Go Back   Bimmerfest - BMW Forums > Everything Else > Site Feedback / Questions / Suggestions > The Test Board
The Test Board
Test your sigs and everything else here.
Old 11-03-2013, 07:11 PM
Brucifer325's Avatar
Brucifer325 Brucifer325 is offline
Team Zippy
Mein Auto: 2000 328Ci
Scan
# ERRORS IN UNITS
Unit BMWTNR HW SW-FSW ERRORS / SHADOW-MEMORY
DME -> 7.500.255 15 E3 1 error / 2 errors
EGS -> 1.423.886 29 57 1 error
EWS -> 6.905.670 03 08 no errors
ABS -> 6.750.536 02 32 3 errors
LEW -> 1.094.142 06 02 1 error
A/C -> 6.902.440 21 05 no errors
SRS -> 6.905.491 01 05 no errors
IKE -> 6.902.379 07 16 1 error
LCM -> 6.901.433 08 13 no errors / 5 errors
ZKE -> 6.904.489 11 15 2 errors / no errors
MFL -> 0.000.000 01 07 no data
AIC -> 8.382.468 04 13 no errors
RAD -> 6.921.963 45 50 no errors
SZM -> 8.379.749 01 01 no errors / no errors
SHD -> 3.861.939 05 31 no errors
SPMFT -> 8.386.427 02 01 no errors / no errors
SPMBT -> 8.386.427 02 01 no errors / no errors
SMF -> 8.263.133 07 0B no errors
# ERRORS DETAILS - DTC(hex)/PARAM(hex)
DME -> 08/B2 - Signal, air-mass flow sensor
Shadow-memory:
7F/02 - Activation, solenoid valve, suction-jet pump
EGS -> 92/20 - CAN Moment interface
ABS -> A5/FE - Pressure sensor 1 electrical failure
B1/FB - Preload pump electrical failure
A6/FE - Pressure sensor 2 electrical failure
LEW -> 09/B5 - No CAN message (ASC)
IKE -> 11/44 - Thermal oil-level sensor
LCM -> Shadow-memory:
33/01 - Sidelight, front right
38/01 - Sidelight, front left
3E/01 - Rear fog light faulty
3F/23 - Turn indicator, rear left
40/23 - Turn indicator, rear right
ZKE -> 07/3F - Anti-theft alarm system: Siren, Radio interior protection, Tilt alarm sensor or Wire STDWA Short circuit to ground or Open circuit
41/21 - Anti-theft alarm system: Tilt alarm sensor
# SCAN END
