helppp!!!!! - Bimmerfest - BMW Forums
Old 11-14-2013, 03:42 AM
jamesching jamesching is offline
Mein Auto: bmw 525i 2005 e60 sedan
helppp!!!!!
guys help me this morning all the sudden my remote wouldnt work...i can unlock or lock the car or start it at all...im getting so worried right now wtf is wrong!! why is this happening?! help please.
Old 11-14-2013, 03:55 AM
banglenot's Avatar
banglenot banglenot is offline
Mein Auto: 2007 530
Details?
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
BMW CCA Member 12+ Years
Old 11-14-2013, 04:16 AM
Those are the details .. I woke up this morning and I pressed start button. .wouldnt work then lock then trunk non worked then I unlocked it manually when I get inside the car I pressed the lock and unlock button on the car dashboard and that wouldnt even work. Put the key in the car wouldnt work either nothing starts
Old 11-14-2013, 05:08 AM
banglenot's Avatar
Mein Auto: 2007 530
OK. No starter click? No (or dim) interior lights, or very dim? If not, your battery has drained to dead. Get it jumped. Then see a dealer/indy to get it diagnosed.
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
Old 11-14-2013, 05:11 AM
What does getting it jumped mean
Old 11-14-2013, 05:17 AM
banglenot's Avatar
Mein Auto: 2007 530
Connect a pair of battery jumper cables to a working car, then to yours. Start the other car. Wait a minute. Start yours.
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
Old 11-14-2013, 05:28 AM
But then how longs that gonna last
Old 11-14-2013, 05:32 AM
Jay Arras's Avatar
Jay Arras Jay Arras is online now
Casual Fanatic
Mein Auto: 2007 530xi 6 speed manual
Follow the directions we're giving you. Once it starts, immediately drive it to a mechanic.
Old 11-14-2013, 05:50 AM
banglenot's Avatar
Mein Auto: 2007 530
Well, it can last a really long time, James. However, some choose to use the BMW Battery Booster System (TM), that comes with a towbar, a long set of jumper cables and a 1995 Toyota with a full tank of gas. The Toyota is permanently attached to your car, and the Toyota replaces the failing BMW battery.
Note that your gas mileage will be affected. Good luck.
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
Old 11-14-2013, 05:58 AM
pcy pcy is offline
Old 11-14-2013, 06:03 AM
dwlink's Avatar
dwlink dwlink is offline
Mein Auto: 435i Gran Coupe
Relax, as others have said it's just a battery issue. Heck if you have Geico insurance you can just call AAA and they'll jump it for you at no cost. As you drive the car it'll get its charge back. A mechanic will be able to tell you if it was a drained battery, and old battery going bad, or something else like an alternator that would prevent the battery from charging.
2015 BMW 435i GC MSport (ED Sept 29, 2014)
2004 BMW 530i (retired)
Old 11-14-2013, 06:55 AM
F1.tifosi's Avatar
F1.tifosi F1.tifosi is offline
Send a message via Yahoo to F1.tifosi
Mein Auto: BMW 535i Sport, 08 Accord
AAA can also confirm if you need a replacement battery..
You will need to at least drive 20 miles daily to avoid these situations,.. short driving on a daily basis can shorten the battery life..
Jet Black | LCSW | DP WT | ZCW | ZPP | ZSP | 261 | 2TB | 322 | 415 | 416 | 609 | 610 | 620 | 677 | 6FL | 6UH |F/R Cameras | Escort 9500ix |
Old 11-14-2013, 07:19 AM
fdriller9 fdriller9 is offline
Mein Auto: '06 AW 330xi
It's not just the length of the drive it depends on engine load. The battery is charged when there is minimal load on the engine. This means cruising at highway speeds and maintaining those speeds.
| LCI Msport Conversion | Exotic Tuning Front Lip | H&R Coilovers | M3 Subframe Bushings | Custom Polyurethane Shore A90 Tension Strut Bushings | E93 M3 23.6mm Rear Sway Bar | UUC Front Sway Bar | Custom Heim Joint Rear Control Arms | Apex ARC-8 | Dunlop Direzza ZII Star Spec | Modified Dinan Cold Air Intake | aFe Oiled Drop-in Filter | Custom Hand-Made LED Angel Eyes | Alpine MRP-M500 | Custom LED Reverse Lights | OEM Blacklines | BMW Performance Trunk Spoiler |
Old 11-14-2013, 07:36 AM
Thanks guys but what bout my key not working..
Old 11-14-2013, 08:12 AM
pcy pcy is offline
Battery in the blade type key degrades over time. If you are handy with soldering iron, you can cut open the key and replace the battery.
Or, you will need to order a new at the dealer for couple of hundred dollars.
Old 11-14-2013, 08:31 AM
Wait so then how do I know if its the battery or key..
Old 11-14-2013, 10:09 AM
pcy pcy is offline
Check the voltage across battery terminals to verify the current status of the [car] battery.
Fully charged battery should read around 12.6V. If the voltage is below 12.4, get it recharged.
Auto parts stores usually [load] test the battery for free.
As for the key...
If the car is working fine with one key and doesn't work the same way with the other key, then you can be confident that battery in the key is the problem.
Old 11-15-2013, 05:58 AM
stmoore01 stmoore01 is offline
Mein Auto: 2010 535xi sport
My advice is to work on one problem at a time. As explained, it sounds as if your car battery has died. WIth the dead battery the key-fob obviously will not work as the cars systems are basically inoperable until there is sufficient charge on the car battery. During the jump starting process you will know right away if the Key-fob is OK or not. Once the car has power on the system from the "doner' car you should be able to use your key to lock/unlock the doors. If that works your key is good and start the car and get to the dealer or auto parts store for a new battery. Remember that you will need to get the battery registered to your car. What this means is that the car needs to be programmed to know that it has a new battery and that battery will have different charging characteristics than your old battery. If you don't reprogram you might experience a shorter overall battery life.
Old 11-18-2013, 09:31 PM
severecaraddict severecaraddict is offline
Send a message via AIM to severecaraddict
Mein Auto: 2004 530i SMG
Subscribed for entertainment value in future posts made by OP.
Old 11-18-2013, 11:19 PM
UltimateDriving UltimateDriving is offline
Mein Auto: A Car
Take it to a MECHANIC.
Old 11-19-2013, 04:18 AM
banglenot's Avatar
Mein Auto: 2007 530
I'm beginning to believe that James is, as the Brits say, "having us on".
Shrug. I think I'll save my help and advice for others.
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
Old 11-19-2013, 07:20 PM
6ICEMAN9's Avatar
6ICEMAN9 6ICEMAN9 is offline
Mein Auto: 08 550i
I've stopped trying to help this one a few threads ago.
Old 02-03-2014, 06:46 AM
tire size
Is it possible for me to get wider tires in the back when my car has all the same size all around..u jus put coils in and running have 245 all around I wanna go wider in the back is that possible
Old 02-03-2014, 06:50 AM
schpenxel schpenxel is offline
DIY'er
Mein Auto: 2004 545i
nvm.
