Crank position Sensor - Bimmerfest - BMW Forums
Old 11-13-2013, 11:15 PM
mybmw408's Avatar
mybmw408 mybmw408 is offline
Mein Auto: BMW 750i
After work I started my 2007 750i. When I tried to drive off, car seemed like it wasn't running on all 8 cylinders, very rough. The check engine came on and ran rough on freeway. Came home and ran codes P0016. Is this the sensor under the car on tranny??
Old 11-14-2013, 05:34 AM
karmaxul karmaxul is offline
Mein Auto: 745i
Yes the sensor is under the transmission. You will need to remove the plastic skid plate and metal skid plate. A 5/8 wrench gave me the best fit on these bolts. I have some picture here of where it is.... http://www.bimmerfest.com/forums/sho...181&highlight=
http://www.bimmerfest.com/forums/album.php?albumid=10496&pictureid=39737 One love
Old 11-14-2013, 10:24 AM
mybmw408's Avatar
Mein Auto: BMW 750i
I seen your pictures for location of the crankshaft position sensor. Just that on code reader screen shows both Crankshaft position sensor and Camshaft position sensor. I know the camshaft position sensors on Bank 1 are on the passenger side. Which one is sensor A??? Just trying to figure this out.
Old 11-14-2013, 10:26 AM
Mein Auto: 745i
Sorry my friend I am not sure which one is sensor A. I honestly have not heard reference to sensor A before.
Old 11-14-2013, 11:36 AM
mybmw408's Avatar
Mein Auto: BMW 750i
Just took it out. Ordered another from BMA here in California $55, BMW dealer wanted $160
ID:	407491Click image for larger version
Old 11-14-2013, 03:15 PM
inspi inspi is offline
Mein Auto: 03 BMW 745i, 06 BMW 750Li
Looks like problem with VANOS to me. Sensor change is useless. The code sey Crankshaft-Camshaft-that's mean timing .....
INSPI
Old 11-14-2013, 03:22 PM
mybmw408's Avatar
Mein Auto: BMW 750i
I'm new to this Vanos stuff, can you explain please??? I've owned older bmw's without this. Have owned this car for almost a month now.
Old 11-14-2013, 03:29 PM
VANOS it's kinda complicated, but i will start with cleaning of check valve #8 on picture located in cylinder heads-total 4 pieces
INSPI
Old 11-14-2013, 03:32 PM
mybmw408's Avatar
Mein Auto: BMW 750i
So this is a major job
Old 11-14-2013, 03:35 PM
mybmw408's Avatar
Mein Auto: BMW 750i
Have to pull motor apart for this.. Don't think there is a DIY for this
Old 11-14-2013, 03:36 PM
Not realy, if you handy
INSPI
Old 11-14-2013, 03:38 PM
mybmw408's Avatar
Mein Auto: BMW 750i
Have to pull timing cover to get to it , everything else in the way
Old 11-14-2013, 03:39 PM
No, everything is outside of head. And i will also check VANOS solenoids
INSPI
Old 11-14-2013, 03:46 PM
Check valves can be removed with intake installed, just take out throtle body
INSPI
Old 11-14-2013, 03:55 PM
mybmw408's Avatar
Mein Auto: BMW 750i
how do the check valves come out?? Special tool....
Old 11-15-2013, 01:48 AM
Torx bit, but i don't remember size
INSPI
Old 11-15-2013, 06:22 AM
Mein Auto: 745i
I am having the same issue with mine and while I am waiting for the sensor to arrive in the country as our BMW dealer does not have it on hand I would like to check the check valve and solenoids.
If you dont mind me asking, once I have them removed, what exactly am I looking for to know they are working properly or need to be replaced.
Old 11-15-2013, 06:50 AM
mybmw408's Avatar
Mein Auto: BMW 750i
Also do I use carburetor cleaner to clean it??? Just spray clean then re install?? I want to try this tonight.
Old 11-15-2013, 01:59 PM
mybmw408's Avatar
Mein Auto: BMW 750i
Don't see anything wrong, just oil on it, looks cleanClick image for larger version
ID:	407686Click image for larger version
Old 11-15-2013, 02:02 PM
Yep, check for any dirt or contamination. And if you found something, then just clean it up. All valve and solenoid are same, so you can try to switch them (bank1 to bank2), then you will see, if the error move to other side-then the solenoid is bad
INSPI
Old 11-15-2013, 02:03 PM
Originally Posted by mybmw408 View Post
Don't see anything wrong, just oil on it, looks cleanAttachment 407686Attachment 407687
Looks OK, how about solenoids?
INSPI
Old 11-15-2013, 02:04 PM
mybmw408's Avatar
Mein Auto: BMW 750i
Are solenoids hard to put back in???
Old 11-15-2013, 02:45 PM
No. Remove 10 mm size bolt and pull it out, reverse for install, just make sure you put back O-ring
INSPI
Old 11-15-2013, 02:51 PM
mybmw408's Avatar
Mein Auto: BMW 750i
I'm waiting for my crankshaft sensor to arrive tomorrow, before I tackle that. It was really quick to check these, 15 min or less.
Old 11-15-2013, 04:03 PM
mybmw408's Avatar
Mein Auto: BMW 750i
Ok couldn't waitClick image for larger version
