E34 (1989 - 1995)
Old 10-08-2009, 12:26 PM
Michael P Michael P is offline
Mein Auto: 1994 & 1995 Bmw 525I
No Power to Fuel Pump 1995 525
I am new to this forum. I have owned Bmw's since 1989. I currently own 2 today and the problem one is the 1995. My shop manuel was stolen so I am sort of blind. Last week thursday turning a corner my 1995 525 died. It would start but acted like no fuel going to engine. I replaced the Fuel Filter.
It still would not run for very long and would die. I checked voltage to fuse and had crank voltage to the fuse panel. I checked voltage to the fuel pump and Had NONE. I cleaned the connector, then let it dry and re-checked voltage, NONE. I placed my meter probe into rear of connector and NONE. The upper 2 tongs did have minor .2 and .3 which I believe is the signal switch voltage for fuel reading.
I saw in the electrical diagram that the relay had a wire behind as well as in front of fuse block so I pulled all three relays from my 1994 (not knowing which of hte three it was) and placed all three into my 2005. I still have no Voltage to the Fuel Pump.
What is real bad is that My 1994 Bmw just 1 day later (Last Friday) had the fuel pump go out. I will recieve the new one today. So, I have been testing between the 94 and 95. I had voltage to the connector in the 94 but not voltage to the connector in the 95 except minor voltage in upper tongs reading about .2 to .3 which I believe is the signal switch voltage.
Any help would be appreciated. to summarize; I have cranking power to fuse block and no cranking power to the fuel pump connector for fuel pump.
Thank YOU for any help, 2 cars down is afirst for me in over 45 years.
Old 10-08-2009, 01:33 PM
woodnthings8's Avatar
woodnthings8 woodnthings8 is offline
Mein Auto: 1995 525i olympics editio
So have you checked the fuse F23? Also the fuel pump relay you said you were not sure as to which one. Were you in the E-Box on the R/H fender or in the main P90 fuse panel? The Fuel pump relay is one of the three in the E-Box. The other thing to consider is the ECM. When you turn the key to run the fuel pump should start and build pressure. So the ECM may not be sending the signal to turn on, I would bet it is a fuse or relay though. You should be able to read the relay power supply and the signal power to see if it is one of those.
1995 E34 525i Olympics Edition Oxford Green Metallic
2008 E63 650i Black Sapphire Metallic
1994 E34 525i Alpine White- SOLD
2007 E90 335i Sapphire Black- SOLD
Old 10-09-2009, 10:44 AM
In the E-Box it is the middle relay(Fuel Pump)
Old 10-09-2009, 03:40 PM
Thank YOu for your Reply,
I checked and also replaced fuse incase it was to old. I also took the Relay's (all 3) out of my 94 525 and placed them into the 95. The 94 runs perfectly now with a new fuel pump but 95 still won't start with no power to fuel pump connector. I had both cars go down within 12 hours of each other.
Thank You
Old 10-23-2009, 12:36 PM
Shizbomber Shizbomber is offline
I just had my 1995 525i do virtually the same thing this morning. After letting it sit for 30 minutes it started and kind of sputtered for 30 seconds then died. I am hoping it is just the filter. Was the filter a major job to change? I have changed fuel filters on other vehicles but am new to BMWs and have never worked on one before. Is there any decent info that you know of on the www as to how to replace it? Thanks.
Old 10-23-2009, 03:45 PM
Jack the rear end up high enough you can get under the forward part of the tank by the passenger tire. Once secured on stands, just loosen the clamp on the filter and hoses. The fuel line will have a little pressure in it but I usually pinch off the hoses with locking pliers. Easy deal to do with only basic tools.
Old 05-22-2010, 11:14 AM
evrtimdy evrtimdy is offline
Mein Auto: 525i
fuel pump down sorry but tese 525s are junk
Can anyone Help! My 525 is getting no power to the fuel pump my relay is new and the fuse is new. whats confusing me is i just replaced the fuel pump too. and there is no power even going to the fuel pump fuse when use the test light. i fear my problem is simple and iv already spent way too much fixing it any ideas. Please Help!
Old 05-22-2010, 12:04 PM
jbh1989 jbh1989 is offline
Mein Auto: '93 E34 525iA
How are you guys testing for power to the fuel pump? Do you have someone cranking while you probe the connector?
