Old 07-06-2013, 08:22 AM
bmwpower8 bmwpower8 is offline
Mein Auto: X5
Successfully coded my E70
Thanks for quick reply,did expect that to be the case even though I had tried the coding as for the F series but to no avail.
Must not give up on this!
Old 08-13-2013, 11:18 AM
iconoclast's Avatar
iconoclast iconoclast is offline
Automotive Addict
Mein Auto: Audi, BMW & RR...
who is the vendor of choice to purchase the device? i have used rosstech for as long as i can remember for vagcom/vcds but no idea who to buy one of these from.
Old 08-13-2013, 11:39 AM
icuc's Avatar
icuc icuc is offline
Mein Auto: 2012 X5, 2012 MINI ALL4
Re: Successfully coded my E70
If you are referring to the cable then buy the K+DCAN from one stop electronics. It is little expensive than ebay cable but it is more reliable.
BMW (Remote) Coding for E Series, F Series and G12 Models - www.bmwminicoding.com
Old 08-14-2013, 08:28 PM
Erlkoenig Erlkoenig is offline
Send a message via Yahoo to Erlkoenig
Mein Auto: German stuff
You will be doing my 35d soon!
It's currently at the dealer. TD will be contacting you soon.
Old 08-14-2013, 08:39 PM
iconoclast's Avatar
Automotive Addict
i dont want anything ebay oriented on my car or affiliated with it... thanks for the head's up... i'll order it tonight.
Old 08-21-2013, 05:15 PM
f30_Msport f30_Msport is offline
Mein Auto: BMW 328i xdrive M Sport
has anyone made a cheat sheet for the E70. I have an F30 and there are cheat sheets for that one. But i cant find one for my wifes E70. When i say cheat sheet, i mean a sheet with all the locations and options there are to code the car.
Old 09-17-2013, 12:17 PM
TinyRK's Avatar
TinyRK TinyRK is offline
Ja mei!
Mein Auto: X5
Hey all,
pulled theFSW_PSW.MAN file
Browsing through it I noticed:
Blah_blah_blah (forgot the "title"):
6_gaenge.
Considering I have a 2012 X5 LCI (e70_n55) and have 8 Gaenge ( 8 speed gearbox), shouldn't this say 8_gange?
Can someone just check their man-file and confirm the same?
BMWCCA Member# 481324
Old 09-17-2013, 12:29 PM
philooo philooo is offline
Mein Auto: 2011 X5 5.0
same for me on my X5 V8
GETRIEBE_GAENGE
6_gaenge
And I can comfirm all 8 gears are in use...I wish we could limit it to six
'11 X5 50i M-Sport
19" Black Saphire | Black | Alu | Lux Seat | Adaptive | Cold | Tech | Sound | Prem | Comf Acces | combox retrofit | Invisihitch oem harness
Old 09-17-2013, 12:34 PM
TinyRK's Avatar
Ja mei!
Mein Auto: X5
Your X5 is a LCI?
Thank you, sir!
Old 09-17-2013, 12:40 PM
it is an early LCI made in march 2011 I believe.
'11 X5 50i M-Sport
Old 09-17-2013, 01:35 PM
foglight foglight is offline
Mein Auto: BMW
Originally Posted by TinyRK View Post
Your X5 is a LCI?
Thank you, sir!
Hey all,
6_gaenge.
Emergency mode(limp home), transmission is a six-speed only.
Old 09-17-2013, 01:37 PM
TinyRK's Avatar
Ja mei!
Mein Auto: X5
But that's not what I read out of:
GETRIEBE_GAENGE
6_gaenge
No mention of LIMP-MODE
Old 09-17-2013, 02:01 PM
I don't feel any limp mode on my car that's for sure.
'11 X5 50i M-Sport
Old 10-30-2013, 09:45 AM
Neon01 Neon01 is offline
BMW Nut
Mein Auto: 12 X5 x35i, 10 135i
Posted this over at bmwcoding newbie thread, but I thought this might be a better spot since I'm dealing with an E70.
