Old 11-12-2013, 05:25 PM
JimInDallas JimInDallas is offline
Mein Auto: 2008 528i
Installing Sirius Radio
Looking for recommendations on installing satellite radio into a 2008 528i. I've seen some aftermarket kits for sale. Is this truly a DIY or better left to a professional?
Any recommendations for the Dallas area?
Old 11-12-2013, 08:08 PM
wcr3d wcr3d is online now
Mein Auto: 2013 535iX M Sport
Do some more research, I was under the impression on the lci's it was standard issue, just inactive.
Old 11-13-2013, 03:43 PM
core22 core22 is offline
Send a message via AIM to core22
Mein Auto: F10 M5
Only very late model 2010's WITH nav had them there but inactive. I tried this and I'm an 09 build and was out of luck.
M5 (F10) | Alpine White | Black Merino | Fineline Anthracite
640i GC (F06) | M Sport | Sapphire Black | Amaro Brown Merino | Red Sycamore | M Performance Exhaust
535xi (E60) | M Sport | Platinum Gray | Black Dakota | Walnut | Dinan S2 | BMS DCI | KWv3 | Beyern Mesh
525i (E60) | Sapphire Black | Black Dakota | Walnut
Old 11-13-2013, 06:11 PM
bmwblack55 bmwblack55 is offline
Mein Auto: Bmw 528 i 2014
How do you find out if it is just inactive
Old 11-13-2013, 06:14 PM
schpenxel schpenxel is offline
DIY'er
Mein Auto: 2004 545i
If you don't have a CIC system (and you don't) then it's not there/inactive
You need to figure out if your car has sirius prep or not. If it does, adding it is very simple (basically just plug in a BMW sirius receiver + coding). If not, you have to add a loop to the MOST (fiber optic) system as well as some power wires, then connect sirius tuner + coding
You can buy a Sirius tuner on eBay. If you don't have prep you'll also have to add an antenna. The regular Sirius ones will work with newer Sirius tuners and you can hide them either under the dash or somewhere similar. the signal can go through plastic no problem
Old 11-13-2013, 08:42 PM
txag_530i's Avatar
txag_530i txag_530i is offline
Mein Auto: 2006 530i
I added the module to my car and had the dealer program it because 3-years ago I didn't know anything about coding. It is not a difficult project.
Old 11-14-2013, 12:57 PM
vadimr vadimr is offline
Mein Auto: car
Took me about an hour from start to finish, that included mounting it, reconfiguring most bust and coding it. Probably the easiest thing you can do if you car has the sat prep kit, if not, it will be 2 hours
