Clicking/kaPop sound when shifting - Bimmerfest - BMW Forums
Old 11-05-2013, 09:57 AM
wordsmyth wordsmyth is offline
Mein Auto: 1998 BMW Z3 Roadster
Flex disk?
Ball or other joints?
Hanger bearing?
All three - or what?
I'm finally getting familiar enough with the car to differentiate sounds. I'm not sure this is normal.
Thanks in advance -
1998 Z3 2.8L 5-speed
If you insist on exercising a right to burn our flag, first be so kind as to wrap yourself in it and douse yourself with gasoline just before you strike the match.
Old 11-05-2013, 11:48 AM
Blacklane Blacklane is offline
Mein Auto: 1998 Z3 Roadster
It's not normal.
Manual or automatic?
Is the sound associated with the shifting action, or is it related, such as part of the clutch engagement or tied to acceleration or deceleration?
Does the sound come from under the car or in the back, such as the result of a broken suspension part or the dreaded differential mount failure?
Absent any other information and assuming it's a manual transmission, my first guess would be shift linkage bushings. You can look over this article: http://www.pelicanparts.com/bmw/tech...t_Bushings.htm
Old 11-06-2013, 04:56 AM
Thanks for the reply and for the link.
It's a 2.8L with a manual transmission.
Reading your post I see four points for evaluation:
shifting action
clutch engagement
acceleration/deceleration
location of sound
After thinking on it I believe I can isolate each step and make notes on the source.
It will be the weekend before I can get back into it and check all that, but I'll make notes and come back to the discussion.
Thanks again -
Old 11-09-2013, 07:53 AM
Okay, this morning I was able to take a 25 mile ride through the country and the noise seems to emanate from behind the driver's seat.
It occurs often, but not always, when shifting.
I can hear it at times when I accelerate/decelerate.
Old 11-09-2013, 08:38 AM
Sounds like the rear shock mount failure. Very common. Replace them with aftermarket ones from Rogue Engineering, Ireland Engineering, or others.
Old 11-09-2013, 09:18 AM
Roger that.
Lacking a detailed history of this car I am gradually building a list of preventative maintenance chores based on reading at multiple sources.
Granted, mechanical conveyances do not have a mind of their own, but some of the chores are all the same prioritizing their selves.
This one just got moved to the top.
