Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series DIY
7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners
Old 11-15-2013, 06:22 AM
rippjd rippjd is offline
Mein Auto: '05 745i / '10 X5 35d
Reference - Official list of E65/E66 retrofits & coding times per Progman v32
As the title states, attached is a scanned copy of the retrofits and conversion list according to BMW's programming software - Progman. Progman is no longer used by BMW Dealers as they have transitioned to a different platform which uses ISTA/P for programing and coding.
Note that many of the options listed will not show when Progman is connected to your car due to geographical region limitations. For example, a US spec car will not show the "BMW Online" as a retrofit option as it was not supported for the North American market.
Some retrofits and conversation will only be applicable for certain model years due to hardware changes during production.
If anyone has any related SIBs, please attach them to this thread.
For example, I know there are some SIBs to better explain when to apply the different transmission conversions.
Coasting jolt: Dampen coasting jolt.
Shift jolt: Dampen shift jolt.
Load change jerk: Dampen load change jerk.
City program: Activate city program.
I've also attached the list of programming times when using OPPS or OPS diagnostic heads, thought I've seen similar times programming through aftermarket OBD to USB adapters.
2005 745i Individual
E65/E66 Parts for Sale:
Alpina Type 743 Front Spoiler complete retrofit kit (new in box) $1200
Old 11-16-2013, 03:07 AM
And here is the retrofit kit Part Number list (first part number column) and respective Installation Instructions (EBA) or Owners Manual (MOI) for most retrofits. Many retrofit kits cannot be ordered in North America, some may already be NLA (no longer available).
I can obtain PDF's of some EBA documents. Send me a PM, though I will pass on some of the cost...
Old 04-27-2016, 06:55 PM
Below are some of the more popular retrofits:
File Type: pdf EBA 0300852 Rear-View Camera Retrofit for 02-05MY - UPDATED.pdf (1.04 MB, 215 views)
Old 12-26-2016, 07:54 AM
Recently I was able to get ISTA/P working and wanted to update this thread with a list of current Conversations / Retrofits available at your local BMW Dealer. See the first attachment to the list after doing an initial measures plan on my USA spec 745i. I have added ACC (Active Cruise Control) and the Multimedia (DVD) Changers, but I'm not sure if they would be listed anyways as these retrofits were never supported in USA spec cars. Some of the conversions I'm familiar with, and added comments in RED font.
I then changed my Vehicle Order to a EURO spec 745i (removed GL63 and added GL61) to see if the list would change. The initial measures plan wanted me to install a new DME (engine ECU), reprogram my AGS (transmission) and SVS (likely from US English to UK English) and lastly install a new TCU (telephone ECU). I re-ran the list of Conversions and only saw one change - adding the Pro Telephone with Handset (2nd page of partial list).
Old 01-13-2017, 06:19 PM
And if you get ISTA/P working, here is a list of Car Key Memory options for the E65 / E66. Some options may not show up depending on the country version (USA vs. EURO).
