Old 11-02-2013, 11:26 AM
jwrape jwrape is offline
Mein Auto: 96 Z3M (M S52 conversion)
Carpet got wet and car won't start
2008 BMW 650i convertible. The top was left down and the interior got wet. What is in there that would prohibit it from starting?
96' Z3 M Conversion. 98' M3 S52 tranplanted into the little beast
Old 11-02-2013, 01:56 PM
645/333's Avatar
645/333 645/333 is offline
Michael
Start with fuses and relays, you don't say if the car will crank over???? You need to supply some more symptoms !!!
Old 11-03-2013, 10:05 PM
Yorgi's Avatar
Yorgi Yorgi is offline
There are a few modules under the seats but I can't see those preventing the car from starting if they were water damaged. You might have a short somewhere in the harness due to the water. Try drying out the car completely, I would remove the seats (4 bolts) and pop off the rear seats (lift straight up). Scanning for codes should give you some ideas too.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 11-04-2013, 04:20 AM
RooK77 RooK77 is offline
Mein Auto: 645i
As seen in previous threads a wet car can take several days to completely dry out.
