EGR Cooler Problem or Valve seals ? - Bimmerfest - BMW Forums
Old 10-29-2013, 03:32 AM
Khemy Khemy is offline
Mein Auto: x5,525i
Hi guys , really need your help with identifying my problem . I have an e70 2007 x5 Diesel.
a) After approx 5 minutes of idling , whitish smoke is discharged from the exhaust. After cutting off the smoke takes about 2 minutes to stop.
b) The smoke smells. I have read about this being smelt in the cabin but i DONT have a cabin smoke problem.
c)I have a Right hand Drive . If i pass my finger in the Right side exhaust , it is a bit "wetter" with black residue. The left side is more powdery but black
I have read many posts about the EGR Cooler being the problem but i am not getting cabin smell.
Any suggestions of causes or possible solutions will be greatly appreciated. Thanks in advance.
Old 10-29-2013, 07:06 AM
Mein Auto: x5,525i
Any ideas on my problem ?
Old 10-29-2013, 08:42 AM
ard ard is offline
Resident Curmudgeon
what does this mean? 'cutting off'?
You turn the car off and for two minutes white smoke billows from the exhaust?
How is you coolant level? Any chance you have a coolant leak into the combustion chambers?
Old 10-29-2013, 09:12 AM
Mein Auto: x5,525i
what does this mean? 'cutting off'? i meant after switching off the engine the smoke usually takes approx a min to go away.
Also the vehicle has only done 35000 kms.
Old 10-29-2013, 10:56 AM
smyles smyles is offline
Mein Auto: X5
what's the status of the SCR system?
Old 10-31-2013, 08:34 AM
Mein Auto: x5,525i
BMW had a look yesterday and said that they believe that the intake manifold has to be changed. The vehicle was stuttering a bit when idling , which suggested to them that there is some sort of leak. This is what is contributing to the oil being burnt and smoke. Does this make sense ?
Old 10-31-2013, 09:41 AM
ard ard is offline
Resident Curmudgeon
Dude, you failed to respond to our specific questions, and are coming back asking more???
Do what you want. If you want opinions and help, then answer questions.
Old 10-31-2013, 09:55 AM
serge1's Avatar
serge1 serge1 is offline
Mein Auto: 2011 BMW X5 35D
Probably thinks "the bmw engineers" fixed the problem. After all they "believe" that was the culprit. From first try. No more need to answer miscellaneous questions on forum anymore.
Old 10-31-2013, 10:17 AM
ard ard is offline
Resident Curmudgeon
There is this paradoxical thing that happens with people and dealers, in that those folks that are totally ignorant** tend to accept what dealers say at face value- they shrug, and think "Well they are the experts" and open their wallets. On the other hand, people with mechanical skills tend to ask more questions. Those with good solid knowledge downright dont trust them to do anything.
You dont 'have a look' and decide to change the intake manifold. You look at the smoke, determine if it is coolant, look at the coolant levels, test the oil, etc, etc...before spending $4000. Hell, if you've been mixing oil and coolant, and the oil is contaminated and youve been driving for months, the engine may be toast- even if it is running. People that dont know, dont know what to ask dealers...who themselves are questionable, especially at outposts in far away places.
** (note- this is "not car people' ignorant, or 'not mechanically inclined', and not stupid or dumb, OK?)
Old 10-31-2013, 11:40 AM
Mein Auto: x5,525i
Sorry , the only question i did not answer is about the "SCR system" ! Only because i have no clue about it. I am new to the vehicle and not very knowledgeable about the mechanics of the vehicle .
Also i may have missed this but the coolant level is always full.
Thanks for your comments.
Old 11-01-2013, 01:23 PM
lpcapital lpcapital is offline
Send a message via AIM to lpcapital Send a message via MSN to lpcapital Send a message via Yahoo to lpcapital
Mein Auto: Wasp & Duc
You don't have an SCR (selective cathalist reduction - or horse-pee): this was first implemented in 2009 in the US model. You have an 07 which is a ROW/EU model so no SCR.
You also only have the high pressure EGR, which is the harmonica looking thing in the front of the car (the double EGR was first introduced by BMW in the US); if the coolant is fine than it's not that leaking (or something else for that matter).
As far as the leaking intake, the only thing i'd say is that because of the EGR which works at idle, you should be smelling diesel or see little puffs of smoke if you open the hood or you should see areas where the soot leaks out. I'd start carefully inspecting that, starting with removing the plastic engine cover, and maybe give it a wash so any leak is more visible. Nonetheless it would stink like diesel in the engine bay... And not just lightly
The other thing that comes to mind is a leak from one of the seals on the turbo: it's just a S.W.A.G. but it wouldn't be unheard of...
Old 11-04-2013, 05:53 AM
Mein Auto: x5,525i
Thanks for taking time to reply. Much appreciated. Will have an update for you soon. Hopefully we can get to the bottom of it. Thanks again.
Old 01-02-2014, 06:40 PM
mfk mfk is offline
Mein Auto: X5d
fwiw, I have 4000 miles on my 2013 x5d. I got a reduced power error for about 30 seconds then it was gone. I took it to the dealer and they said it was the egr valve and replaced it. The service manager said they have seen a few of these recently.