VIN-P 525iA
ASE Certified. BMW Specialist
Old 10-24-2013, 08:31 PM
jacrex1 jacrex1 is offline
Mein Auto: 1994 BMW 525i sportwagon
no power to fuelpump
same problem....yes , someone is checking while cranking .
Old 11-01-2013, 05:29 PM
jnrlaw83 jnrlaw83 is offline
"I wanna go fast"
Same problem
I checked fuses relays, changed fuel pump, changed DME, Crank sensor reading over 500ohms but I'm not getting any power to the fuel pump or the fuel pump relay for that matter.... even changed the main relay! I've also searched everywhere I can... I have the service manual and the electrical service manual and I believe I'm missing something but I don't know what! and I have all but given up
Old 11-01-2013, 05:46 PM
E34ZombieHunter's Avatar
E34ZombieHunter E34ZombieHunter is online now
Nothin like an E34
Mein Auto: 95 540i B/B
You should no start checking wiring if everything else is eliminated
Gotta love an E34!!
If you want to get junkyard parts remember one thing, if it was wrecked you know it was running/driving. You may not know how well, but it was.
READ THE STICKIES AT THE TOP OF THE PAGE!!
STOMP TEST
READ ME IM THE BIBLE
FAN CLUTCH
LOCKS
ANGEL EYES
Audio
E28 v. E30 v. E34
Old 11-01-2013, 06:06 PM
"I wanna go fast"
checked the wiring from the DME to the relay and it has continuity. Jumped the fuel pump relay and the fuel pump runs tested the relay and it tested good... even changed it and no luck.... checked the wiring diagram on the electrical service manual and checked the related wire no luck.... it's just funny that during my web search i found a few people
with the same issue but no documented fix!
Old 11-01-2013, 06:40 PM
Nothin like an E34
What about the crash relay?? It cuts the power to the pump. As in it controls the fuel pump relay and will not let it send power to the pump. Give me a second to fund it in my Bentley.
Edit----So you f/p relay is in the box on the passenger side, the crash control unit is in the fuse box on the driver side, i have attached a diagram.
Gotta love an E34!!
STOMP TEST
FAN CLUTCH
LOCKS
ANGEL EYES
Audio
E28 v. E30 v. E34
Old 11-01-2013, 07:19 PM
"I wanna go fast"
thank you sir I'm going to check that when the sun comes up! i don't know how i missed it.... but I'll look into it.
Old 11-02-2013, 07:59 AM
Mamij Mamij is offline
Banned
Mein Auto: BMW 320i M52 1996
If the pump runs when the relay is jumped (the engine should start with the jumped relay, check that), and the relays are good, then the issue is the fuel pump relay socket's contacts and the wires underneath. They get pushed down when a relay is pushed in on them, and contact is lost. Jumping it makes this less likely to happen, as you are watching directly.
Easy fix. Remove relay. Slide up socket gently as far as the wires will allow. First clean upper contacts with contact cleaner and a toothbrush. Blow dry. Then, look at the wiring under the socket. Push it up and into the socket with a toothpick. Ideally, use clear silicone sealant on the bottom of each contact to keep it pushed into the socket. This is a long term solution - you don't want this problem to reappear later through muscular driving. Let it dry, affix the relay and check to make sure the underwires hold, slide the socket back into the holder, reinsert the relay and start the engine.
[ Btw, the same method should be used to bulletproof the car's low and high speed aux fan relays, if wire slack at the slack permits. If slack is insufficient, a thin cable tie or rubber band is your Plan B. These relays are essential aspects of the car's cooling system. ]
Welcome to the best!
Old 11-02-2013, 08:13 AM
"I wanna go fast"
Question
Thanks I will also check that.... Quick question though, my crank sensor measured 512ohms and I read in Bentley that that was in spec but I read some where else that it should be closed to 1250ohms... I checked a new sensor and it read 500+ ohms... So now I'm confused about the crank sensor.
Old 11-02-2013, 09:01 AM
Nothin like an E34
Yes, the Bentley is wrong idk off the top of my head the spec, but someone will chime in with it.
Gotta love an E34!!
STOMP TEST
FAN CLUTCH
LOCKS
ANGEL EYES
Audio
E28 v. E30 v. E34
Old 11-02-2013, 04:29 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
Correct reading should be 540 +/- 10%.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 06-24-2015, 01:38 PM
DrDIAS DrDIAS is offline
Mein Auto: 540ia 1998, 525ia 1995
Question E34 1995 Fuel pump in Plastic fuel tank!
