Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - E23 / E32 (1977 - 1994)
Old 11-10-2013, 08:47 PM
Armageddon32695 Armageddon32695 is offline
Mein Auto: 1989 735i
1989 735i trans issues
I have a 1989 735i that i have been having some issues with. The transmission starts off in first gear goes until it redlines then violently shifts into 4th gear and doesnt come out of 4th until i turn my car off and let start it again. And when i try and shift it to a lower gear manually it doesnt engage. And when i shift it either into reverse or park the entire car jerks heavily and after i do that and put it back into drive it stays in 4th gear. And today it did that and after turning the car off for the 5th time i put it in drive and hit the throttle and it revved high and suddenly jerked and went. It felt like i was first starting to learn to drive manual but this beemer is automatic! I read that it could be a certain solenoid or something relatively easy. if anybody knows anything to try before i have to go out and buy a new trans i would greatly appreciate any knowledge or ideas how to maybe fix it. thank you so much in advance.
Old 11-14-2013, 11:15 PM
Jwrightkustomz Jwrightkustomz is offline
BMW ****
Mein Auto: 1987 735i
Do you know what trans it is? It sounds like the transmission is going into fail-safe mode. Is the fluid full? When was the last time it was serviced? Some guys say dumping a quart of lucas transmission fix and changing the fluid can fix it. I personally don't believe in the 'mechanic in a can' but, if your tranny is toast what's it going to hurt? If I recall depending on the transmission there is sometimes issues with the filter collapsing, solenoids sticking, or valves sticking. I don't think a new trans is necessary, usually just a valve body replacement/rebuild does the trick.
Old 11-15-2013, 08:38 AM
It is an e32 6 bolt automatic tramsmission. The fluid is full I did it about a month ago yesterday I took the pan off and the filter off and sprayed a lot of cleaner in hopes it would at least help the problem. I am putting it back together today
