Old 11-13-2013, 06:15 AM
svre46 svre46 is offline
Mein Auto: 02 M3/07 750Li
Help with SOS error and Bluetooh coding.
My 04 545i came with a CIC retrofit and the original TCU from 03. Bluetooth was never enabled but I knew my TCU had it when I pulled my trunk liner. I decided to try and enable it. I have a few issues.
1) I enabled the bluetooth features in the TCU (TCUM) and successfully can connect, make calls, receive calls, voice commands work in NAV and for dialing ect. The mic however in the call does not work. All of the Trace files I see online are from the newer TCUs and look different than mine. Mine specifically is missing the line "USED_MICROPHONES wert_01" for example. Online with newer TCUs I see that this is there. I tried to add it and I get coding faulty error(I expected that). I figured coding would be different on a newer TCU.
2) I also now get the SOS error now. I did not have this before getting bluetooth 99% working. I have disabled everything I could find related in the TCU (TCUM) module. It is still there.
Ok I fixed the SOS error. Under SGM I changed verbau_telefon to night_verbaut and also uberwach_telephone to nicht_aktiv.
SOS button still works.
Any ideas? I will try to post my TRC file later today.
I was looking through NCS dummy and think there are a few things I will try to change tonight. I will post back results also.
In The Garage
02' ///M3 Vert AP||CPI||BREMBO||APEX||SE||AVIN||TTFS
07' 750Li Individual
16' X1 xDrive28i (Wife's)
Old 11-14-2013, 05:45 AM
Well,
I messed with the VO and re coded the modules below. Still have the warning. The SOS button itself works. I am thinking of maybe adding +TELD to the VO and re-coding KOMBI. I read that might work. I tried -TELD before but I am running out of options. Maybe I did it wrong and did not code that VO to KOMBI. As far as the speaker issue goes I will figure that out after the annoying SOS message.
Here are my Trace files if anyone can take a look.
In The Garage
Old 11-14-2013, 08:16 AM
fdriller9 fdriller9 is online now
Mein Auto: '06 AW 330xi
Yes you code +teld to VO and code lma and cas as well as tcu, cappl, CIC etc. any systems related to BMW assist.
Are you sure there is a mic installed? If the car didn't have bluetooth to begin with, there will be no mic installed.
| LCI Msport Conversion | Exotic Tuning Front Lip | H&R Coilovers | M3 Subframe Bushings | Custom Polyurethane Shore A90 Tension Strut Bushings | E93 M3 23.6mm Rear Sway Bar | UUC Front Sway Bar | Custom Heim Joint Rear Control Arms | Apex ARC-8 | Dunlop Direzza ZII Star Spec | Modified Dinan Cold Air Intake | aFe Oiled Drop-in Filter | Custom Hand-Made LED Angel Eyes | Alpine MRP-M500 | Custom LED Reverse Lights | OEM Blacklines | BMW Performance Trunk Spoiler |
Old 11-14-2013, 08:35 AM
Thanks,
There might not be a mic if there is more than one. Since assist worked, and all of the voice commands worked I thought it would be the same mic used. I followed the thread below and others have had success.
http://forums.5series.net/bluetooth-...ing-no-121586/
My main concern is the SOS error. I could really care less about Bluetooth at this point.
In The Garage
Old 11-14-2013, 01:59 PM
vadimr vadimr is offline
Mein Auto: car
Originally Posted by svre46 View Post
Thanks,
Pull the codes with INPA, what is it complaining about?
Old 11-14-2013, 04:12 PM
I am getting error 93f4 under the sgm. No communication with telefon.
In The Garage
Old 11-14-2013, 04:27 PM
Now just to get Bluetooth Mic working.
In The Garage
Old 11-19-2013, 12:30 PM
So guys with Bluetooth. Is the mic near the sunroof switch? Do you have two mics? One for SOS/Assist/Voice commands and one just for Bluetooth? I see no other coding I can do and from what I can read on one thread the car uses two Microphones for Bluetooth and Assist. Just want someone to confirm this. Either way I will tear into the sunroof panel after work and take a look. Hopefully I'm missing a mic and there is a plug. I can swap the two out and resolve my issues.
In The Garage
Old 11-19-2013, 12:52 PM
DIY'er
Mein Auto: 2004 545i
This is NOT correct for all E60's. My car did NOT come with bluetooth but still had two mics installed
Mine is a late 2003 545i that had assist & "telematics prep". It did not come with bluetooth from the factory.
Old 11-19-2013, 12:53 PM
DIY'er
There should be two mics. I can't remember which is which, but I THINK the mic for bluetooth is to the right side of the car. I remember thinking that it didn't make a whole lot of sense.. I can look it if up if you really need to know
I can confirm the bluetooth & Sos/assist use separate mics
Old 11-19-2013, 01:00 PM
No, no need. I appreciate the added info. I'm going to check to make sure it is there. Swap them to test functionality. Like I said everything works except no one can hear me when making calls. VR and everything else works perfect. So I could have a bad mic , a missing mic, or a faulty TCU. I had prep but for whatever reason car has a TCU from 03.
In The Garage
Old 11-19-2013, 01:01 PM
DIY'er
I bet it's a missing mic personally--should be easy enough to check at least
Old 11-19-2013, 01:08 PM
Yup! Thanks for the help.
In The Garage
Old 11-19-2013, 04:51 PM
Well definitely had a Bluetooth mic. Swapped it with the VR mic and the mic worked for VR still. Has to be tcu, wiring, or coding.
In The Garage
