Old 04-12-2010, 08:05 PM
pigeon pigeon is offline
Mein Auto: 06 750Li
Coolant flush?
It's been 2 years so it's time for a coolant flush. Anyone have a DIY, or should I just buck up and have the dealer do it when it's in later this week for yet more warranty work?
Old 04-12-2010, 10:32 PM
Call Me Daddy Call Me Daddy is offline
Porsche Ex-Pat
Send a message via AIM to Call Me Daddy
Mein Auto: 2003 745i Blk/Blk Sport
I had mine done at and independent shop and I think they charged around $150. Not worth the mess for a DIY in my opinion.
Am I crazy or am I?
Old 04-20-2010, 01:45 AM
TechGuy TechGuy is offline
Mein Auto: E46 325i
But BMW never recommends this job.
Old 04-20-2010, 07:06 AM
cjennjr cjennjr is offline
Mein Auto: 2002 BMW 745i
Per the Owner's Manual, BMW recommends coolant change every four years. If you switch to the waterless coolant, no other changes are required.
Black Beauty
Old 04-20-2010, 03:06 PM
Maverick62 Maverick62 is offline
Mein Auto: 2013 750lix m-sport
DIY, just remove drain plug, let it run out. then fill with a 50/50 mixture . Get the right
antifreeze .
2013 750lix dgm2 M-sport
2011 550ix dgm awesome (in pic)
2006 750li bk saph retired
1998 740il ox grn retired
Old 04-20-2010, 07:20 PM
USALEXUSBMW750's Avatar
USALEXUSBMW750 USALEXUSBMW750 is offline
Little Odessa
Mein Auto: bmw
Originally Posted by maverick62 View Post
diy, just remove drain plug, let it run out. Then fill with a 50/50 mixture . Get the right
antifreeze .
+1
Old 03-11-2011, 09:41 PM
zeekq zeekq is offline
Send a message via AIM to zeekq
Mein Auto: 2002 745i
where is the drain plug? and after drainig do i need to run water thro? than fill it with bmw antifreez?
Old 03-12-2011, 12:02 AM
***CCCP***'s Avatar
***CCCP*** ***CCCP*** is offline
Major
Mein Auto: 745 li
Old 03-12-2011, 07:54 AM
Little Odessa
Mein Auto: bmw
Wait till your bottom hose radiator temp sensor start leaking, then change o-ring on it and flush the system, do everything in once
Old 10-29-2013, 11:29 AM
minhvotx minhvotx is offline
Mein Auto: 2006 bmw 750li
Did you find out where the drain plug located? I need to do mine.
Old 10-29-2013, 11:36 AM
mgucci745 mgucci745 is offline
Teenage Car Enthusiast
I'm almost positive the drain plug is somewhere on the radiator. I saw some videos how to do a coolant flush on the n62 engine. It's as simple as unplugging the drain and refilling.
ALSO, if I'm using BMW BLUE COOLANT, do I still need to add 50/50 mix w/ distilled water???? The last few times i've put just blue coolant in and filled to the top.
This Car Im Driving Make U Feel Some Type Of Way
@V1SUALZ Los Angeles car v1sualz company coming soon!
F*** a lease, drive a e65
Old 10-29-2013, 11:52 AM
Nygel's Avatar
Nygel Nygel is online now
Mein Auto: BMW 750Li
passenger side bottom of radiator.
Old 10-29-2013, 12:32 PM
Thank you mgucci745 for replying. I see a video showing the plug with red plastic cap on the lower passenger side of the radiator. Need to remove the under car panel to access.
Old 10-29-2013, 03:21 PM
gkent gkent is offline
Mein Auto: 2013 F02
The BMW blue is not pre-mixed .... you need to mix 50/50 with distilled water.
Note the steps for coolant filling to ensure proper venting (taken from the TIS: http://bmw.workshop-manuals.com/7_Se...dex.php?id=798)
- Before filling expansion tank, turn ignition position on (don't start)
- Set Heat to maximum (blower low) ... this is important to ensure heater valves are OPEN and Aux water pump is ON ..
- Fill expansion tank up to Max
- With cap open, start engine and run at idle for 1 minute and shut off
- Fill coolant back to Max level and close cap
- Run engine up to operating temp (until thermostat opens). Check for leaks. (Do NOT open expansion tank cap when coolant is HOT)
Old 10-30-2013, 01:58 PM
Good instruction. Done flushing my cooling system today. Thanks.
Old 10-31-2013, 07:11 PM
rippjd rippjd is offline
Mein Auto: '05 745i / '10 X5 35d
Coolant flush?
Technically you should also pull a coolant plug from the engine block. Then refit with a new crush washer. I forget which side of the engine is easier to get to.
2005 745i Individual
E65/E66 Parts for Sale:
Alpina Type 743 Front Spoiler complete retrofit kit (new in box) $1200
