make it line up properly. however the same problems occurs. the key goes in and does catch ~ 1/2 way in, in the pre turn on position. then once it is pushed all the way it in will not catch and releases back to the 1/2 position. (it does not fall completely out.)
i took a flashlight and pressed the internal slider in the cas in slowly to inspect for any visible damage, both on top and bottom there are plastic tabs which hold the key in place and they are both undamaged, and the entire internal mechanism looks clean and undamaged front to back. I can see the cas going out, but at exactly the same time as the key was worked on ?, that seems a little too coincidental unless the key physically damaged it which does not appear to be the case.
i appreciate the quick reply's guys, any additional ideas would be helpful. i hate the idea of dropping dealership money to replace cas and keys and be wrong about it.
Old 10-27-2013, 08:18 PM
PAPER's Avatar
PAPER PAPER is online now
CRISP & CLEAN
Mein Auto: Ford Pinto
Originally Posted by KillaGorilla View Post
so.
I would try filing both sides of the key fob were you split it apart & then
gluing it back together . The key Fob is very touchy & precise in its
measurements & thickness .
Old 10-27-2013, 08:56 PM
Mr745i's Avatar
Mein Auto: 745i
Try another key if you have one or try holding the fob in place and try the start button and see what happens......like the member paper said those keys are very sensitive.
Quick question,
Do you have any problems with memory settings I.e: eq settings, radio settings? Meaning do your settings go back to default after you've turned car off for a while?
Old 10-28-2013, 12:39 PM
Mein Auto: 745Li
sadly do not have another key.
when i press the key entirely in and hold it, there is no response at all. as if the key is not there. and no there have been no issues with memory or other settings prior to this issue. i have ordered a key now but have to wait for it to arrive. hopefully i just killed a key and nothing more.
Old 10-28-2013, 05:53 PM
Mr745i's Avatar
Mein Auto: 745i
Good luck.......
Old 10-28-2013, 11:36 PM
karmaxul karmaxul is offline
Mein Auto: 745i
I have read about a battery reset where you disconnect the neg cable for 20.
Old 10-29-2013, 12:44 AM
Mein Auto: 745i
http://forums.bimmerforums.com/forum...ll-in-one-post I think this is what your looking for
Old 11-01-2013, 07:09 AM
Mein Auto: 745Li
i killed my key. cutting it open to fix a door unlock issue cost me 220.00 and a bit of a headache. i have an expensive door unlock paperweight now to remind me to work slower and more precisely. thanks for your info guys.
Old 11-01-2013, 02:16 PM
PAPER's Avatar
CRISP & CLEAN
There are plenty of members on here that have
Done the repair with no issues , Myself included
When I helped a friend fix his . You were given
Some suggestions on your post how to fix the
problem. I even made a suggestion that fixed
the problem for others that had your same issue .
He should try the repair if he is comfortable with
The method & you should not discourage him
From doing so
Sent from my C6833 using BimmerApp mobile app
Old 11-01-2013, 02:44 PM
Mein Auto: 745Li
i know paper, the info was good, but apparently my fat fingers did the damage.
Old 11-01-2013, 04:43 PM
PAPER's Avatar
CRISP & CLEAN
you should have had someone help you .
Also you should go backk & try my suggestion ...
