Easy to change Rear diff and transfer case oil - Bimmerfest - BMW Forums
Old 03-08-2010, 10:15 PM
humbertob humbertob is offline
Send a message via MSN to humbertob
Mein Auto: BMW 335i N55
Thumbs up Easy to change Rear diff and transfer case oil
Tonight I just changed my rear diff oil as well as the transfer case oil. Was so easy to do it, never imagined that I would work on a bmw. The harderst part was to almost dissasembly the tire carrier to get access to the fill plug on the rear differential, a little time consuming. I used the OEM BMW oil for the Transfer case and red line 70-90 for the diff. Very happy finding out that I can work on my bmw, the only doubt here is how to change the front diff oil, I'm still thinking how to get to the fill and drain plug without dissasembling other important things, any advice ? Next DIY proyect will be ATF flush. Thanks to all for this great forum !
2013 BMW 335i Sport
2011 BMW 335i Performance Power Kit (Son's)
2009 BMW X3 (Wife's)
Old 03-08-2010, 10:34 PM
Mein Auto: 2004 X3 2.5i
How did the color of the old fluid look compared to new?
The transfer case looks easy - I may do that this summer.
Hardly necessary to even raise the vehicle.
Might just drive onto 4 pieces of 2x10 lumber to gain an extra 1.5" rather than mess with 4 axle stands.
Did you find the transfer case capacity was only 1/3L or just over 1/2L - I have seen both quoted?
With fluid that costs $45/L or something, you don't want to be spilling any.
I figure the transfer case has a harder life than the 2 diffs., so it gets priority in maintenance.
Old 03-09-2010, 04:32 AM
kenza kenza is online now
Mein Auto: 2007 X3 2.0d MT
Humberto, did you take any pics?
Old 03-09-2010, 06:01 AM
thayerV thayerV is offline
Mein Auto: 2009 X3 (mt)
I'm pretty sure they deleted the drain plug on the LCI models. We will have to suck it out through the fill hole. Mike Miller talked about it in Bimmer magazine. He doesn't like it and neither do I.... But it is what it is, so I'm going to curve a piece of copper tubing so I can suck out as much of the old out as possible when I do mine.
Note how they switched covers in the E83N which takes one plug where the older E83 takes two.
http://www.realoem.com/bmw/showparts...93&hg=33&fg=10
http://www.realoem.com/bmw/showparts...75&hg=33&fg=10
Old 03-09-2010, 07:30 AM
Smile
Supercourse: You don't need anything to raise the X3 up for the TC oil change, clearance is OK for a normal person. The fluid compared with the new one was so dark, I think this is the first TC oil change for this X3 in 60K miles. The rear diff oil was almost new, compared with the color of brand new oil. I think the rear diff oil was changed not so long ago, but anyway I didn't know so just flushed and changed it. The TC took a little more than 1/2 bottle of OEM BMW TC oil from Bavarian Auto (www.bavauto.com) and yes it cost me like $50 including shipping for just 1L bottle. Now I'm just figuring out how to change the front diff oil and next DIY project will be the TRANS Flush. I'm planning to keep this X3 for a long time so all the fluids need to be changed. This coming saturday I'll flush the power steering fluid. Thanks all for your help in this great forum. God Bless you all !
2013 BMW 335i Sport
Old 03-09-2010, 09:08 AM
Humberto, take pics for a DIY
Old 03-09-2010, 09:26 AM
Sorry kenza, It's so messy to take my camera out while doing this, I'm a Pro Photographer also, so my equipment is expensive to get oil on it, but next time I'll do my best to capture images with my wife's Point and Shoot for sure. Thanks !
2013 BMW 335i Sport
Old 03-09-2010, 10:30 AM
Humberto, Point&Shoot should be more than enough. Thanks
Old 03-11-2010, 10:49 AM
bmwadam bmwadam is offline
Long LIVE ZFHP22!
Mein Auto: 2006 330i 6MT Sport
I did this job 2 wks ago. I changed all driveline fluids at 50k. Changed my 6-speed manual gearbox fluid, front and rear diff, and transfer case. Went with redline products on everything except the transfer case, which I used the OEM stuff from Bav auto. The front diff was not hard. I had to drop a splash cover. I used a drill pump attached to an air compressor to pump the fluid into the front diff. fill hole. I also had it up on a lift which made it a piece of cake!
BTW the redline stuff is 6 bucks a liter, I think the diffs take just over a liter on capacity or maybe almost 2? I cant remember.
I'm sorry I didnt take any pictures, BUT the front diff was easier than the rear diff. The splash pan came off much easier than that dang spare tire carrier!
