Help Oil went where steering fluid should - Bimmerfest - BMW Forums
Old 10-28-2013, 07:07 PM
Ingrid Ingrid is offline
Mein Auto: 2007 750li
Holy smokes. I put 5w-30synthetic oil in what I now think is the power steering fluid dump. Can I drive it to the shop or should I suction it out and refill, have it towed?
Also I have not driven the car since I did this...bone head. My wife is even in disbelief.
Old 10-28-2013, 07:11 PM
Nygel's Avatar
Nygel Nygel is offline
Mein Auto: BMW 750Li
drain it, its that simple. If you never turn on the engine just turkey base it out, if you ran the engine loosen the hose and let all the oil run out with the engine running.
Old 10-28-2013, 07:38 PM
Okay well I turned the engine on for about 2 minutes, before I realized what I had done. I did not go anywhere. Do you think I could get it to the shop or should I tow it?
I could definitely turkey baster it out, but you mentioned If I started the care I should drain it? Thanks Nygil
Old 10-28-2013, 07:55 PM
Nygel's Avatar
If you look at the power steering fill can there is a hose, get you something to catch the fluid and let it drain in your catch can, you should get most of it out but if you want to make sure remove hose at pump and let it drain and the refill with CHF 11S fluid.
if you want to tow it its up to you but its a simple diy.
Old 10-28-2013, 08:05 PM
Expo BMW's Avatar
Expo BMW Expo BMW is offline
Local Enthusiast
Mein Auto: E65
As nygel said. You can disconnect one of the hoses and pump out the old fluid with the engine running. Fill up and turn the steering wheel from lock to lock. You should repeat this twice to make sure you get out all of the contamination. The only problem is that the Pentosin CHF fluid is expensive. What is more expensive though is if you drive it the way it is and cause damage to the steering rack or power steering pump.
. 360infiniteusa Angel Eyes . H&R Springs . mObridge AUX Integration .
Old 10-29-2013, 02:50 AM
inspi inspi is offline
Mein Auto: 03 BMW 745i, 06 BMW 750Li
And then You need to bleed Dynamic Drive system-if equipped
INSPI
