AC on or off in the winter? - Bimmerfest - BMW Forums
Old 10-27-2013, 09:02 AM
ce200 ce200 is offline
Mein Auto: 2011 X5 diesel
do you guys turn off the AC in the winter?? or keep it on all the time?
except when there is condensation on the windows i know you have to tunr it on..
any ideas?
thanks
Old 10-27-2013, 10:37 AM
ard ard is offline
Resident Curmudgeon
on all the time. Helps preserve the interior (ie leather, carpeting) by controlling humidity- irrespectibve on window fogging.
Old 10-27-2013, 11:29 AM
Mein Auto: 4 BMWs, 1 Jeep, 1 Vespa
I'm not a fan of processed air. I'm more of a windows cracked open and sunroof on vent type of guy so AC is generally off unless I need cooler air on highway trips or it's raining / snowing. Given where I live, the AC is off 80% of the time.
Old 10-27-2013, 11:59 AM
BenF12400 BenF12400 is offline
Mein Auto: 2006 X3; 2010 528;2013 X5
I think leaving it on "helps lubricate the moving parts" in the AC - or so I think I read once.
Old 10-27-2013, 03:11 PM
smyles smyles is offline
Mein Auto: X5
Re: AC on or off in the winter?
Define "winter". A/C isn't working when it's below 40 or smthg like that.
P.S. lol @ keeping humidity out in winter. Cold air is dry by itself. Just ask your skin.
Old 10-27-2013, 08:25 PM
gresch's Avatar
gresch gresch is offline
Don't be a hammer
I run the compressor a few times a month in the winter, but generally it's off.
Old 10-28-2013, 05:38 AM
troymi troymi is offline
Mein Auto: '14 650i X Coupe
The compressor is the single largest drag on the engine. Takes power and reduces fuel economy. Mine is off unless needed. Always switch it manually even when hvac is on auto.
Old 10-28-2013, 06:02 AM
sburke91 sburke91 is offline
Mein Auto: '11 X5 50i, '04 HD VRSCA
Is there any variant of the 'auto' mode where the system will automatically determine (via temp/humidity delta) when to turn the AC on/off?
Sean Burke
2011 X5 50i
2004 HD VRSCA
Old 10-28-2013, 10:27 AM
xx xx is offline
Mein Auto: E83 X3, F25 X3 and F15 X5
yeah, turn the temperature up a little.
edit: be sure the controls for the rear passengers isn't set to something really cold.
E83 X3 | E70 X5 (sold) | F25 X3 | F15 X5
Old 10-28-2013, 06:53 PM
bimwad bimwad is offline
Mein Auto: '09 750i, '10 X5, '11 RR
I leave my AC on year round. I have never had to recharge an AC either as I believe usage it better than non-usage. I don't notice a big drag on the engine with the AC on either so I don't believe it causes any issues.
TIA
Mohamed
'05 E53 X5 3.0 | Premium | Rear Climate | Xenons | Privacy Glass
'09 F01 750i sport | premium sound | CWP | Rear Wood Shelf | BT Audio
'10 E70 X5 xdrive30i sport | rear shades | rear climate | iPod/USB | Sat Radio | DVD in Motion activated
'13 328i drive | premium | heated| executive | privacy glass |HUD
'14 F10 550i M Sport | premium sound | CWP | Rear Shade | BT Audio |HUD
'16 K1600GTL Exclusiv
Old 10-29-2013, 03:44 AM
Advocate Advocate is offline
Mein Auto: X5 35d, Z4 3.0i
I leave mine on all year too. Even in foul Winter weather in the Northeast, the windows clear and it helps evaporate some of the moisture that builds up in the interior.
Old 10-30-2013, 09:09 PM
DeanLinAZ DeanLinAZ is offline
DeanLinAZ
Mein Auto: 2011 X5 35i Sport Act.
My A/C has been switched on continuously since we picked up our X5 at the dealership on September 6, 2011. BTW, the compressor only operates when the cabin temperature calls for it. The magnetic clutch lets the compressor rest otherwise.
DeanLinAZ
2011 X5 Sport Activity, Saph. Black/Oyster, M Sport, Technology, Convenience, Access, Sound, Side Camera
Previous: 2008 535i, 2001 740iL (euro del)
Old 10-30-2013, 11:10 PM
ard ard is offline
Resident Curmudgeon
lol?
when the air is heated it can hold moisture- simply as the temperature is changed water molecules move into and out of the air.
In a car, you have a cabin of moisture laden air - remember the warm air has blown over wet shoes, melting snow, etc....then you turn off the car and everything cools. And the moisture deposits into the interior of the car.
lol indeed.
