Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 8 Series - E31 (1989 - 1999)
Old 10-30-2013, 02:05 PM
Jolo Jolo is offline
Mein Auto: 2002 540 IT; 1997 840 CI
Front and Rear Windows Not Working
I have searched all the posts but cannot find a similar instance of both driver front and rear windows suddenly not functioning. My 840 ci window dropped an inch when I opened the door, but did not move up when I got in and closed the door. The windows remains open a crack and will not move when the window switch is operated. Ironically, both front and rear window are not operating, while both windows on the passenger side do operate normally. I do not see any fuses that are dedicated to the windows, and all fuses are in tact anyway.
Any ideas out there before I pull the door apart? And any hidden screws or clips that will prevent me from removing the inside door panel? Hopefully it will be as easy as my 5 series door panel removal.
Thanks in advance.
Joe
Old 10-30-2013, 09:55 PM
TerryY's Avatar
TerryY TerryY is offline
Old Fogey
Mein Auto: BMW '95 840
Ask over at http://forums.bimmerforums.com/forum...ries-%28E31%29
There are only a few 8 owners here and Many Many over there. Because they all quit working I would bet on the general module. But first have you tried the passenger door from the passenger side switch? The switches are data linked rather than direct wired.
Terry
Woodland Washington
'95 840Ci
'98 740i
'00 Range Rover Vitesse
www.wuffer.net
www.8coupe.com
www.8er.org
Old 11-04-2013, 11:08 AM
DavoTX DavoTX is offline
Mein Auto: F30 335i M '94 BMW 840ci
Thumbs up
Thanks in advance.
Joe
Is it just the windows or any of the other electrical failing as well? I had a similar issue sometime back and after trying every trick in the book I finally took out the General Module and had an electrical engineer check out the circuits - turned out there were 3 dead capacitors on the board - once replaced the power windows started functioning again. Might be worth a shot!
Old 11-09-2013, 08:06 AM
Wuffer Wuffer is offline
Mein Auto: 91 850i
Windows are controlled by fuses in the trunk, drivers side. Dont recall which fuse controls drivers side but should be obvious.
