Old 10-19-2013, 06:44 AM
P11SCL P11SCL is offline
Mein Auto: BMW X3 3.0i Sport
Warning lights!
Ok now I'm getting pi55ed off with this car!!
Got the expansion tank fitted so that's sorted but now I was just driving and all of a sudden the ABS, Tyre pressure, 4x4 and brake warning lights are all amber!
Car seems to be driving fine but really not sure what's going on!
Old 10-19-2013, 11:04 AM
TJPee07 TJPee07 is offline
Mein Auto: 2006 BMW X3
Warning lights!
Have you checked your battery? Just went through a similar spell, and the odd faults were due to diminishing voltage.
Old 10-19-2013, 11:29 AM
Warning lights!
I have a volt meter and it was showing 13.9v when running. Maybe take it to kwikfit and get them to do a test. The car only gets used for short journeys and when it overheated it was on ignition for a lot of the time without the engine running,
You think that could be the problem?
I just took out a warranty yesterday on the car, but I fear they may think I'm at it!!
Old 10-19-2013, 01:18 PM
Warning lights!
I have read on this forum before that short hops are tough on the battery--but perhaps that holds true for any car. I honestly don't know.
Old 10-19-2013, 04:05 PM
Warning lights!
Just going to wait till Monday and see what the warranty company says and see where we go from there
Old 10-19-2013, 05:38 PM
Supercourse Supercourse is online now
Mein Auto: 2004 X3 2.5i
Originally Posted by P11SCL View Post
.... The car only gets used for short journeys
Some cars can take that - but BMW's prosper on vigorous exercise.
....... it was on ignition for a lot of the time without the engine running,
Yes.
Battery is weak. You should get a reading of about 14.2V - 14.4V when running.
13.8V immediately after shutting it off, and then 12.6V - 12.8V when it has rested a bit.
That would explain the Brake, ABS and 4x4 lights.
Not sure about the flat tire warning - that might be for real.
Old 10-20-2013, 04:46 AM
Warning lights!
Just got the battery checked and the battery came back fine.
Tried to see if I could hear the clicking noise from the transfer box but it's silent.
Was thinking it could maybe a wheel speed sensor?
Would explain abs and 4x4 lights and also the low tire pressure light.
Looks like I will have to take it to bmw :0(
Old 11-05-2013, 10:24 AM
Warning lights!
Car fixed at last, all it was was a rear wheel speed sensor (abs)
Thanks everyone for the help
