Old 11-10-2013, 10:59 PM
mpx mpx is offline
Mein Auto: Explorer
Question Engine diagnostic - where to start?
So I entered the BMW world with a project. I'm happy about that, I enjoy working on a car and learning. I'm excited that the car is this 528i.
It's an 97 528i (03/96) that I don't know anything about. The inner belt was shredded, probably because of lack of maintenance, as the last few owners seemed busy to get rid of it rather than maintain it. The engine turns but doesn't start. With ignition on there seems like a pump cycling somewhere under the air duct. It hums for a few minutes, stops, then whirs again. There are 4 codes stored:
P0500 Vehicle Speed Sensor Malfunction
P0505 Idle Air Control System
P1421 Secondary Air Bank 1
P1423 Secondary Air Bank 2
When the belt breaks and the water pump stops running, does the engine stop to prevent overheating? How can I estimate at this point the damage to the engine? I remember one post mentioning that '96 models would be less likely to have a warped head, another post recommending an engine swap over a repair if the heads are warped. The engine oil is dark but seems ok.
The 2 last codes seem to involve the exhaust check valve or secondary air pump. If these were bad, would they prevent the engine from starting? Where do you suggest I start?
Thank you.
Old 11-11-2013, 12:54 AM
mjalloul11's Avatar
BMW forever
Mein Auto: 1996 528i 1999 MB C240
The sound you hear is probably the ICV , It buzez with ignition on. You have the iron block but even that can get the head warped, take the plugs off and see if water is present. Air pump does not stop the engine, it makes for a rough one. Start with the basic, AIR,FUEL and SPARK.
Old 11-11-2013, 05:23 AM
Fudman's Avatar
Fudman Fudman is offline
Ignore the SAP for now. It has no impact on engine performance. It throws a code when it doesn't function because it is an emissions system. However, if your car does not start, you have much bigger issues. If your car had overheated badly, then the engine is toast. Belt failure does not cause the engine to stop so overheating is a definite possibility. +! on above. When it doesn't start, check for air, fuel and spark. THEN check the head gasket and then fix the SAP.
Old 11-11-2013, 06:10 AM
JimLev JimLev is offline
Mein Auto: 540/6, Tribeca
Do you know when the last time it was running? Was it weeks ago or years ago? Do you hear the fuel pump running when you turn the key to position 2? It will only run foe 2-3 seconds so you need to have someone turn the key while you have your head stuck in the trunk listening for it.
Have you tried spraying some starter fluid into the intake manifold?
Old 11-11-2013, 07:48 AM
Gas, air, spark, compression, and finally timing, in that order (as noted above).
Old 11-11-2013, 10:05 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
I believe your engine has a Schrader valve somewhere on the injector manifold. Get a fuel pressure tester at Harbor Freight, and measure it. S/b 50+ psi.
Old 11-11-2013, 10:46 AM
poolman poolman is offline
Mein Auto: 525i station wagon
Check all the vacuum ports and hoses--most of your code problems can and will occur because of vacuum leaks--haveing a big one can also keep the engine from starting.
Old 11-11-2013, 11:16 PM
mpx mpx is offline
Mein Auto: Explorer
Question update #1
Thank you for the quick replies.
The car hasn't run in over a year, at least. The title history shows the previous transfer last year with the same odometer reading. I can't tell if there were any attempts to repair it, I would say there were none.
I took the MAF sensor out and I sprayed starting fluid in the remaining segment of the duct. No spark, but it didn't seem to crank fast enough, either, I'll try again with a better battery.
I took out spark plugs #1 and #2. I smell gas and they are fouled, based on charts I'd say dry carbon. At 160k, they seem to be the original Bosch F8LDCR.
How can I check the crank/cam position sensors, if they are next? I see many posts to read through, please let me know what you think I should do next. I'm trying to go through all your suggestions and I'll update the thread.
Old 11-11-2013, 11:28 PM
mjalloul11's Avatar
BMW forever
Only the crank sensor is important but it will throw a code. You seem to be getting fuel, next is spark! Fresh plugs and a good battery is next i think.
Old 11-15-2013, 11:52 AM
mpx mpx is offline
Mein Auto: Explorer
After many other hours spent reading this forum, I found the numerous posts about engine diagnosis. I want to thank you for the patience you had to answer my questions, even when similar threads were already available.
I purchased a new battery and checked that I have spark. I have fuel, I can hear the fuel pump running when I short the pins on the relay ( and the relay is good) and I always have gas squirting whenever I release the Schrader valve on the fuel rail after I crank the engine. But the engine wouldn't start even with starting fluid.
I only have compression in cylinder 6. I measured: 1(30),2(20),3&4 almost zero,5(30) and 6(120)psi. I figured the cylinders must have been flooded on several occasions while cranked so I added some transmission oil in each cylinder. That increased compression by at least 20 psi in all except for the middle ones. #6 increased to 200psi.
Given that the engine most likely overheated when the serpentine belt broke, should I start shopping around for a new engine after what I found out? But I should still take the heads off and see what I find, right? The engine should have the iron block, what is the best scenario I can hope for and what special tools would I need?
Old 11-15-2013, 11:21 PM
These threads have been prepared to help people with similar problems once an engine has overheated to the point where the question needs to be asked ...
- Summary advice to provide users who suspect a major engine repair due to overheating (1) (2) (3) (4) & how to test an engine for a blown head gasket, cracked heads, a warped block, stripped head bolt threads, cam seizures, contaminated bearings, coolant hydrolock, or piston, ring, or valve damage (1) (2) & what are the major factors in deciding whether to rebuild the engine, replace the engine, or sell the car (1) & a DIY for replacing the I6 M54 head gasket (1) (2) & replacing the V8 M62TU head gasket (1) & why these engines are so prone to heat-related damage in the first place (1) & welding the crack between cylinder #3 and the water jacket on the exhaust side (1) & what engine swaps are most recommended (1) (2) (3) & where to obtain a new or rebuilt head (1) replacement short block or long block (1) (2) & how to lift & remove the engine (1) & the most recent real-world results from the last 50 people faced with similar blown engine problems from which this advice came from (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) (17) (18) (19) (20) (21) (22) (23) (24) (25) (26) (27) (28) (29) (30) (31) (32) (33) (34) (35) (36) (37) (38) (39) (40) (41) (42) (43) (44) (45) (46) (47) (48) (49) (50)
