Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > E24 (1976 - 1989)
E24 (1976 - 1989)
The BMW 6 Series (E24) was the first variant of the 6 series produced by BMW from 1976 through 1989.
Old 10-22-2013, 11:31 AM
drseth drseth is offline
Mein Auto: 1998 Z3 2.8, 1987 L6 635C
Power Seat Backs not moving, motor running
Hi,
My L6 has these 12 way adjustable comfort seats and right now, neither seat back moves. The driver side seat would move on one side, and the other side stayed still. How do I fix this? Do I need new cables? If so, where can I get them? The motors are running when the switch is depressed.
Seth Anderson
Moon, VA
1987 BMW 635CSi L6
Old 10-22-2013, 04:30 PM
Got It Working
What I did was to remove the cables out of the housing and put some wadded up pieces of aluminum foil and reinserted the cable. The pieces keeps the cable from coming out of the worm gear on the sides of the seat. I found a post where the guy cut some coat hanger 1/3" or so and inserted that, but I thought the foil would be more forgiving.
Time will tell if it is a long term fix.
Old 10-22-2013, 05:58 PM
hornhospital's Avatar
D'oh, You Kids!
I like your tinfoil idea better. Hope it lasts a long time.
Quotes to live by:
BMW-CCA #441426
Old 10-31-2013, 03:01 AM
DVO.USA DVO.USA is offline
Mein Auto: 635csi 1988
Old 11-11-2013, 04:09 AM
Hey guys my headrest do Not work, everything else work. Any blue print, video or pictures how to fix it?
Diego
Old 11-12-2013, 07:05 AM
coolredlich coolredlich is offline
Mein Auto: 1993 bmw 525it
Short seat cable fix
I had the same problem of the cable being too short. My fix was to grab the ferule with needle nose pliers, heat it with a lighter and pull and it comes off. Then cut 3/8 inch off the end, use needle pliers to bend indents back, place back on cable, push indents back in with an awl. Works great.
Old 11-12-2013, 07:20 AM
Thank You so much my friend. I will try that this weekend. Did you removed the sit to do that?
Old 11-12-2013, 11:38 AM
I already had my seats out. I'm sure that they need to come out. Just remove the side trim and remove the gear box.. It might be a good idea to clean and lube the cable, mine were real gunked up. Do one at a time to make sure gears mesh properly.