I downloaded the "BMW coding all-in-one kit", which looks like a great comprehensive package of files that are needed for coding. However, it looks like it's at least 6-12 months old, since it didn't have anything newer than SP Daten v46 for my E70. I was able to find the full 10GB v47.1, which I think is recent enough to code my 2012 E70. Questions:
1. which files do I need from that large download and where do I move them to?
2. in the instructions I read everywhere, there is always a step that says "update your NCSE to match you daten files" or some such. then they provide a link to a wiki on this site that doesn't appear to be active to indicate HOW to do this. Without that wiki I guess I'm dead in the water. Could someone describe how to update NCSE to match my daten files?
Thanks in advance.
Chris
2012 X5 xDrive35i Platinum Gray/Oyster/Burl Walnut
2010 135i Alpine 6 sp White/Coral Red/Black Alcantara M Sport
Old 10-30-2013, 10:50 AM
blue dragon blue dragon is offline
Mein Auto: X5 35D
search for laden.bat within the daten folder and run that. There are a couple of other directories that you need to copy over manually as well.
'09 X5 35D - Work horse
'17 X1 MSport - Wife
'17 340i MSport (ordered) - Soon to be daily
Old 10-30-2013, 05:24 PM
BMW Nut
Awesome, got it all figured out. Just coded the windows close function with the key fob. I've got a lot of reading to do to figure out how to continue coding additional things without losing what I've already coded. I really want to do the DVD in motion as well, and I understand the best way to do that is before everything else since it'll wipe the rest.
Is v47.1 dates recent enough to get all the modules for a 2012 E70?
Chris
Old 11-21-2013, 10:55 AM
deepak333 deepak333 is offline
Mein Auto: 2013 X5
I am doing code to my new 2013 X5 35i xDrive. Any one experienced any issue with BMWNA Warranty?
Old 11-21-2013, 12:13 PM
mgarciah's Avatar
mgarciah mgarciah is offline
Mein Auto: 320i, X3 and X5
At least, here in Costa Rica, no, according to them there is no relation between a code and warranty issues, in fact my car is fully retrofitted with idrive, 8.8 display, internet, BMW live etc, is also a X5 3.5i 2013, and I already claimed several warranties as the brake actuator, autoleveling xenons etc without any issues, the only problem is that they will flash the whole car and comes back to the standard code so you have to recode it again.
Old 12-04-2013, 09:16 AM
yozh's Avatar
yozh yozh is offline
Mein Auto: F15 40e 16
Just got my new 2013 X5 35i P xDrive and already want to program things. Such as mirror auto folding on door lock/ulock DVD in motion and some other annoying things. Can some one point me in the right direction to get started ? Like what cable I need where to download things and how to start ?
Thanks in advance
Old 12-04-2013, 09:32 AM
mgarciah's Avatar
Thanks in advance
www.bmwcoding.com
Old 12-04-2013, 10:45 AM
yozh's Avatar
Originally Posted by mgarciah View Post
Thanks I guess I`ll post there.
Old 12-04-2013, 10:56 AM
mgarciah's Avatar
Good luck, you have to be patience and read a LOT before trying to do something, moderators on that forum are very tough, so do not open threads like.. "how can I code..." first read all the Sticky threads for beginners and you will be amazed of how much info you can get.
Old 12-04-2013, 11:10 AM
yozh's Avatar
Yeah trying to wrap my head around it. Just want to make sure that there is info for the 2013 X5 and I dont damage my car. Thanks for the tips !
Old 12-22-2013, 09:20 PM
molloy molloy is offline
Mein Auto: 2011 BMW X5 35D
Thanks in advance.
I'm having trouble getting access to everything on bmwcoding, is there a reason for this? I've tried to code last year, and gave up.. thinking to try again. Do you have a link to this kit? Also, does anyone know if its possible to code for bmw live?
Old 12-23-2013, 02:17 AM
Mein Auto: X5 35D
Go into the daten folder within the E70 folder. There is a file called laden.bat, you will need to run that to update the daten files. There folders and instructions can be found here
http://www.bmwcoding.com/showthread....oding-your-car
