Old 11-13-2013, 10:07 AM
Mo A Mo A is offline
Mein Auto: 2008 BMW 528i
Sound on start up.
I Have a 2008 528i with 70k miles. I've notice that when I start the car a click sound comes on. Its hard to explain how it is, but right when I push the start it comes (like a ding). The sound doesn't come on all the time, but it does come on a lot. The car drives perfect no check engine no lights at all. I just want to know what could that sound be or what's causing it.
Thank you!
Old 11-14-2013, 10:14 PM
08Bmw528i 08Bmw528i is offline
Mein Auto: 528i
it sounds like my 2008 528i got the same problem
Old 11-15-2013, 12:09 AM
2chill's Avatar
2chill 2chill is offline
Mein Auto: 2008 528XI
I've been hearing that click as long as I've owned my car. It's probably an electronic module or some sort. It's normal so don't worry about it.
PP, CWP, NAV, satelite radio, USB, Folding Rear Seats.
Old 11-15-2013, 12:15 AM
Sound on start up.
Yeah it's weird
Old 11-15-2013, 12:16 AM
Sound on start up.
Yeah that sounds like it, and thanks for the help a lot!
Old 11-15-2013, 09:14 AM
pcy pcy is offline
Mein Auto: '06 530i, '07 C280, ML320
Source of the noise is throttle actuator.
To see if your car makes that noise, put the key in ignition (turn off radio, fan, to be able to hear that click noise) and turn the key to position 2, you will hear a click noise. That's the sound of throttle actuator doing a self check. Butterfly in the throttlebody turns a little and goes back to it's closed position. Due to age/degradation, 'play' develops in the shaft that connects the butterfly to the actuator; this results in that click noise.
I have verified this by removing the throttlebody from the car while the electrical connector still connected to the actuator and when I turn the key to position 2, I can see the actuator doing the self-check and I hear the noise from that actuator.
Old 11-16-2013, 08:41 AM
Mido2man Mido2man is offline
Mein Auto: 530i
Mine do that 2 and its the AC , if the AC off before you start the car it will do that . But if the AC is off it wont do it , not sure yours is the same problem or not , but its not big deal
Old 11-16-2013, 06:08 PM
UltimateDriving UltimateDriving is offline
Mein Auto: A Car
Could also be the transmission, i've heard the tranny make a click noise when i start the car.
Old 11-20-2013, 12:25 AM
Sound on start up.
Is that a big problem? Why would the trans make that sound?