The DIYer BMW rant:
Cursed plastic impailor waterpumps, plastic bleeder screws, m20 timing belts, anti rattle clips, window regulators, CDV valves, digital odometer displays, evaporative emissions circuit, aux cooling fan, sunroof drains, heator cores, door seals, control modules, M62 cam covers and of course GM autos.... (more to come)
Old 03-11-2010, 11:10 AM
My X3 is Auto, but I still can't find a way to remove the drain bolt from the front diff, I'll try again to look at it next weekend. At this time I have changed almost all the fluids on mine: Engine Oil, Rear Diff Oil, transfer case oil, power steering oil. Just want to change the front diff oil and the brake fluid, but I don't know how yet !
2013 BMW 335i Sport
Old 03-11-2010, 11:32 AM
Long LIVE ZFHP22!
Hmm. I can take a look at it again this weekend and see. I'll try and take a picture and post it on here. In the meantime, good luck!
The DIYer BMW rant:
Old 03-11-2010, 12:39 PM
That's why I love this forum, always somebody is willing to help, thanks a lot bmwadam, if you can post a pic of your front diff I can compare it to mine, may be I got a different model on my X3, I don't know for sure ! Thanks a lot again ! Blessings !
2013 BMW 335i Sport
Old 03-11-2010, 02:08 PM
Originally Posted by humbertob View Post
... if you can post a pic of your front diff I can compare it to mine, may be I got a different model on my X3, ..
I think the diff. will look the same.
As bmwadam has a manual transmission, that's where the accessibility will be different.
Too many things coming out of, or going into, an auto. box compared to a manual.
Old 03-11-2010, 02:26 PM
That's what I'm thinking !!! Still figuring out how to change the fluid on the front diff !
2013 BMW 335i Sport
Old 03-13-2010, 07:59 PM
Well finally figured out and today just changed the front diff oil in our X3, really easy, just removed the 4 bolts on the bottom skid plate, and the access to the fill and drain bolts were so easy. The front diff oil were dirtier than the rear one so I think this is the first time this X3 get a front diff oil change in 60K miles, so great time to do it ! Thanks to everyone here at the forums. Blessings !
2013 BMW 335i Sport
Old 06-04-2010, 10:03 PM
Court M3 Court M3 is offline
Mein Auto: 88 M3
Did you ever get pics? Need to do this before mine goes into storage?
Old 07-04-2010, 06:15 AM
didymos didymos is offline
brum brum
Mein Auto: '04 X3 2.5
Seems I need to get three quarts to cover front and back differentials.
BTW: seems like our cars have similar mileage and I've changed coolant and it looked like it was time. Did you come around servicing the transmission?
Old 07-29-2010, 01:33 PM
Espen Lysholm Espen Lysholm is offline
Mein Auto: 2012 BMW X3 2.0DA
Diy
Hi,
Does anyone have a DIY guide for oil change with pictures for front + rear diff and xdrive case?
I have changed oil and filter on the automatic gearbox.
My X3 is a 2004 2,5IA.
Kind regards
Espen
Old 11-06-2013, 12:52 PM
neosimago neosimago is offline
nsmgo 2006 X3
Mein Auto: 2006 X3
2006 X3 Transfer Case Oil Change
Hello everyone,
My 2006 X3 just hit the 65k mark recently, and with the suggested maintenance schedule i have been reading, the transfer case oil was part of the suggested flush.
I did think about ordering the oil online, but picking it up at the dealer costed $90 for 1L, and I know I over paid, but i was wanting to get it done soon.
I just changed out the transfer case oil yesterday, and to my surprise it too just 1/2L, or 500 ml before it started dribbling out on the fill hole.
What surprised me was how much came out the transfer case when I drained it. It seemed just a tad, maybe 100ml more than 500ml in the drain fluid. I will be doing this when I hit $90k mi, so i'll use the remainder. Can anyone verify that this oil will be alright sitting in my garage for three years?
Old 11-06-2013, 12:58 PM
nsmgo 2006 X3
Mein Auto: 2006 X3
suggested Tool needed: 14mm hex
Here are the links to the drain/fill plugs on my 2006 X3 differentials:
here's the replacement plugs:
https://www.ecstuning.com/ES205597/
here's the 14mm wrench to make the job easy:
https://www.ecstuning.com/ES2162537/
Tell us how it went?!
Old 11-06-2013, 07:15 PM
cagui1223's Avatar
cagui1223 cagui1223 is offline
Mein Auto: 2007 BMW X3 3.0si [e83]
humbertob's post was back from 2010. This thread has long been dead.