Old 10-30-2013, 11:32 PM
1 for all 1 for all is offline
Mein Auto: 1 Series
I live in the DC area, which is a swamp, even in the cooler months. A/C 100% of the time to keep windows clear, to control humidity and odor, and to prolong the life of the A/C itself. #1 cause of premature A/C failure: lack of regular use.
Old 10-31-2013, 06:13 AM
Kamdog's Avatar
Kamdog Kamdog is offline
<- Bailey
Mein Auto: 2008 535i
I leave it on practically all the time, unless it is a bit warm, not hot, and I want to run with wide open windows.
535i, Monaco, Cream, Light Poplar, Comfort Seats, PP, Nav, ED.
Old 10-31-2013, 08:00 AM
Mein Auto: X5
lol?
lol indeed.
You do realize when you heat cold air, you don't add 'moisture' to it and the humidity drops since it's relative? Yes, warm air can absorb more moisture and hence drying it helps to fight condensation, hence a/c is turned on during the windshield defrost cycle. And yes, when warm air with more absorbed moisture gets in contact with cold parts, you'll see condensation.
But if you turn on A/C when it's below freezing temps outside, what do you think happens to a/c components before the engine compartment and cabin warm up?
Old 10-31-2013, 09:39 AM
ard ard is offline
Resident Curmudgeon
So.. yes, just taking a volume of air without any external influences and changing the temerautre up or down will not 'change the moisture content'- the RH changes, but not the actual mositure.
But we are talking about a car, right? Not a high school physics class...
Glad you agree that the AC running can pull moisture out of the warm air, allowing it to condense out and drain.
Now, you last question.... I actually dont know what will happen. After all, modern AC systems have pressure and limit swtiches, and the old "it will freeze uo" situation ended in the 1970s. I suspect the BMW system will look at internal, external and coolant temeratures (all three) and make decision about when to engage the AC compressor to achieve the temp desired AND provide some dehumidiifcation.
Say, after typing this I'll try and find that BMW tech manual on E70 HVAC if it is around the web....
A
Old 10-31-2013, 10:21 AM
Mein Auto: X5
In a car such as E70 with any kind of air circulation your body heat and expiration aren't significant enough to affect the cabin humidity to the point it becomes an issue (not to mention leather and dryness don't like each other.
But yes, please find and read an E70 HVAC manual to see how far advanced modern a/c units become that laws of physics don't apply anymore and can be ignored.
Old 10-31-2013, 02:21 PM
bkhk bkhk is offline
Mein Auto: 2015 Alpine White F80 M3
Leave it on always. If not you will get that stale water smell from the system as moisture is left in there when turned off or not used.
Old 10-31-2013, 06:56 PM
ard ard is offline
Resident Curmudgeon
http://www.bmwmotorsports.org/pdf/e7...%20Systems.pdf
1. I never said your body and expiration are the cause humidity- you posited that so you could then knock it down as if it were my argument. You get moisture inside from warm air passing over wet: shoes, clothes, floor mats, melting snow.
2. I am not understanding the 'laws of physics' argument....
Read the document.
The system will turn on the AC compressor when it needs cool air or needs to dehumidify. It apparently has a sensor that will detect condensation on the glass before it is visible to the user...
IMO the old 'robs power' and 'uses more gas' is a thing of the past with non-variable compressors. Just MHO
A
Old 11-01-2013, 07:39 AM
Mein Auto: X5
The system will turn on the AC compressor when it needs cool air or needs to dehumidify....
Precisely - even if you press A/C button and have that green light on, A/C won't work in many if not all winter conditions (if we talk about real winter, i.e. close or below freezing temps, not say the San Diego type winter). So even if you think you're protecting your interior components - and again, who in their right mind intentionally subjects leather to ultra-dry processed air?? - in reality in winter it's moot.
Old 11-02-2013, 06:21 AM
What is winter? I use my AC all year round.
Old 11-03-2013, 08:10 PM
Toneaero Toneaero is offline
Mein Auto: 2008 Harley FXCWC
My idle RPMs drops a little bit when I switch off the compressor. Thats why I leave the AC off when I don't need it.
Old 11-04-2013, 03:20 AM
TinyRK's Avatar
TinyRK TinyRK is offline
Ja mei!
Mein Auto: X5
BMWCCA Member# 481324
Old 11-04-2013, 04:28 AM
Tiny RK
Are you OK? I have no idea what your picture means. Please translate for me as I must be thick.