E34 M50 1995 Fuel pump in Plastic fuel tank!
I am having a problem on how to remove the fuel pump from within a plastic fuel tank!
The sending unit comes out easily, there are two fuel lines leading back down into the tank.
How do you remove and/or find the fuel pump hold down clamp within the plastic fuel tank?
Also there seems to be a different Fuel pump used for the Plastic fuel tank which is Suction device with pump BMW Part# 16 14 7 161 387
The Bentley Manual only shows removal for the Mental tank and fuel pump!
My fuel tank has the same lock ring BMW#16111181142 holding the fuel sending unit BMW#16141179798 in place on the plastic fuel tank.
See URL noted below:
Please reference URL: http://bmwfans.info/parts-catalog/E3...stic_fuel_tank
Yes, this is an European model.
I live in Panama City Panama.
Any and all help and assistance is highly appreciated!
Best Regards,
Ron
Old 06-24-2015, 02:57 PM
TheEinstein's Avatar
TheEinstein TheEinstein is offline
Mein Auto: E34 540i
In the diagram you reference, there are two vertical plastic tabs on part #16. One right in the foreground and one opposite of it barely in view. Squeeze those two tabs together and that entire holder should come out with the pump.
1995 E34 540ia
160,000 Miles
VIN# ...GF32404
Hellrot Red
Fuelly
My Basic Repair History (Edited 1/27/2015)
Ongoing comparison between two E34 540ia's
OBC4 Hidden Functions : Link
Old 06-25-2015, 05:38 PM
Fuel pump problem fixed, now auto trans shift problem
Thanks to "TheEinstein" for the information about the plastic tabs on the fuel pump holder.
I had to drain over eight gallons of Petrol out and then was able to get to it with little difficulty.
I had my Electrical Mechanic look at it, he happened to have a new fuel pump, after dissembling the old fuel pump assembly and replace it with the new fuel pump which by the way looked identical to the one inside the fuel pump assembly. Then reassembled the fuel pump assembly, and then reinstalled it without problem! Then started the BMW without any problems!
My Original problem before the fuel pump issue was that the "Flex Disc" on the drive line had ripped apart!
After replacing with a new "Flex Disc", the Fuel pump issue happened!
Now the automatic transmission will not shift into gear. It now starts in Park and neutral, yet will not shift into any of the drive grears or reverse gear. Nothing had changed before the "Flex Disc" replacement it was shifting before without problem! There are no signs of any ATF lost!
Any suggestions?
By the way I cannot find the plug that is used to put in ATF into the automatic transmission, I had the car jacked up and could not find the filler on the automatic transmission.
Again thanks for the heads up on the Fuel pump problem.
Old 06-25-2015, 07:15 PM
Mein Auto: E34 540i
Create a new thread out of your last post here. It will be much more readable from a topic standpoint. More info the better. Car year model, engine model/series, and problem stated pretty much as you did. What happened, what you did, what it's doing.
1995 E34 540ia
160,000 Miles
VIN# ...GF32404
Hellrot Red
Fuelly
Old 01-22-2017, 12:03 PM
Beemer8135 Beemer8135 is offline
Mein Auto: 540i
Hey All, Hello from the land of the ice & snow (Canada) lol
I too have an issue relating to my fuel pump, In Nov, I had a "crank, no start issue" for the first time, I let it sit for 10 min's , tried again, and it was good all day, The next day...Nothing, Checked the relay(good), fuse(good), power at the sender(nothing),
I changed the pump just in case, I'm suspecting the sender.
Anyone else with this issue in the past ?
Thank you in advance
Old 01-22-2017, 12:14 PM
BMR_LVR's Avatar
Humble E34 lover
Sounds like the common crankshaft position sensor failure. You could try squirting a little starting fluid in the intake while cranking the engine over. If it fires, then you have a fuel delivery problem. If it doesn't, then it's likely the CPS. You can check it with a multi-meter. The instructions are in the Bentley manual. Note however that the specifications in the original version of the Bentley were incorrect. They put out a correction that shows that the CPS should read 540 ohms +/- 10%. Hope this helps and good luck.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 01-22-2017, 01:19 PM
Mein Auto: 540i
That's perfect, I'll check it out and let you know what I find.
Cheers
Sent from my iPhone using Bimmerfest mobile app
